    Calendar Color
    27 Posts 12 Posters 22.3k Views 13 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @Mitch1138
      @Mitch1138 its still in the develop branch only
      R 1 Reply Last reply
      • Mitch1138M
        Mitch1138
        That was fast, thanks very much. How can you tell when it is released?
        A 1 Reply Last reply
        • A
          Aries1984 Module Developer @Mitch1138
          quick question on this issue…it the function already released? I can’t get it to work :( My config is:
                      colored: true,
                      header: "Termine",
                          displaySymbol: true,
                          timeFormat: "absolute",
                          getRelative: "0",
                          urgency: "0",
                          dateFormat: "DD.MM HH:mm",
                          FullDayEventDateFormat: "DD.MM",
                          fetchInterval: "5000",
                          fade: false,
                                  symbol: "mars",
                                  color: '#f70000',
                                   url: "https://calendar.google.com/calendar...",
                                  symbol: "venus",
                                  color: '#f70000',
                                  symbol: "clock",
                                  color: '#f70000',
                                  symbol: "globe",
                                  color: '#f70000',
                                  symbol: "cocktail",
                                  color: '#f70000',
          • L
            LeFreak76
            Hello Aries,
            have you found a solution for this problem? I have started my Mirror Build today and achieved a lot of good working things. But the calendars are driving me nuts. First test with MMM-MyCalendar failed because of incorect displayed times (11 or 25 minutes off). Never the less that one had colors. Now i switched back to the “default” calendar, and at least the times are properly shown (despite the fact the the absolute or relative Parameters are doing nothing…). Unfortunately it is not possible to change the colors of the different url’s.
            So please drop me a line if you found a solution to it. Or if not “Same problem here +1”
            Thanks a lot
            LeFreak76 from Hamburg
            • H
              hockey2112
              @LeFreak76 , I found a solution that worked for me: https://github.com/MichMich/MagicMirror/tree/develop/modules/default/calendar#calendar-configuration
              Basically, you need to add colored and coloredSymbolOnly settings/values. Then you can add the color setting with the hex code for each calendar.
                rally @strawberry 3.141
                @strawberry-3-141 What does that mean?
                It’s not available?
                  Mrc
                  Go to folder MagicMirror/modules/default/calendar , edit calendar.js , change values colored and coloredSymbolOnly to “true”
                    sdetweil @Mrc
                    @Mrc do NOT edit the module source files to change configuration.
                    put the settings in the config section for that. module in config.js
                    module:'calendar',
                    config:{
                        colored:true,
                        coloredSymbolsOnly:true
                      RJDaPirate
                      Any one know why all of the calendar entries are being assigned Mom’s color instead of their own?
                      			header: "Family Schedule",
                      			position: "top_center",
                      				colored: true,
                      						symbol: "calendar-check",
                      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                      						 symbol: "Dad's Calender",
                      							url: "https://calendar.google.com/calendar/ical/basic.ics",
                      							color: '#6600CC'
                      						symbol: "Mom's Calender",
                      						color: '#ff0000'
                      						Symbol: "A's Calender",
                      						color: '#00ff00'
                      						symbol: "J's Calender",
                      						color: '#40E0D0'
                      						symbol: "L's Calender",
                      							url: "https://calendar.google.com/calendar/basic.ics",
                      						color: '#ffd700'
                        sdetweil @RJDaPirate
                        @RJDaPirate
                        the code looks up the color using the url as a key…
                        all of your urls are the same so you will get results based on the url, where the name is stored last. M is higher than any other string, so the url will match that in the hash lookup
                          RJDaPirate @sdetweil
                          @sdetweil I deleted the personal settings within the urls. They are all different in the real config.js file.
                            @RJDaPirate the code does this
                            if (this.config.colored && !this.config.coloredSymbolOnly) {
                            				eventWrapper.style.cssText = "color:" + this.colorForUrl(event.url);
                            	colorForUrl: function (url) {
                            		return this.getCalendarProperty(url, "color", "#fff");
                              @sdetweil This is not visible in the config.js file. Earlier in the thread you instructed another user not the change settings in source instead of the config.js. Where are the setting you highlighted?
                                @RJDaPirate i am just showing the code that uses the settings from config.js… not changing it…
                                this.config.colored
                                u have colored: true, in config.js calendar config section
                                then it looks up color value by url…
                                if not found it return #fff as the color…
                                u have 6 digit color values…
                                  @sdetweil Understand you did not “edit”. Do not understand what I have done wrong? Cannot find examples of Calendar Module Config.js with seperate colors for different url (google) calendars. Is there a knowledge document you’d recommend I read thru that covers those config: { colored:…
                                    @RJDaPirate I wasn’t aware of color support myself til you mentioned it.
                                    the online doc is all I am aware of
                                      RJDaPirate
                                      @sdetweil , The lack of a “proper” symbol was my undoing.
                                        pastormingle
                                        how do you change the schedule time color and font? Mine seems to be gray even after sending the fade to false.
