    help! npm start error: Failed at the start script 'electron js/electron.js'.
    6 Posts 4 Posters 6.8k Views 5 Watching
    • E Offline
      evergreen
      magicmirror@2.0.0 start /home/pi/MagicMirror
      fs.js:640
      return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      Error: ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/node_modules/electron/path.txt’
      at Error (native)
      at Object.fs.openSync (fs.js:640:18)
      at Object.fs.readFileSync (fs.js:508:33)
      at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:4:42)
      at Module._compile (module.js:570:32)
      at Object.Module._extensions…js (module.js:579:10)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3)
      at Module.require (module.js:497:17)
      npm ERR! Linux 4.4.21-v7+
      npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
      npm ERR! node v6.9.1
      npm ERR! npm v3.10.8
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.0.0 start: electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! electron js/electron.js
      npm ERR! npm bugs magicmirror
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls magicmirror
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      how can i fix this?
        msheen
        I’ve got exactly the same problem …
        Anybody got any idea’s ?
        I’ve googled it there seems a few people with the problem but no answers
        Any help would be appreciated.
        • T Offline
          tajno
          Did you tried “npm install electron”?
            msheen
            Tajno - just tried that now - got this message
            npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
            No idea what means …
            and when I tried to start magic mirror got this :
            npm ERR! Linux 4.4.32-v7+
            npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
            npm ERR!
            Thanks for your suggestions - got any more idea’s ? as I’d really like to this working
            • T Offline
              tajno
              Sounds that now grunt is not installed…
              Try:
              npm install -g grunt
              after them again npm install -g electron
              Btw. how did you install the mirror? By yourself or with the suggested curl command?
                Sintei @tajno
                @tajno ,
                Had the same problem.
                Installed and reinstalled several times, manually and with the automated script.
                It looked to me it was a problem installing grunt and electron.
                I had to install them with sudo.
                Still did not work, but when I renamed the magicmirror folder and “reinstalled” magicmirror using curl command with sudo, it worked.
                Some privileges problem maybe somewhere?
