    MMM-bergfex not working
    mmm-bergfexbergfexsnow
    38 Posts 5 Posters 20.8k Views 5 Watching
      MajorC Project Sponsor
      I tried to install the MMM-bergfex following the instructions of the readme file on GitHub.
      Also, I include the example config.
      https://github.com/nebulx29/MMM-bergfex
      But now I only get a complete black screen with the mouse visible. All my modules that where working before are not shown anymore?
      Any suggestions how to troubleshoot this? Is @nebulx29 still around?
        sdetweil @MajorC
        @MajorC black screen, do this
        open the developers console, ctrl-shift-i on the mirror keyboard
        select the console tab
        and scroll up to see any errors, usually red text
        u can also filter messages for specific modules by putting part of the module name in the filter field, ‘berg’ for example here
          I can open the developers console without mmm-bergfex in the config and will see a couple of entries, no errors.
          As soon as I include mmm-bergfex in the config, the developers console says: DevTool was disconnected from the page. Once page is reloaded, DevTools will automatically reconnect.
            sdetweil @MajorC
            @MajorC ok, look in the window where you start MM, npm start or pm2 ,
            if pm2 the pm2 logs --lines=???
            where ??? is a number, 15 is the default
            to get to the window if MM is showing, alt-spacebar, n
              /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
              0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-bergfex/node_helper.js:11:13)
              0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:786:30)
              0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
              0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:645:32) {
              0|MagicMir |   code: 'MODULE_NOT_FOUND',
              0|MagicMir |   requireStack: [
              0|MagicMir |     '/home/pi/MagicMirror/modules/MMM-bergfex/node_helper.js',
              0|MagicMir |     '/home/pi/MagicMirror/js/app.js',
              0|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
              0|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
              0|MagicMir |     undefined
              0|MagicMir |   ]
              0|MagicMir | }
              0|MagicMir | [2020-09-27 17:30:56.629] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|MagicMir | [2020-09-27 17:30:56.630] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                sdetweil @MajorC
                @MajorC looks like you didn’t do the npm install in the module folder after cloning
                  MajorC Project Sponsor @sdetweil
                  pi@MagicMirror:~/MagicMirror/modules/MMM-bergfex $ npm install cheerio
                  npm WARN MMM-bergfex@ license should be a valid SPDX license expression
                  + cheerio@1.0.0-rc.3
                  updated 1 package and audited 65 packages in 5.877s
                  2 packages are looking for funding
                    run `npm fund` for details
                  found 0 vulnerabilities
                  audited 65 packages in 2.257s
                  I just did it again, but I am quite sure I already did it before.
                    sdetweil @MajorC
                    @MajorC sadly he didn’t update package.json with all the required modules
                    do
                    npm install async --save
                    npm install sys – save
                    his code
                    var async = require('async');
                    var sys = require('sys');
                    var exec = require('child_process').exec;
                    const request = require('request');
                    const cheerio = require("cheerio");
                      @sdetweil said in MMM-bergfex not working:
                      in the MMM-bergfex folder?
                        sdetweil @MajorC
                        @MajorC of course
                          sorry, I am totaly new to this world, my first Raspberry project.
                          pi@MagicMirror:~/MagicMirror/modules/MMM-bergfex $ npm install async --save
                          + async@3.2.0
                          added 1 package from 1 contributor and audited 66 packages in 2.709s
                          pi@MagicMirror:~/MagicMirror/modules/MMM-bergfex $ npm install sys -- save
                          + sys@0.0.1
                          + save@2.4.0
                          added 13 packages from 11 contributors and audited 79 packages in 8.763s
                            sdetweil @MajorC
                            @MajorC and then start mm
                              well, I have my mirror back, including Bergfex Snow Report. At the moment there is only “loading…” visible.
                              I will double check my config.
                              Maybe you can include the help to the git? Would be nice to have it working as smooth as the rest in this wonderful project.
                                sdetweil @MajorC
                                @MajorC he hasn’t updated in 2 years… so unlikely
                                  And it is working.
