    MMM-awesome-alexa
    241 Posts 43 Posters 461.1k Views 47 Watching
    • G
      Ghost2000
      it works with your settings.
      http: // localhost: 3000 /? code = ANMcPyM …
      DANKE DANKE DANKE DANKE DANKE ! LOVE YOU!
      • G
        Ghost2000
        > magicmirror@2.13.0 config:check /home/pi/MagicMirror
        > node js/check_config.js
        [2020-10-10 00:52:40.394] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
        [2020-10-10 00:52:40.490] [INFO]   Your configuration file doesn't contain syntax errors :)
        Screen black… no Error
        G 1 Reply Last reply
        • G
          Ghost2000 @Ghost2000
          @Ghost2000 said in MMM-awesome-alexa:
          pi@MagicMirror:~ $ cd ~/MagicMirror/
          pi@MagicMirror:~/MagicMirror $ pm2 log mm
          [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
          0|mm       |     at Module._compile (internal/modules/cjs/loader.js:786:30)
          0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
          0|mm       |     at Module.load (internal/modules/cjs/loader.js:645:32) {
          0|mm       |   code: 'MODULE_NOT_FOUND',
          0|mm       |   requireStack: [
          0|mm       |     '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js',
          0|mm       |     '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js',
          0|mm       |     '/home/pi/MagicMirror/js/app.js',
          0|mm       |     '/home/pi/MagicMirror/js/electron.js',
          0|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
          0|mm       |     undefined
          0|mm       |   ]
          0|mm       | }
          0|mm       | [2020-10-10 00:55:35.178] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|mm       | [2020-10-10 00:55:35.178] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          0|mm       | [2020-10-10 00:55:34.267] [LOG]    Initializing new module helper ...
          0|mm       | [2020-10-10 00:55:34.268] [LOG]    Module helper loaded: mmpm
          0|mm       | [2020-10-10 00:55:34.304] [LOG]    Initializing new module helper ...
          0|mm       | [2020-10-10 00:55:34.305] [LOG]    Module helper loaded: updatenotification
          0|mm       | [2020-10-10 00:55:34.306] [LOG]    No helper found for module: MMM-Carousel.
          0|mm       | [2020-10-10 00:55:34.306] [LOG]    No helper found for module: clock.
          0|mm       | [2020-10-10 00:55:35.154] [LOG]    Loading module helpers ...
          0|mm       | [2020-10-10 00:55:35.156] [LOG]    No helper found for module: alert.
          0|mm       | [2020-10-10 00:55:35.159] [LOG]    Initializing new module helper ...
          0|mm       | [2020-10-10 00:55:35.160] [LOG]    Module helper loaded: mmpm
          0|mm       | [2020-10-10 00:55:35.161] [LOG]    Initializing new module helper ...
          0|mm       | [2020-10-10 00:55:35.161] [LOG]    Module helper loaded: updatenotification
          0|mm       | [2020-10-10 00:55:35.162] [LOG]    No helper found for module: MMM-Carousel.
          0|mm       | [2020-10-10 00:55:35.163] [LOG]    No helper found for module: clock.
          0|mm       | [2020-10-10 00:55:35.253] [LOG]    Launching application.
            sdetweil @Ghost2000
            @Ghost2000 module not found, I am away for the rest of the evening
              I have a script that does the 14 install steps
              • G
                Ghost2000
                can you send me ?
                  sdetweil @Ghost2000
                  @Ghost2000 https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
                  • G
                    Ghost2000
                    Thx Good night
                    • G
                      Ghost2000
                      0|mm       |     at processTicksAndRejections (internal/process/task_queues.js:8        9:5)
                      0|mm       | [2020-10-10 01:57:43.816] [ERROR]  (node:15126) UnhandledPromiseRej        ectionWarning: Unhandled promise rejection. This error originated either by thro        wing inside of an async function without a catch block, or by rejecting a promis        e which was not handled with .catch(). (rejection id: 1)
                      0|mm       | [2020-10-10 01:57:43.819] [ERROR]  (node:15126) UnhandledPromiseRej        ectionWarning: Unhandled promise rejection. This error originated either by thro        wing inside of an async function without a catch block, or by rejecting a promis        e which was not handled with .catch(). (rejection id: 1)
                      0|mm       | [2020-10-10 01:57:43.820] [ERROR]  (node:15126) [DEP0018] Deprecati        onWarning: Unhandled promise rejections are deprecated. In the future, promise r        ejections that are not handled will terminate the Node.js process with a non-zer        o exit code.
