    MMM-MagicMover
    15 Posts 8 Posters 6.3k Views 7 Watching
    • Cr4z33C Offline
      Cr4z33
      Hmm very usefull module here thanks.
      It will come very handy once I’ve setup my daughter 24/7 smart mirror!
      C-sonC 1 Reply Last reply Reply Quote 1
      • C-sonC Offline
        C-son Module Developer @Cr4z33
        @Cr4z33 Thanks for feedback, and good luck with your daughters mirror :)
        MMM-MagicMover :: MMM-MagicSuperHero :: MMM-MagicHexClock
          raymondjspigot
          hi C-son thanks for your module, I’m just building and trying out my mirror and avoiding burn-in sounds like a great idea.
          I’ve been slowly configuring my mirror and started using the module MMM-BackgroundSlideshow as well. I’m finding that if I enable MMM-MagicMover then my background images don’t show (I just get my Clock, Calendar modules etc. displaying on a black background). If I disable MMM-MagicMover then the background images from MMM-BackgroundSlideshow are displayed under my other modules ok like before.
          Do you know if there’s a way to run both modules at the same time? I’ve experimented with changing the module position values in my config.js but it didn’t seem to help.
          (My MMM-BackgroundSlideshow is in position: fullscreen_below incidentally)
          thanks for any help anyway
          C-sonC 1 Reply Last reply Reply Quote 0
          • C-sonC Offline
            C-son Module Developer @raymondjspigot
            @raymondjspigot thank you for your bug repport. I will try to find a solution for this.
            • BKeyportB Offline
              BKeyport Module Developer
              Installed new version today, and now the middle column of items are pushed way right. don’t seem like anything is moving around either.
              Anything I can do to fix it, or should I wait?
              • C-sonC Offline
                C-son Module Developer @BKeyport
                @BKeyport hard to say since I have no idea what other modules you’re using. It’s also hard to anticipate what and how other modules available for the Magic Mirror will affect Magic Mover. :)
                • BKeyportB Offline
                  BKeyport Module Developer @C-son
                  @C-son Apparently, updates you did between my post and my capturing screen shots fixed it. It’s now working normally after another git pull.
                  Thanks!
                  • C-sonC Offline
                    @BKeyport awesome, thanks for getting back to me!
                    • C-sonC Offline
                      A new version of MMM-MagicMover is now released. Now you can add regions that shouldn’t be included, by adding them to an array:
                        module: "MMM-MagicMover",
                          updateInterval: 60 * 1000,
                          ignoredRegions: [],
                          maxMove: 20,
                      Valid regions are: '.region.top.bar', '.region.upper.third', '.region.middle.center', '.region.lower.third' and '.region.bottom.bar'.
                        mcaminiti @C-son
                        @c-son If I have a full screen background rotating from Bing or somewhere else, do you think that change is enough to prevent some burn in or would something like this still be helpful for clock, date and other things that maybe are always white and showing up.
                        Fairly new to MM and found this module which I think is great idea. I didnt know if this burn in was common?
