    MMM-MyCommute not showing up.
    31 Posts 4 Posters 14.4k Views 4 Watching
      sdetweil @Doogain
      @Doogain that is NOT your ‘config’… that is the module source.
      my general rule, you never edit the module source, unless u are doign something special, like extending its functionality
      to install a module you do
      cd ~/MagicMirror/modules
      git clone ???
      where ??? is the module github url
      then when that completes, you add a
                module:   ??? ,
      to the modules array in config/config.js
      the required data for the config entry will be found in the README.md file in the module folder just created by the git clone operation
        Doogain @buzzkc
        @buzzkc said in MMM-MyCommute not showing up.:
        @Doogain Did you add the module into the MagicMirror/config/config.js?
        That might be the issue, I didnt know I had to do that. Never installed a module before.
        @sdetweil said in MMM-MyCommute not showing up.:
        git clone ???
                  module:   ??? ,
        I already did the first part, its the last part that I think I’ve screwed up on. I’ll give a go now, will post back soon.
          Doogain
          So I added this to config.js in MagicMirror/config
          module: “MMM-MyCommute”,
          position: “top_left”,
          header: “Traffic”,
          classes: “default everyone”,
          I recieved this error in developer console now
          alt text
          • buzzkcB Offline
            buzzkc
            @Doogain
            Your config entry should look more like the one in the Readme.md page of the module (https://github.com/jclarke0000/MMM-MyCommute)
            Also, be sure you followed all of the installation notes in the readme.
              module: 'MMM-MyCommute',
              position: 'top_left',
                apikey: 'API_KEY_FROM_GOOGLE',
                origin: '65 Front St W, Toronto, ON M5J 1E6',
                startTime: '00:00',
                endTime: '23:59',
                hideDays: [0,6],
                destinations: [
                    destination: '14 Duncan St Toronto, ON M5H 3G8',
                    label: 'Air Canada Centre',
                    mode: 'walking',
                    color: '#82E5AA'
                    destination: '317 Dundas St W, Toronto, ON M5T 1G4',
                    label: 'Art Gallery of Ontario',
                    mode: 'transit'
                    destination: '55 Mill St, Toronto, ON M5A 3C4',
                    label: 'Distillery District',
                    mode: 'bicycling'
                    destination: '6301 Silver Dart Dr, Mississauga, ON L5P 1B2',
                    label: 'Pearson Airport',
                    avoid: 'tolls'
            Darren
            My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
              sdetweil @Doogain
              @Doogain u modified the module source. Please remove yours, and customize the config.js
                Doogain
                I reverted the module source, I messed up bigtime on that. The modules show up in MM now, and that is so great! Thanks a lot!
                It does give a me a error instead of commute time tho, I think thats a either a API or adress error.
                Which API do I have to select from google? It gives me several choices.
                • buzzkcB Offline
                  buzzkc
                  I believe it’s the Maps Javascript API>>Directions API
                  Darren
                    Doogain @buzzkc
                    Hmm still getting a error where it should say commute time.
                    It says:
                    MMM-MyCommute: You must enable Billing on the Google Cloud Project at https://console.cloud.google.com/project/_/billing/enable Learn more at https://developers.google.com/maps/gmp-get-started
                    I already have that enabled tho.
                      Doogain
                      I figured it out. I had to enable all the following
                      1.) Maps Javascript API
                      2.) Directions API
                      3.) Geocoding API.
                      Marking as solved, thanks for all the help :-)
                        sdetweil @Doogain
                          spoonek
                          Sorry to bump an old post, seemed like a better idea vs creating a new one…
                          I’m having the same issue. I’m using MagicMirror 2.12. The MMM-MyCommute module shows “Error” in red for my destination. I have an api key. The api key is active. I’ve added the Directions API, Geocoding API and Maps JavaScript API to my Google Cloud Platform account. I’ve tried both apikey and apiKey. I did read on the Google site that the request needs to be something like “key_api” but can’t find that verbiage again to validate. Not sure what else I can do at this point. Any tips? Many thanks!!
                          code:
                          	header: 'Commute Times',
                          		apiKey: '**********************************',
                          		origin: '**my home address**',
                          		startTime: '00:00',
                          		endTime: '23:59',
                          		destinations: [
                          				destination: '6000 N Terminal Pkwy, Atlanta, GA 30320',
                          				label: 'Airport'
                            sdetweil @spoonek
                            @spoonek apikey, all lower case, read the module doc
                            open the developers window ctrl-shift-i, then select the console tab and scroll up see any errors. u can also filter messages by module, by placing part of the module name in the filter field ‘comm’ for example
                              spoonek @sdetweil
                              @spoonek apikey, all lower case, read the doc
                              Thanks. There is conflicting info on github. One MyCommute says use apikey. The other fork says to now use apiKey. I tried both, same result…“Error”.
                              I’ll check out the dev window. I’m a n00b so learning as I go. Appreciate the suggestion!
                              [edit]. …aaaaaand I’m on a MAC. :man_facepalming_light_skin_tone:
                                sdetweil @spoonek
                                @spoonek the same result means the problem is probably in the key. Google requires a credit card to back their accounts, altho they give generous credits against usage for a while
                                  spoonek @sdetweil
                                  @sdetweil Yep, I added a card and activated the account last night. Was hoping it would sync up overnight but same issue this morning.
                                    sdetweil @spoonek
                                    @spoonek use the menu to get the dev window open. or start with
                                    npm start dev
                                    if u normally use pm2, do pm2 stop 0
                                    before the npm start
                                      sdetweil @spoonek
                                      @spoonek no sync time. it’s immediate.
                                        spoonek @sdetweil
                                        npm start dev
                                        OK, that is awesome! Thanks for the tip! So maybe I need to generate a new api key and use that?
                                        [2020-08-20 09:07:14.680] [LOG] MMM-MyCommute: You must use an API key to authenticate each request to Google Maps Platform APIs. For additional information, please refer to http://g.co/dev/maps-no-account
                                          sdetweil @spoonek
                                          @spoonek u didn’t list the maps api I the list of services above
                                            spoonek @sdetweil
                                            @sdetweil thanks. I don’t see it…
