    MMM-MyCommute not showing up.
    31 Posts 4 Posters 14.8k Views 4 Watching
      Doogain @buzzkc
      @buzzkc said in MMM-MyCommute not showing up.:
      I believe it’s the Maps Javascript API>>Directions API
      Hmm still getting a error where it should say commute time.
      It says:
      MMM-MyCommute: You must enable Billing on the Google Cloud Project at https://console.cloud.google.com/project/_/billing/enable Learn more at https://developers.google.com/maps/gmp-get-started
      I already have that enabled tho.
        Doogain
        I figured it out. I had to enable all the following
        1.) Maps Javascript API
        2.) Directions API
        3.) Geocoding API.
        Marking as solved, thanks for all the help :-)
          sdetweil @Doogain
            spoonek
            Sorry to bump an old post, seemed like a better idea vs creating a new one…
            I’m having the same issue. I’m using MagicMirror 2.12. The MMM-MyCommute module shows “Error” in red for my destination. I have an api key. The api key is active. I’ve added the Directions API, Geocoding API and Maps JavaScript API to my Google Cloud Platform account. I’ve tried both apikey and apiKey. I did read on the Google site that the request needs to be something like “key_api” but can’t find that verbiage again to validate. Not sure what else I can do at this point. Any tips? Many thanks!!
            code:
            	module: 'MMM-MyCommute',
            	position: 'top_left',
            	header: 'Commute Times',
            		apiKey: '**********************************',
            		origin: '**my home address**',
            		startTime: '00:00',
            		endTime: '23:59',
            		destinations: [
            				destination: '6000 N Terminal Pkwy, Atlanta, GA 30320',
            				label: 'Airport'
              sdetweil @spoonek
              @spoonek apikey, all lower case, read the module doc
              open the developers window ctrl-shift-i, then select the console tab and scroll up see any errors. u can also filter messages by module, by placing part of the module name in the filter field ‘comm’ for example
                spoonek @sdetweil
                @sdetweil said in MMM-MyCommute not showing up.:
                @spoonek apikey, all lower case, read the doc
                Thanks. There is conflicting info on github. One MyCommute says use apikey. The other fork says to now use apiKey. I tried both, same result…“Error”.
                I’ll check out the dev window. I’m a n00b so learning as I go. Appreciate the suggestion!
                [edit]. …aaaaaand I’m on a MAC. :man_facepalming_light_skin_tone:
                  sdetweil @spoonek
                  @spoonek the same result means the problem is probably in the key. Google requires a credit card to back their accounts, altho they give generous credits against usage for a while
                    spoonek @sdetweil
                    @sdetweil Yep, I added a card and activated the account last night. Was hoping it would sync up overnight but same issue this morning.
                      sdetweil @spoonek
                      @spoonek use the menu to get the dev window open. or start with
                      npm start dev
                      if u normally use pm2, do pm2 stop 0
                      before the npm start
                        sdetweil @spoonek
                        @spoonek no sync time. it’s immediate.
                          spoonek @sdetweil
                          npm start dev
                          OK, that is awesome! Thanks for the tip! So maybe I need to generate a new api key and use that?
                          [2020-08-20 09:07:14.680] [LOG] MMM-MyCommute: You must use an API key to authenticate each request to Google Maps Platform APIs. For additional information, please refer to http://g.co/dev/maps-no-account
                            sdetweil @spoonek
                            @spoonek u didn’t list the maps api I the list of services above
                              spoonek @sdetweil
                              @sdetweil thanks. I don’t see it…
                                sdetweil @spoonek
                                @spoonek from the link on the module doc
                                Maps JavaScript API
                                from the image u posted,
                                2nd row, second box from left
                                  spoonek @sdetweil
                                  @spoonek from the link on the moduledoc
                                  Maps JavaScript API
                                  Yep, got that one already. :(
                                    sdetweil @spoonek
                                    @spoonek so, then, passing the key is a problem,
                                    so it might be the item name in config. u can specify both,
                                    and u got the right string for the API key from Google.
                                    which GitHub module are u using?
                                    from the module folder do,
                                    git remote -v
                                      spoonek @sdetweil
                                      OK, I’ll add apikey and apiKey. I just generated a new key as well. Billing acct is active too.
                                      pi@raspberrypi:~/MagicMirror/modules/MMM-MyCommute $ git remote -v
                                      origin https://github.com/jclarke0000/MMM-MyCommute.git (fetch)
                                      origin https://github.com/jclarke0000/MMM-MyCommute.git (push)
                                        sdetweil @spoonek
                                        @spoonek from the module folder
                                          spoonek @sdetweil
                                            spoonek @spoonek
                                            @sdetweil Looking good now after adding both apikey and apiKey. Most likely me generating a new key as well. Thanks for the dev tips! Will be useful for me down the road.
