    Is it possible to ad an Arduino?
    55 Posts 4 Posters 28.5k Views 4 Watching
      Shinji0912 @Shinji0912
        Shinji0912 @sdetweil
        @sdetweil Thats my Current Arduino code :
        volatile int32_t m_counter = 0;
        bool WasStarted = false;
        static const char *pcDHT11Prefix = "[sensor:DHT11:";
        static const char *pcPostfix = "]";
        void setup() {
          Serial.begin(9600);
          while(!Serial);
          Serial.println("[status:setup:starting]");
          Serial.println("[sensor:DHT11:11]");
          int test = 1;
          m_counter = test;
          if(test > 1) {
            WasStarted = false;
            Serial.println("[status:setup:failed]");
            return;
          delay(3000);
          WasStarted = true;
          Serial.println("[status:setup:started]");
          delay(100);
        void loop() {
          Serial.print(m_counter + 11);
          Serial.println(pcPostfix);
          if(m_counter % 3 == 0) {
            delay(1000);
            Serial.print(pcDHT11Prefix);
            delay(2000);
          if(m_counter >= 60) m_counter = 0;
          m_counter++;
          delay(1000);
        and i got the ArduPorts running on the MM itself
        now it is running but always searching for the module … see Picture.
        alt text
          sdetweil @Shinji0912
          @Shinji0912 and the config for the port ??
                          portname: "/dev/ttyUSB0",
          ls /dev | grep -i usb
          I don’t see a ttyUSB0 on my pi4…
          is that the right one on pi?
          i would guess that is for a USB plugin serial port, not direct serial port…
          I do have a /dev/serial1 (on all 3 of my pi devices, Pi0, Pi3, and Pi4)
            Shinji0912
            I have it plugged in on my Raspberyy Pi3 and the config on the Pi itself is
            	          module: 'MMM-ArduPort',
            	          position: 'bottom_right',
                          header: 'Arduino Sensors',
                            updateInterval: 1,
                            animationSpeed: 1000,
                            displayIcons: true,
                            showDescription: true,
                            hideLoading: false,
                            hideWaiting: false,
                            useColors: true,
                            sensors: [
                                    description: "Temperature",
                                    maxValue: 50,
                                    maxFormat: "({0}°C) VERY HIGH",
                                    highestValue: 30,
                                    highestFormat: "({0}°C) HIGH",
                                    highValue: 15,
                                    highFormat: "({0}°C) NORMAL",
                                    lowValue: 10,
                                    lowFormat: "({0}°C) LOW",
                                    lowestValue: 5,
                                    lowestFormat: "({0}°C) VERY LOW",
                                    minValue: 0,
                                    minFormat: "({0}°C) OK"
            and im not pretty sure what u want to tell me (im not an native english speaker) i come from germany
              @Shinji0912 said in Is it possible to ad an Arduino?:
              I think that is the wrong device name for the serial port on the pi. if you are using the gpio header pins
              Ich denke, das ist der falsche Gerätename für die serielle Schnittstelle auf dem Pi. wenn Sie die GPIO-Header-Pins verwenden
                @sdetweil Im not using the Gpio header pins i have the Arduino connected to the Pi using usb?
                  @Shinji0912 i have never seen arduino connected via USB… none of my arduino devices have USB plugs
                  did u check the available device names on your pi?
                  from a terminal window do
                    @sdetweil https://www.conrad.de/de/p/arduino-ag-usb-2-0-anschlusskabel-1x-usb-2-0-stecker-a-1x-usb-2-0-stecker-b-1-80-m-schwarz-95068.html?hk=SEM&WT.srch=1&WT.mc_id=google_pla&s_kwcid=AL!222!3!418522360024!!!g!!&ef_id=CjwKCAjwkoz7BRBPEiwAeKw3qy_SdRSLbXPZvYvpwSlJoKKFL-pjesNMeK_-wcbD8RJ4kJ7A1uo9ghoCmeUQAvD_BwE%3AG%3As&gclid=CjwKCAjwkoz7BRBPEiwAeKw3qy_SdRSLbXPZvYvpwSlJoKKFL-pjesNMeK_-wcbD8RJ4kJ7A1uo9ghoCmeUQAvD_BwE
                      @Shinji0912 this is my arduino experience
                      https://www.antratek.com/nodemcu-v2-lua-based-esp8266-development-kit
                        @sdetweil Oh ok , the school told us to buy the Uno R3 and it’s the first one i’ve used so far ^^
                          Shinji0912
                          @sdetweil alt text
                            @Shinji0912 don’t see ttyUSB0
                            are there any message on the console where u start mm? npm start? or pm2 logs --lines=???