                                  This is important:
                                  This is an array with strings of the skiareas to display. String must exactly match the name on http://www.bergfex.at/oesterreich/schneewerte/
                                    sdetweil @MajorC
                                    @MajorC yes, precise config is required in each module. some don’t document well…
                                      Thanks for your very fast help. Maybe someone will rewrite this MMM. Winter is coming!
                                        Suboshi
                                        Hi ,
                                        sorry for bringing this up again. I also have the bergfex “loading…” issue. However, in the logs I can see the values are retrieved. They just don’t show in the mirror:
                                        0|mm     | 83 snow reports from bergfex.at retrieved.
                                        0|mm     | [2020-11-12 21:40:29.367] [LOG]    searching for Koralpe
                                        0|mm     | [2020-11-12 21:40:29.369] [LOG]    searching for Hintertuxer Gletscher / Hintertux
                                        0|mm     | [2020-11-12 21:40:29.370] [LOG]    searching for Ischgl
                                        0|mm     | [2020-11-12 21:40:29.373] [LOG]    searching for Obergurgl - Hochgurgl
                                        0|mm     | [2020-11-12 21:40:29.375] [LOG]    searching for Seefeld/Rosshütte
                                        0|mm     | [2020-11-12 21:40:29.376] [LOG]    searching for Sölden
                                        0|mm     | [2020-11-12 21:40:29.377] [LOG]    searching for Stubaier Gletscher / Stubaital
                                        0|mm     | [
                                        0|mm     |   null,
                                        0|mm     |   {
                                        0|mm     |     skiarea: 'Hintertuxer Gletscher / Hintertux',
                                        0|mm     |     tal: '-',
                                        0|mm     |     berg: '135 cm',
                                        0|mm     |     neu: '-',
                                        0|mm     |     lifte: '0',
                                        0|mm     |     update: ''
                                        0|mm     |   },
                                        0|mm     |   {
                                        0|mm     |     skiarea: 'Ischgl',
                                        0|mm     |     tal: '-',
                                        0|mm     |     berg: '20 cm',
                                        0|mm     |     neu: '-',
                                        0|mm     |     lifte: '0',
                                        0|mm     |     update: ''
                                        0|mm     |   },
                                        0|mm     |   {
                                        0|mm     |     skiarea: 'Obergurgl - Hochgurgl',
                                        0|mm     |     tal: '-',
                                        0|mm     |     berg: '75 cm',
                                        0|mm     |     neu: '-',
                                        0|mm     |     lifte: '0',
                                        0|mm     |     update: ''
                                        0|mm     |   },
                                        0|mm     |   null,
                                        0|mm     |   {
                                        0|mm     |     skiarea: 'Sölden',
                                        0|mm     |     tal: '19 cm',
                                        0|mm     |     berg: '72 cm',
                                        0|mm     |     neu: '-',
                                        0|mm     |     lifte: '0',
                                        0|mm     |     update: ''
                                        0|mm     |   },
                                        0|mm     |   {
                                        0|mm     |     skiarea: 'Stubaier Gletscher / Stubaital',
                                        0|mm     |     tal: '35 cm',
                                        0|mm     |     berg: '110 cm',
                                        0|mm     |     neu: '-',
                                        0|mm     |     lifte: '0',
                                        0|mm     |     update: ''
                                        0|mm     |   }
                                        0|mm     | ]
                                        So the names of the resorts seem to be correct.
                                        Any ideas on this one?
                                        thanks
                                        Chris
                                          Suboshi
                                          Argh… just 2 minutes after posting I found the issue:
                                          I had 2 values “Koralpe” and “Seefeld/Rosshütte”, which were displayed in the log as NULL. Removing these entries made bergfex work…
                                          Again, it was a typo ;)
                                          thanks
                                          Chris
                                          • F Offline
                                            FatTony123
                                            Hi all,
                                            I’ve created a fork and did some updates to the code and config.
                                            You can now select the country where bergfex should choose the values from.
                                            Feel free to test and let me know any feedback.
                                            So far I can show multiple countries and their values…
                                            M 2 Replies Last reply Reply Quote 1
