    MMM-Spotify
    249 Posts 51 Posters 341.4k Views 54 Watching
      raf
      hi all
      I have installed spotify but can only play the sound on my smartphone and my google nest mini, how can I play the sound through the speakers of the raspberry pi
      spotify does appear in the MagicMirror
        sdetweil @raf
        @raf Spotify requires a supporting player.
        librespot or raspotify
        note these are both installed in the base system outside mm.
        once u install and start them, you should see the pi device in your phone app Spotify player to transfer play to.
        I have installed the Spotify Connect app.on windows and my desktop linux, and can play on my pi, and see what is playing on mm
          raf @sdetweil
          its only for premium users ?
            sdetweil @raf
            @raf I think so
            • L Offline
              Lauren0612
              @Sean said in MMM-Spotify:
              MMM-Spotify
              Where is this module? I cant find it on the magic mirror module list anymore :(
                sdetweil @Lauren0612
                @Lauren0612 bugsounet has removed his modules.
                  A Former User
                  open again (temporarily)
                  • L Offline
                    Lauren0612 @Guest
                    @Bugsounet noooo please come back 😥😥
                      A Former User
                      MMM-Spotify works now :)
                      I have open it
                      L A 2 Replies Last reply Reply Quote 0
                      • L Offline
                        Lauren0612 @Guest
                        @Bugsounet if i put it on my rasberry pi and you take away the module again I’m assuming it won’t work anymore? Sorry I’m new to rasberry pi and still trying to figure everything out 😩
                          A Former User
                          don’t cry :)
                          You know i will not stop coding … I prefer make good thing and take time …
                          in All case, actually i have not many time … (changing job and location)
                          So i prefer make on line my modules rather than make you wait a long time !
                          but in the long run i will make my own mirror system (it’s planned!)
                          • L Offline
                            Lauren0612 @Guest
                            @Bugsounet good luck in your new job!
                              A Former User
                              Thx, i start it in 15 days !
                              So imagine, i have not many time for coding !
                              and besides what I tell you the internet connection will be really but really not great …
                              (maybe LTE altenative needed … i think)
                                Andresleonsalas @Guest
                                @Bugsounet Thanks a lot! Your modules are GREAT!
                                • L Offline
                                  lotman9000
                                  Hey guys,
                                  I recently discovered this module and love it! Unfortunately, I can’t manage to enable the volume control via notifications. While other notifications such as “SPOTIFY_SHUFFLE” or “SPOTIFY_TOGGLE” work, “SPOTIFY_VOLUME_UP” or “_DOWN” won’t.
                                  I am using a usb macro pad as input device (mapped to numeric keys 1-10) with MMM-Keybindings. The following settings are a minimal working example from my config.js:
                                  			module: "alert",
                                              		module: "MMM-KeyBindings",
                                  				enableKeyboard: true,
                                  				handleKeys: ['1', '2', '3', '4', '5', '6', '7', '8', '9', '10'],
                                  				actions: [
                                  						key: "1",
                                  						notification: "SPOTIFY_SHUFFLE"
                                  						key: "2",
                                  						notification: "SPOTIFY_VOLUME_DOWN"
                                    		module: "MMM-Spotify",
                                    		position: "bottom_left",
                                  			volumeSteps: 5,
                                  			debug: false,
                                  			control: "hidden"
                                  I also realized that the module is not receiving the current volume from my devices but is rather stuck at 100%.
                                  Is there anyone who might have an idea of how to fix this problem? Thank you so much in advance!
                                    Abstr @requiemmg
                                    @requiemmg
                                    Hey Requiemmg, I’m dealing with the exact same problem, so im very curious if you managed to fix the problem? thnx!
                                      sdetweil @Abstr
                                      @Abstr install the spotify connect app on your pc. it will.let u control spotify on the pi. install raspotify or librespot on the pi. spotify connect will.let u make sure spotify is working. i think.u can control the player volume from the connevt app
                                      https://www.spotify.com/us/connect/
                                        Abstr @requiemmg
                                        @requiemmg , @sdetweil Thanks for the quick reply. Volume is working fine, but switching between 2 different “Client Id’s” isnt working. The MagicMirror only shows the accountdefault: 0. This means first device is working fine, but it isnt possible to switch to another device.
                                          sdetweil @Abstr
                                          @Abstr device or account.
                                          each system is one device. far as i know spotify bequires logoff/logon to switch
                                          accounts. even family is multiple users under one payment plan
                                          again verify how it works with the connect app. has nothing to do with mm
                                          S A 2 Replies Last reply Reply Quote 0
                                            @sdetweil verify w the connect app
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
