    MMM-MQTTbridge
    Scheduled Pinned Locked Moved Unsolved System
    44 Posts 14 Posters 26.1k Views 15 Watching
    • SergeS
      Serge @shinebright
      @shinebright what you had changed? Could you tell soi can add it as an option for the next releases
      • F
        fribse
        Hi @Serge
        I’ve finally received the mirror itself, so now the MagicMirror is finally getting finished.
        One of the things was to update the MM itself, as well as a few modules (screencast).
        After doing that, I don’t see any mqtt status messages going out, and it doesn’t react on incoming either.
        I’ve checked the username/password, still correct, and the IP hasn’t changed either?
        SergeS 1 Reply Last reply Reply Quote 0
        • SergeS
          Serge @fribse
          • SergeS
            Serge
            Version 1.1 released https://github.com/sergge1/MMM-MQTTbridge
            Code updated with the help of community members.
            Now,
            • mqtt topics introduced into mqttDictionary. This allows now:
              – Subscribe to that specific topic from the mqttDictionary.
              – now you can specify different behavior for the same payload from different topics,
              e.g. if you got the mqttPayload “20” at “kitchen/temperature” topic and at “kitchen/humiduty” topic - different Command could be executed (before module recognized only payload for all the topics subscribed);
            • Now, if notiPayload or mqttPayload are not specified within mqttDictionary or notiDictionary, the respective payload from mqtt or noti will be sent as payload for noti or mqtt.
              E.g. if MM receives the mqtt message at “kitchen/temperature” with payload “20”, and mqttDictionary does not have specified payload at all - the “20” will go as payload for issued Noti.
            • All errors of several mqtt connections disappear;
            • mqttBridgeFormatOnly - not used anymore;
            • Changed mqttDictionary according to notiDictionary. Subscription to topic only once
            Please do not forget to change the config section and mqttDictionary accroding to the new structure.
            • cowboysdudeC
              This is really needed and very nice!! Thank you!
                majdzik84
                Stupid novice question. How can I update the module? :) I have to remove the old one and upload the new one, is there any command to update the already uploaded module?
                  sdetweil @majdzik84
                  @majdzik84 upload? internet is upload, local computer is download
                  to update a module locally, you go to that module folder and do a git pull
                  sometimes you also need to do npm install again, but I would try first without it
                  • K
                    KSumwalt
                    I installed the module on Aug 18, 2020 and have it connecting to my broker. Either I have something off or the module always sends out the notification’s payload and I cannot over-ride such. My notiDictionary.js file looks like this:
                    var notiHook = [
                        notiId: "USERS_LOGIN",
                        notiPayload: [
                            payloadValue: '',
                            notiMqttCmd: ["Command 1"]
                        notiId: "SHOW_ALERT",
                        notiPayload: [
                            payloadValue: '',
                            notiMqttCmd: ["Command 2"]
                        notiId: "NEWS_FEED",
                        notiPayload: [
                            payloadValue: '',
                            notiMqttCmd: ["Command 3"]
                    var notiMqttCommands = [
                        commandId: "Command 1",
                        mqttTopic: "mirror/profile",
                        mqttMsgPayload: 'george'
                     //    mqttMsgPayload: '{state:"OFF"}'
                        commandId: "Command 2",
                        mqttTopic: "mirror/alert/set",
                        mqttMsgPayload: 'on'
                        commandId: "Command 3",
                        mqttTopic: "mirror/alert/test",
                        mqttMsgPayload: 'go'
                    module.exports = { notiHook, notiMqttCommands };
                    When an alert is shown, the SHOW_ALERT send an MQTT Topic of mirror/alert/set but the payload according to MQTT Snooper and my HomeSeer system is [object Object]. I expected it to be a string of on. NEWS_FEED does noth8ing, as expected from the config. USERS_LOGIN is from the MMM-Face-Reco-DNN module. It has a string value of the person who’s face it recognizes. When it recognizes me, the payload for the MQTT topic is Karl both when I have no value and when I have George in the payload setting as shown above.
                    This is how I have the module configured in the config.js file:
                    			module: 'MMM-MQTTbridge',
                    //			disabled: false,
                    				mqttServer: "mqtt://192.168.1.2:1883",
                    				mqttConfig:
                    					listenMqtt: true,
                    					interval: 300000,
                    				notiConfig:
                    					listenNoti: true,
                    					ignoreNotiId: ["CLOCK_MINUTE", "NEWS_FEED"],
                    					ignoreNotiSender: ["system", "NEWS_FEED"],
                    				// set "NOTIFICATIONS -> MQTT" dictionary at /dict/notiDictionary.js
                    				// set "MQTT -> NOTIFICATIONS" dictionary at /dict/mqttDictionary.js
                    What might I be doing wrong?
                    Note that for an IP address and no username/password I had to set the server to mqttServer: “mqtt://192.168.1.2:1883”, dropping the colon (:) prior to the IP address. I had it in there based on the provided settings for the localhost version.
                    SergeS 3 Replies Last reply Reply Quote 0
                    • SergeS
                      Serge @KSumwalt
                        Mrtrol2013
                        Can I use this module to manage MMM-pages?
                        • SergeS
                          Serge @KSumwalt
                          @KSumwalt
                          the module is working. try to reinstall it and check the configuration once more.
                          Here is the community member says that he uses module perfectly https://forum.magicmirror.builders/topic/13726/mmm-ledstripcontrol-control-a-led-strip-with-optional-pong-game-support
                          @Mrtrol2013 said in MMM-MQTTbridge:
                          Yes.
                          See
                          • that part of MMM-pages’s readme here https://github.com/edward-shen/MMM-pages#regarding-notifications and
                          • that part of MMM-MQTTbridge’s readme here https://github.com/sergge1/MMM-MQTTbridge#mqtt-to-notifications-dictionary-section
                          • SergeS
                            Serge @KSumwalt
                            @KSumwalt please update the module and try once more. If the problem will exist, send here your logs
                            • F
                              fribse
                              • Cr4z33C
                                Cr4z33
                                I’ve got a BTicino F20T60A power consumption meter connected by MQTT so can someone please help me to show power usage only on MagicMirror by using this MM module?
                                Feel free to ask me MQTT / Home Assistant details to provide (as I don’t know right now what you need 😅)!
                                • wishmaster270W
                                  wishmaster270 Module Developer @Cr4z33
                                  @Cr4z33 Hi, I am working on a module which will be called MMM-ValuesByNotification (https://github.com/Tom-Hirschberger/MMM-ValuesByNotification) and will perfectly fit your needs.
                                  If the payload of the notification is a valid json string the values can be selected with the JsonPath syntax.
                                  If needed the values can be reformatted.
                                  I am using it to display the temperature and humidity of different sensors in my house and the level of my watertank.
                                  Screenshot
                                  The module is functional already but not documented yet. The configuration can be a little bit tricky but I am planning to add a lot of examples to the readme in the next weeks.
                                  Cr4z33C 1 Reply Last reply Reply Quote 2
                                  • Cr4z33C
                                    Cr4z33 @wishmaster270
                                    @wishmaster270 that’s great news I’ve added your repo and will wait then for the instructions once they come out.
                                    • wishmaster270W
                                      wishmaster270 Module Developer @Serge
                                      @Serge Hi,
                                      as i am unable to modify the first post to announce new release i will start a new thread. Maybe you can link to it in the first post.
                                      • SergeS
                                        Serge @wishmaster270
                                        @wishmaster270 done.
                                        • 2 / 3
