    [MMM-Roomba980] - Live Roomba Stats
    12 Posts 4 Posters 7.1k Views 4 Watching
      djsunrise19
      Cool :). Seems to be compatible with more than one romba(980)?!
      Compatible robots: all 800 and 900 series with HOME app.
        relm923 @joseska
        @joseska Looks like that should work. Let me know if I can help
          relm923 @djsunrise19
          @djsunrise19 Good catch! I renamed the repo/package to MMM-Roomba to reflect the compatibility. The old links should still continue to work
            joseska @relm923
            @relm923 Thanks… my nodejs coding is very bad.
            I´m trying with MIIO API for xiaomi vaccum data but sometimes work and others not work…
            I´m trying…
            thanks…
              joseska @relm923
              @relm923
              Hey… Can you help me… the module always is “LOADING”.
              for Now the data is trought json url because miio not work property. JSON work well, but the module always is “LOADING”. not work
              the url of the module is: https://github.com/joseska/MMM-Xiaomi-Vacuum
              sorry, is a copy-paste of your module, for now I have not been able to put the credits on github…
              thanks…
              R 1 Reply Last reply Reply Quote -1
                relm923 @joseska
                @joseska I’m not familiar with the Miio/Xiaomi API.
                Are you seeing data returned from the raw HTTP request (looks like you’re logging some)? If you are, you’ll need to call self.sendSocketNotification('STATS', self.stats); after updating self.stats to tell your module to update. Unfortunately I can’t test anything since I don’t have a Xiaomi.
                You may want to look at using https://github.com/aholstenson/miio too.
                  joseska @relm923
                    joseska @relm923
                    @relm923 Hi… WORK… ;)
                    the error was that I rename renderPhase function to renderPhase2. (Novice)
                    I need to change some things still and use miio to get vacuum data, but for now WORK…
                    When use miio to get data I upload to github and publish here If you give me permission to use your module as the base of mine…
                    thanks for your time…
                      relm923 @joseska
                      @joseska Nice work! Feel free to use my module how ever you want
                        Baschti
                        I got the whole time only “loading” on my screen! I Installed Dorita980 und the module! Did you have some hints?
