    Video player -> would someone like to help me to write a program?
    18 Posts 3 Posters 6.3k Views 3 Watching
      sdetweil @Goldjunge_Chriz
      @Goldjunge_Chriz ok, thx. this forum is for magic mirror related work.
      • G Offline
        Goldjunge_Chriz @sdetweil
        I know 😅 that’s why I posted it in general discussions. I’ve been an active member here for years and I was just hoping someone with programming experience could help me, even if it’s not a magicmirror project.
          ashishtank Module Developer
          May be you can check https://github.com/osmc/osmc ? this is open source media player, you can modify the source code to support your feature ?
          • G Offline
            Goldjunge_Chriz @ashishtank
            @ashishtank said in Video player -> would someone like to help me to write a program?:
            many thanks :) I know this player. Unfortunately it is and remains just a player. Here too… some script has to be created to implement my wishes. And here is the problem again …
            • G Offline
              Goldjunge_Chriz
              I need something simple that works according to the following example scheme:
              Start loop
              Select random Video from Folder “placeholder 1”
              IF GPIO “XY” ist true
              THAN Select random Video from Folder “placeholder 2”
              ELSE Loop previous selected Video from Folder “placeholder 1”
              IF selected random Video from Folder “placeholder 2” is over
              THAN select random Video from Folder “placeholder 3”
              IF selected random Video from Folder “placeholder 3” is over
              THAN go Back to start
              End Loop
                @Goldjunge_Chriz got it… will check if i can help you with it. Is it fine that background script is starting and stopping the player based on GPIO input ?
                • G Offline
                  the player should actually always run automatically. So boot up and automatically play the first random video from “placeholder 1”. once all steps have been processed, he should simply play a video from “placeholder 1” again until the button is pressed. And so on in a loop, until you shut down the raspberry. I would like to avoid one or more actions.
                  Thank you in advance, I think it’s great that you want to help :)
                    Yes, i can help. infect i have also seen few open source scripts/players where one or more things are controlled by GPIO. I have limited time so i can not commit any time line for this yet.
                    • G Offline
                      @ashishtank
                      OK. I had actually hoped for relatively quick help, but if it doesn’t work sooner I’ll have to live with it :) I’m happy if someone supports me at all :)
                      S A 2 Replies Last reply Reply Quote 0
                        @Goldjunge_Chriz could you two take this to email or chat. thanks
                          ashishtank Module Developer @Goldjunge_Chriz
                          Hi @Goldjunge_Chriz you can check below post this have mostly similar feature. few changes and it should work for you. I am replying here so if some one have different opinion or better solution then can suggest, if you have any query for the below then do send me chat.
                          https://www.instructables.com/id/Raspberry-Pi-video-player-for-Children/
                          • G Offline
                            @ashishtank
                            that looks very, very interesting.
                            Can you help adapt the code for my needs? :) that with the playlists seems like a really interesting approach.
                            • G Offline
                              Goldjunge_Chriz
                              No other ideas or help ? 😟
