    No numbers in analog watch face
    33 Posts 11 Posters 16.5k Views 9 Watching
    • I
      Ice-cream @Guest
      @hango Thanks Hango.
      1. I have updated the code (still not working presumably because of point 3 below)
      2. I don’t know where to download the old SVG faces - when I installed MM there was/is a folder full of SVG clock faces
      3. Please don’t laugh - I don’t know how to create/use a custom css folder - I plan to learn this soon! X
        A Former User
          sdetweil @Guest
          @hango if one uses my installer script, I create the empty custom.css as part of the install.
          ? 1 Reply Last reply
            A Former User @sdetweil
            • I
              Ice-cream
              1. Haha thanks guys - that worked!
              Very good point in regard to ‘‘how you update the code if you don’t know to create custom.css?’’- I previouly edited the config.js, clock.js and clock_styles.css > I created a really pretty analog clock with the centre, second hand, minute and hour each with different colours.
              1. For some reason I thought that a custom.css was really technical but I easily created this from my terminal.
              For what it’s worth, I’ve connected to a few APIs and have configued these in the main confg folder and the css’s.
              Going forward I’m going to play with customising the default modules (well the ones which I haven’t hidden in the main config file) in the custom CSS.
              Thanks again Xx
                sdetweil @Ice-cream
                @Ice-cream do not edit the default files.
                config in config.js and css in custom.css
                • T
                  TomBrown @sdetweil
                  @sdetweil said in No numbers in analog watch face:
                  @lavolp3 interesting, my script tries to minimize space used, so only downloads the master branch
                  to down develop do
                  git fetch origin develop:develop
                  git checkout develop
                  I am probably doing something wrong.
                  I typed in “git fetch origin develop:develop” and then “git checkout develop” and got an error.
                  error: Your local changes to the following files would be overwritten by checkout:
                  	modules/default/clock/clock.js
                  	modules/default/weatherforecast/weatherforecast.js
                  	package-lock.json
                  Please commit your changes or stash them before you switch branches.
                  Aborting
                    sdetweil @TomBrown
                    @TomBrown do u remember why you edited the clock and weatherforecast files?
                    • T
                      TomBrown
                      I edited the clock.js to change the default clock from digital to analog.
                      Not sure about the weatherforcast.js though. I did make a copy of the files before editing anything. Could I just rename the backup file to the regular one and try the update again?
                        sdetweil @TomBrown
                        @TomBrown yes u can copy the originals back.
                        never edit them, use the config.js to change the config.
                        git diff > somefile
                        will show u the changes into somefile
                        u can erase the package-lock.json file
                        • T
                          TomBrown
                          OK. That did it! Ran the update, now at version 2.13.0-develop
                          Changed the clock back to analog with face-010 and it is looking like I want it!
                          Thanks @sdetweil !!
                          • H
                            hayman
                            hello,
                            ive been using Face5 for a while pretty nice ,is there a way to change it to arabic numbers ?
                            thanks
