    custom.css not executed on return from GoogleAssistant. MMM-GoogleAssistant
    google assistant
    23 Posts 4 Posters 6.5k Views 3 Watching
      A Former User
      @gelaw: I think you can’t use custom.css for tunning GoogleAssistant. (never tested with it)
      Because GoogleAssist use Iframe ouside the dom for displaying content (and Assistant2Display extension too)
      but you can use css files inside GoogleAssistant directly
      • G Offline
        gelaw @Guest
        @Bugsounet Thanks for the response. I am am using custom.css to place the default clock module on the screen. This custom.css file is not related to MMM-GoogleAssistant at all. My issue occurs when MMM-GoogleAssistant exits; then it returns to the MagicMirror screen but the clock is not placed correctly. When MMM-GoogleAssistant exits, it appears that ~/MagicMirror/css/main.css is executed, but my custom.css file is not executed.
        However, if I then press cntl-w, then the screen resets correctly. I am wondering what commands/code are executed when MMM-GoogleAssistant exits? And can I change that?
          A Former User
          @gelaw
          then … no idea … GA only deactivates all the modules for take place for fullscreen and reactivates them once the conversation is over (hidden and show)
          maybe @sdetweil can say more?
          • G Offline
            gelaw @Guest
            @Bugsounet Thanks again for your response. I did a quick test putting my modified .css code into main.css and the exact same behavior occurred. That is: displayed correctly when MM started, incorrectly when GA exits, and ^w corrects the display again. I am not sure where the issue occurs.
            As you say, maybe @sdetweil has better insight.
              sdetweil @gelaw
              @gelaw can u open the developers window after return from GA display and look at your clock module css changes (select the elements tab, and navigate the dom tree)
              click on the element you changed with custom.css and look at the bottom of the dev window, which should give the classes used top to bottom, left to right… is your modified class there? then look on the right side to see the class content definitions are your changes there,
              another thing to try if address:“0.0.0.0”, and ipWhitelist:[] in config.js, you can access MM from another machine, use chrome on your PC and repeat the test… see if it fails on chrome…we are downlevel on electron (hard to test with so many changes going into it all the time)
              • G Offline
                gelaw @sdetweil
                @sdetweil Thanks! I will try this and report back
                • G Offline
                  gelaw
                  @sdetweil I did a test with Google Chrome on a second machine. As far as I can tell I get the same response - that is on a return from GoogleAssistant it does not use my custom.css settings. Cntl-W has the same effect.
                  I do not know how to work with the developers window. I opened the window, and the elements tab was open. I could not find the classes after that. I really do not know how to use the developers window. Can you point me to a write-up or tutorial on using the developers window?
                  S ? 2 Replies Last reply Reply Quote 0
                    sdetweil @gelaw
                    @gelaw I don’t know where to find any training.
                    the elements tab shows the web page in the browser. ~/MagicMirror/index.html shows the format of the web page.
                    mm puts content in ‘positions’ which are listed in the index.html
                    when u get to an element, then u will see the classes used
                    here I have navigated to the calendar and selected an element
                    u can see the classes along the right edge, top to bottom, bottom is closer to main and custom.css
                    top is closest to the element selected.
                    You can see the class list left to right just above the console area, bottom of elements area (this machine doesn’t have an image editor on it so I can’t mark it up)
                      A Former User @gelaw
                      @gelaw sure i use it ;)
                      I will try something
                      custom.css works with GA and other modules.
                      So maybe, i think there is an error with your custom.css code
                      try to correct it in real time, and past the new css code found
                      • G Offline
                        gelaw @sdetweil
                        @sdetweil Thanks! I see it now. Here is what I found:
                        When I start MM:
                        When I access GoogleAssistant:
                        When the system exits GoogleAssistant and returns to MM the modified element.style persists and the position remains “fixed”.
