    MMM-MP3Player (remade asimhsidd's player)
    mp3 playermusic player
    14 Posts 5 Posters 6.4k Views 5 Watching
    • X
      x3mEr
      Hi, community!
      I present a MagicMirror module for playing music from folder.
      This is the version of the asimhsidd’s MMM-MP3Player module remade to my needs.
      @asimhsidd, thank you very much for so beautiful player!
      Differences:
      • my version play music from path, not USB;
      • besides .mp3, supports .wav and .flac;
      • has autoplay, random and loop options;
      • can be controlled with notifications;
      • only supports rock music.
      It was a first time I have ever worked with JavaScript. I know nothing! I just wanted working mp3 player for my mirror. After unsuccessful installations of several modules, I decided to remade asimhsidd’s player.
      P.S.: thank you, MichMich, for so cool project and community. Thank you, @sdetweil, for your numerous responses and hints and for helping module developers. I just want you to know you helped a lot of people (not only in this forum).
      Download
      • E
        emrah_asl
        Hi, How can I enable mp3 player only between 3 hours in a day ?
        05.00 AM - 08.00 AM
        X 1 Reply Last reply Reply Quote 0
        • X
          x3mEr @emrah_asl
          @emrah_asl, Hi. This module does not provide such opportunity. I think you should search module that can turn on/off or hide other modules on time.
          • X
            x3mEr
            UPD:
            Version 1.2.0 - 2020.09.14
            • Now player displays album cover. It tries to retrieve the image from ID3-Tags, if nothing found, it searches file cover.jpg in the playing music file directory.
            • add: turn random on/off over notifications.
              more in README.md
              Jonae
              i cant get notifications to start the player. Can you add an example? Thanks. How to use it with
              MMM-Remote-Control.
                sdetweil @Jonae
                @jonae looks like from the code, it can play music that is defined in the config.
                				case "PLAY_MUSIC":
                					if (audioElement.paused){
                						audioElement.play();
                					else {
                						self.sendSocketNotification("LOADFILE", self.songs[self.current]);
                					break;
                				case "STOP_MUSIC":
                					audioElement.pause();
                					break;
                				case "NEXT_TRACK":
                					if(!self.musicFound){
                						self.album_art.classList.toggle('active');
                						return;
                					if (self.config.random){
                						if (!arrPlayed.includes(false)){
                							arrPlayed.fill(false);
                						do {
                							ind = Math.floor(Math.random() * self.songs.length); // (self.current + 1) % self.songs.length;
                						} while (arrPlayed[ind] || ind == self.current); // ind == self.current: not to play one song twice - in the end of list and in the beginning of newly created list)
                						arrPlayed[ind] = true;
                						self.current = ind;
                					else {
                						if(self.current==(self.songs.length-1)){ // this assures the loop
                							self.current = -1;
                						self.current++;
                					break;
                				case "PREVIOUS_TRACK":
                					if(self.current==0){ // this assures the loop
                							self.current = (self.songs.length);
                					self.current--;
                					break;
                				case "RANDOM_ON":
                					self.config.random = true;
                					break;
                				case "RANDOM_OFF":
                					self.config.random = false;
                					break;
                  Jonae @sdetweil
                  @sdetweil i saw that, i send the notification and nothing happens…
                    sdetweil @Jonae
                    @jonae do you have the music defined in config?
                    u can use the developers window, sources tab to walk thru the modules code
                    ctrl-shift-i, select the sources tab, find the module and its js file, will show to the right
                    click the line number in the left edge where the notificationReceived is
                    then send your notification and it shoudl stop there, then the circle arrow, is step instruction
                    and u can hover over the variables to see what they contain
                    blue arrow to run to next stop (if any)
                      Jonae @sdetweil
                      @sdetweil thanks for the tipp, but nothing happens. like it is ignoring the notification, maybe remote control is not sending the right notification…
                        sdetweil @Jonae
                        @jonae notification is a text string
                        notification is just a text string, here its ‘PLAY_MUSIC’
                        u have to configure that as remote doesn’t have it built in.
                          Jonae @sdetweil
                          @sdetweil i have done it with curl, but now I am searching a easier way to play and stop music using curl
                          S B 2 Replies Last reply Reply Quote 0
                            sdetweil @Jonae
                            @jonae ok, can’t help with remote and I don’t use that module
                              Jonae @sdetweil
                              @sdetweil thanks anyways!!
                                bachoo786 @Jonae
                                @Jonae hi did you ever manage to control another way?
