help! npm start error: Failed at the start script 'electron js/electron.js'.
6 Posts 4 Posters 6.2k Views 5 Watching
  • E Offline
    evergreen
    magicmirror@2.0.0 start /home/pi/MagicMirror
    fs.js:640
    return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
    Error: ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/node_modules/electron/path.txt’
    at Error (native)
    at Object.fs.openSync (fs.js:640:18)
    at Object.fs.readFileSync (fs.js:508:33)
    at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:4:42)
    at Module._compile (module.js:570:32)
    at Object.Module._extensions…js (module.js:579:10)
    at Module.load (module.js:487:32)
    at tryModuleLoad (module.js:446:12)
    at Function.Module._load (module.js:438:3)
    at Module.require (module.js:497:17)
    npm ERR! Linux 4.4.21-v7+
    npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
    npm ERR! node v6.9.1
    npm ERR! npm v3.10.8
    npm ERR! code ELIFECYCLE
    npm ERR! magicmirror@2.0.0 start: electron js/electron.js
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
    npm ERR! If you do, this is most likely a problem with the magicmirror package,
    npm ERR! not with npm itself.
    npm ERR! electron js/electron.js
    npm ERR! npm bugs magicmirror
    npm ERR! Or if that isn’t available, you can get their info via:
    npm ERR! npm owner ls magicmirror
    npm ERR! /home/pi/MagicMirror/npm-debug.log
    how can i fix this?
      msheen
      I’ve got exactly the same problem …
      Anybody got any idea’s ?
      I’ve googled it there seems a few people with the problem but no answers
      Any help would be appreciated.
      • T Offline
        tajno
        Did you tried “npm install electron”?
          msheen
          Tajno - just tried that now - got this message
          npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
          No idea what means …
          and when I tried to start magic mirror got this :
          npm ERR! Linux 4.4.32-v7+
          npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
          npm ERR!
          Thanks for your suggestions - got any more idea’s ? as I’d really like to this working
          • T Offline
            tajno
            Sounds that now grunt is not installed…
            Try:
            npm install -g grunt
            after them again npm install -g electron
            Btw. how did you install the mirror? By yourself or with the suggested curl command?
            S 1 Reply Last reply Nov 21, 2016, 7:19 AM Reply Quote 0
              Sintei @tajno
              @tajno ,
              Had the same problem.
              Installed and reinstalled several times, manually and with the automated script.
              It looked to me it was a problem installing grunt and electron.
              I had to install them with sudo.
              Still did not work, but when I renamed the magicmirror folder and “reinstalled” magicmirror using curl command with sudo, it worked.
              Some privileges problem maybe somewhere?
