    MMM-bergfex not working
    mmm-bergfexbergfexsnow
    38 Posts 5 Posters 16.6k Views 5 Watching
      MajorC Project Sponsor
      I tried to install the MMM-bergfex following the instructions of the readme file on GitHub.
      Also, I include the example config.
      https://github.com/nebulx29/MMM-bergfex
      But now I only get a complete black screen with the mouse visible. All my modules that where working before are not shown anymore?
      Any suggestions how to troubleshoot this? Is @nebulx29 still around?
        sdetweil @MajorC
        @MajorC black screen, do this
        open the developers console, ctrl-shift-i on the mirror keyboard
        select the console tab
        and scroll up to see any errors, usually red text
        u can also filter messages for specific modules by putting part of the module name in the filter field, ‘berg’ for example here
          I can open the developers console without mmm-bergfex in the config and will see a couple of entries, no errors.
          As soon as I include mmm-bergfex in the config, the developers console says: DevTool was disconnected from the page. Once page is reloaded, DevTools will automatically reconnect.
            sdetweil @MajorC
            @MajorC ok, look in the window where you start MM, npm start or pm2 ,
            if pm2 the pm2 logs --lines=???
            where ??? is a number, 15 is the default
            to get to the window if MM is showing, alt-spacebar, n
              /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
              0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-bergfex/node_helper.js:11:13)
              0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:786:30)
              0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
              0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:645:32) {
              0|MagicMir |   code: 'MODULE_NOT_FOUND',
              0|MagicMir |   requireStack: [
              0|MagicMir |     '/home/pi/MagicMirror/modules/MMM-bergfex/node_helper.js',
              0|MagicMir |     '/home/pi/MagicMirror/js/app.js',
              0|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
              0|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
              0|MagicMir |     undefined
              0|MagicMir |   ]
              0|MagicMir | }
              0|MagicMir | [2020-09-27 17:30:56.629] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|MagicMir | [2020-09-27 17:30:56.630] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                sdetweil @MajorC
                @MajorC looks like you didn’t do the npm install in the module folder after cloning
                  MajorC Project Sponsor @sdetweil
                  pi@MagicMirror:~/MagicMirror/modules/MMM-bergfex $ npm install cheerio
                  npm WARN MMM-bergfex@ license should be a valid SPDX license expression
                  + cheerio@1.0.0-rc.3
                  updated 1 package and audited 65 packages in 5.877s
                  2 packages are looking for funding
                    run `npm fund` for details
                  found 0 vulnerabilities
                  audited 65 packages in 2.257s
                  I just did it again, but I am quite sure I already did it before.
                    sdetweil @MajorC
                    @MajorC sadly he didn’t update package.json with all the required modules
                    do
                    npm install async --save
                    npm install sys – save
                    his code
                    var async = require('async');
                    var sys = require('sys');
                    var exec = require('child_process').exec;
                    const request = require('request');
                    const cheerio = require("cheerio");
                      @sdetweil said in MMM-bergfex not working:
                      in the MMM-bergfex folder?
                        sdetweil @MajorC
                        @MajorC of course
                        • 1 / 4
