    Convert bytes to megabytes - JSON
    8 Posts 3 Posters 2.2k Views 3 Watching
      mongo116 Module Developer @sdetweil
      @sdetweil Thanks for the reply.
      basically t.data[i].down_rate / 1024 for kilobytes
        sdetweil @mongo116
        @mongo116 right
          I figured this out in the end, with the help of google :) I used the JSON.parse() reviver function to take the down_rate and up_rate from the payload and divide it by 1024 (and again by 1024) to convert the bytes to megabytes. What confused me at first was I was trying to do this in the node_helper.js, which didn’t work. It needed to be in the socketNotificationReceived of the .js file.
                          var payload = JSON.parse(payload, function (key, value) {
                              if ( key === 'down_rate' ) {
                              return (value / 1024 / 1024).toFixed(2);
                              else if ( key === 'up_rate' ) {
                              else {
                              return value;
          I’m sure there is a proper way of doing this, but for my needs this is now working as needed.
            sdetweil @mongo116
            @mongo116 json data before parse is called is a text string, and math in string is bad.
            parse converts to number if possible
            then math works.
            number/(1024*1024)
            is parts of megabyte
              A Former User
              in MMM-Tools, i use this :
                convert: function(octet,FixTo) {
                  octet = Math.abs(parseInt(octet, 10));
                  var def = [[1, 'b'], [1024, 'Kb'], [1024*1024, 'Mb'], [1024*1024*1024, 'Gb'], [1024*1024*1024*1024, 'Tb']];
                  for (var i=0; i < def.length; i++) {
                    if (octet < def[i][0]) return (octet/def[i-1][0]).toFixed(FixTo)+def[i-1][1];
              Syntax:
              octet: octets to transform
              FixTo: precision of the result
              Fixto precision sample: if you set it to 2 result is : X.XX, if you set it to 3result is X.XXX
              Of course, Unit is automaticaly set ! b /Kb/Mb/Mb/Tb
              That’s to you to adapt if you want to use it ;)
                Thanks for the replies :thumbs_up_light_skin_tone:
                I’ve got the bytes string converting to a number, so that’s all good. Now the next question, @Bugsounet how do I use your function within the JSON.parse function?
                                    var num = Number(value);
                                    return (num/(1024*1024)).toFixed(2);
                Just to add, I had tried the following and receive a this.convert is not a function
                                    var downrate = this.convert(value,0);
                                    return downrate;
