MMM-MP3Player (remade asimhsidd's player)
mp3 playermusic player
14 Posts 5 Posters 4.1k Views 5 Watching
  • X Offline
    x3mEr
    Hi, community!
    I present a MagicMirror module for playing music from folder.
    This is the version of the asimhsidd’s MMM-MP3Player module remade to my needs.
    @asimhsidd, thank you very much for so beautiful player!
    Differences:
    • my version play music from path, not USB;
    • besides .mp3, supports .wav and .flac;
    • has autoplay, random and loop options;
    • can be controlled with notifications;
    • only supports rock music.
    It was a first time I have ever worked with JavaScript. I know nothing! I just wanted working mp3 player for my mirror. After unsuccessful installations of several modules, I decided to remade asimhsidd’s player.
    P.S.: thank you, MichMich, for so cool project and community. Thank you, @sdetweil, for your numerous responses and hints and for helping module developers. I just want you to know you helped a lot of people (not only in this forum).
    Download
    • E Offline
      emrah_asl
      Hi, How can I enable mp3 player only between 3 hours in a day ?
      05.00 AM - 08.00 AM
      X 1 Reply Last reply Sep 14, 2020, 9:43 PM Reply Quote 0
      • X Offline
        x3mEr @emrah_asl
        @emrah_asl, Hi. This module does not provide such opportunity. I think you should search module that can turn on/off or hide other modules on time.
        • X Offline
          x3mEr
          UPD:
          Version 1.2.0 - 2020.09.14
          • Now player displays album cover. It tries to retrieve the image from ID3-Tags, if nothing found, it searches file cover.jpg in the playing music file directory.
          • add: turn random on/off over notifications.
            more in README.md
            Jonae
            i cant get notifications to start the player. Can you add an example? Thanks. How to use it with
            MMM-Remote-Control.
            S 1 Reply Last reply Nov 7, 2021, 4:42 PM Reply Quote 0
            • S Away
              sdetweil @Jonae
              @jonae looks like from the code, it can play music that is defined in the config.
              				case "PLAY_MUSIC":
              					if (audioElement.paused){
              						audioElement.play();
              					else {
              						self.sendSocketNotification("LOADFILE", self.songs[self.current]);
              					break;
              				case "STOP_MUSIC":
              					audioElement.pause();
              					break;
              				case "NEXT_TRACK":
              					if(!self.musicFound){
              						self.album_art.classList.toggle('active');
              						return;
              					if (self.config.random){
              						if (!arrPlayed.includes(false)){
              							arrPlayed.fill(false);
              						do {
              							ind = Math.floor(Math.random() * self.songs.length); // (self.current + 1) % self.songs.length;
              						} while (arrPlayed[ind] || ind == self.current); // ind == self.current: not to play one song twice - in the end of list and in the beginning of newly created list)
              						arrPlayed[ind] = true;
              						self.current = ind;
              					else {
              						if(self.current==(self.songs.length-1)){ // this assures the loop
              							self.current = -1;
              						self.current++;
              					break;
              				case "PREVIOUS_TRACK":
              					if(self.current==0){ // this assures the loop
              							self.current = (self.songs.length);
              					self.current--;
              					break;
              				case "RANDOM_ON":
              					self.config.random = true;
              					break;
              				case "RANDOM_OFF":
              					self.config.random = false;
              					break;
              J 1 Reply Last reply Nov 7, 2021, 4:53 PM Reply Quote 0
                Jonae @sdetweil
                @sdetweil i saw that, i send the notification and nothing happens…
                S 1 Reply Last reply Nov 7, 2021, 4:57 PM Reply Quote 0
                • S Away
                  sdetweil @Jonae
                  @jonae do you have the music defined in config?
                  u can use the developers window, sources tab to walk thru the modules code
                  ctrl-shift-i, select the sources tab, find the module and its js file, will show to the right
                  click the line number in the left edge where the notificationReceived is
                  then send your notification and it shoudl stop there, then the circle arrow, is step instruction
                  and u can hover over the variables to see what they contain
                  blue arrow to run to next stop (if any)
                  J 1 Reply Last reply Nov 7, 2021, 5:46 PM Reply Quote 0
                    Jonae @sdetweil
                    @sdetweil thanks for the tipp, but nothing happens. like it is ignoring the notification, maybe remote control is not sending the right notification…
                    S 1 Reply Last reply Nov 7, 2021, 7:55 PM Reply Quote 0
                    • S Away
                      sdetweil @Jonae
                      @jonae notification is a text string
                      notification is just a text string, here its ‘PLAY_MUSIC’
                      u have to configure that as remote doesn’t have it built in.
                      J 1 Reply Last reply Nov 7, 2021, 8:30 PM Reply Quote 0