                            ??? is a number, default is 15
                              @sdetweil Not as far as i can see.
                                @Shinji0912 so, I would use the linked examples outside mm to make sure it works
                                  @sdetweil Ok so i have installed Serialport on the Pi and told the arduino to digitalwrite 10 but how to i let the Pi read 10?
                                    @Shinji0912 Google , there are many examples
                                      @sdetweil , @wishmaster270
                                      Ok , so now i got the Arduino to communicate with the PI via usb, (i got the right Portname using NodeRed). This is the current Arduino Script :
                                      #include <Wire.h>
                                      #include "DHT.h"
                                      #define DHTPIN 2
                                      #define DHTTYPE 11
                                      DHT dht (DHTPIN, DHTTYPE);
                                      void setup()
                                        Wire.begin();
                                        Serial.begin(9600);
                                        dht.begin();
                                      void loop()
                                        delay(2000);
                                        float temp = dht.readTemperature();
                                        float rel_hum = dht.readHumidity();
                                        if (isnan(rel_hum) || isnan(temp)) {
                                          Serial.println(F("Daten vom Sensor konnten nicht gelesen werden!"));
                                          return;
                                        float hif = dht.computeHeatIndex(rel_hum);
                                        float hic = dht.computeHeatIndex(temp, rel_hum, false);
                                        Serial.print(F("Luftfeuchtigkeit: "));
                                        Serial.print(rel_hum);
                                        Serial.print(F("%  Temperatur: "));
                                        Serial.print(temp);
                                        Serial.print(F("°C "));
                                        Serial.println(F(""));
                                      Some things are in german so dont be suprised ^^
                                      and via NodeRed i know that it is working and the Pi is currently reading the data.
                                      alt text
                                      My issue now is that my Config.js isn’t working anymore after installing ArduPorts ??
                                      alt text
                                      This is the current config :
                                      /* Magic Mirror Config Sample
                                       * By Michael Teeuw https://michaelteeuw.nl
                                       * MIT Licensed.
                                      var config = {
                                      	address: "localhost", 	// Address to listen on, can be:
                                      	port: 8080,
                                      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                                      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                                      	language: "de",
                                      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                                      	timeFormat: 24,
                                      	units: "metric",
                                      		position: "bottom_right",
                                      		portname: "/dev/ttyACM0",
                                      		updateInterval: 2,
                                      		displayIcons: ture,
                                      		useColors: true,
                                      	sensors: [ {
                                      	description: "Temperatur",
                                      		module: 'MMM-TelegramBot',
                                      			telegramAPIKey: '',
                                      			allowedUser: [''],
                                      			adminChatId: ''
                                      			module: "MMM-Online-State",
                                      			module: "updatenotification",
                                      			position: "bottom_bar"
                                      			module: "clock",
                                      			position: "top_right"
                                                  module: 'MMM-RBB-Weather',
                                                  position: "top_left", // All available positions
                                                               days: "0",
                                                               updateInterval: "600",
                                      			header: "Events",
                                      						symbol: "calendar-check-o ",
                                      						url: "",
                                      						maximumEntries: "5",
                                      						maximumNumberOfDays: "7"
                                        module: "MMM-NowPlayingOnSpotify",
                                        position: "bottom_left",
                                          showCoverArt: false,
                                          clientID: "",
                                          clientSecret: "",
                                          accessToken: "",
                                          refreshToken: ""
                                      alt text
                                      i don’t know what to do now :C i thought i had it working this time finally …
                                      EDIT :
                                      Found the mistake i’ve written “ture” not “true” fml…
                                      EDIT 2 :
                                      But it’s still not working as i want it to it still says :“Waiting for Connection” on the Arduport module when launching the MagicMirror.
                                        @Shinji0912 and u did the npm install in the arduport module folder?
                                          @sdetweil yes i did .-.
                                            @Shinji0912 ok, need to see the console logs
                                            from nom start or pm2 logs
                                            and the developers window ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors.
                                            u can also filter messages by.module, by adding part.of the module name to the filter field, ardu for example