                      0|mm       | [2020-10-10 01:57:43.823] [ERROR]  (node:15126) [DEP0018] Deprecati        onWarning: Unhandled promise rejections are deprecated. In the future, promise r        ejections that are not handled will terminate the Node.js process with a non-zer        o exit code.
                      0|mm       | [2020-10-10 01:57:44.478] [ERROR]  Calendar Error. Could not fetch        calendar:  https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/publ        ic/basic.ics 404: Not Found
                      0|mm       | [2020-10-10 02:00:07.079] [ERROR]  Calendar Error. Could not fetch        calendar:  https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/publ        ic/basic.ics 404: Not Found
                      0|mm       | [2020-10-10 02:00:07.387] [ERROR]  (node:15126) UnhandledPromiseRej        ectionWarning: Error: [object Object]
                      0|mm       |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.j        s:1:6073
                      0|mm       | [2020-10-10 02:00:07.388] [ERROR]  (node:15126) UnhandledPromiseRej        ectionWarning: Unhandled promise rejection. This error originated either by thro        wing inside of an async function without a catch block, or by rejecting a promis        e which was not handled with .catch(). (rejection id: 2)
                        sdetweil @Ghost2000
                        @Ghost2000 looks like a networking problem calendar catch fetch too
                        u ran the script?, do
                        pm2 stop 0
                        pm2 flush
                        pm2 start 0
                        pm2 logs --line=100 >somefile
                        post content of somefile
                        don’t truncate the log lines
                        • G
                          Ghost2000 @sdetweil
                          pi@MagicMirror:~ $ pm2 log mm
                          0|mm       |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.j        s:1:6162
                          0|mm       | [2020-10-10 16:05:13.621] [ERROR]  (node:1774) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 4)
                          0|mm       | [2020-10-10 16:05:13.622] [ERROR]  (node:1774) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 4)
                          0|mm       | [2020-10-10 16:42:49.278] [ERROR]  ERROR! Could not find main modul        e js file for MMM-Windy
                          0|mm       | [2020-10-10 16:42:53.517] [ERROR]  (node:4326) UnhandledPromiseReje        ctionWarning: Error: [object Object]
                          0|mm       | [2020-10-10 16:42:53.518] [ERROR]  (node:4326) UnhandledPromiseReje        ctionWarning: Error: [object Object]
                          0|mm       | [2020-10-10 16:42:53.519] [ERROR]  (node:4326) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 1)
                          0|mm       | [2020-10-10 16:42:53.520] [ERROR]  (node:4326) [DEP0018] Deprecatio        nWarning: Unhandled promise rejections are deprecated. In the future, promise re        jections that are not handled will terminate the Node.js process with a non-zero        exit code.
                          0|mm       | [2020-10-10 16:42:48.826] [LOG]    Launching application.
                          0|mm       | [2020-10-10 16:42:51.828] [LOG]    Create new calendar fetcher for        url: https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/private-c4        92e1e266741d80fd373303d2eb7f99/basic.ics - Interval: 300000
                          0|mm       | [2020-10-10 16:42:51.848] [LOG]    starting internet monitor node h        elper
                          0|mm       | [2020-10-10 16:42:51.854] [LOG]    Smart Touch module has started
                          0|mm       | [2020-10-10 16:42:51.860] [LOG]    Create new news fetcher for url:        https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                          0|mm       | [2020-10-10 16:42:51.900] [INFO]   Checking git for module: mmpm
                          0|mm       | [2020-10-10 16:42:51.901] [INFO]   Checking git for module: MMM-Car        ousel
                          0|mm       | [2020-10-10 16:42:51.928] [INFO]   Checking git for module: MMM-awe        some-alexa
                          0|mm       | [2020-10-10 16:42:51.954] [INFO]   Checking git for module: iFrame
                          0|mm       | [2020-10-10 16:42:51.980] [INFO]   Checking git for module: MMM-OnS        creenMenu
                          0|mm       | [2020-10-10 16:42:52.006] [INFO]   Checking git for module: interne        t-monitor
                          0|mm       | [2020-10-10 16:42:52.031] [INFO]   Checking git for module: MMM-Rem        ote-Control
                          0|mm       | [2020-10-10 16:42:52.065] [INFO]   Checking git for module: MMM-Sma        rtTouch
                          0|mm       | [2020-10-10 16:42:53.295] [INFO]   Newsfeed-Fetcher: Broadcasting 5        3 items.
                          0|mm       | [2020-10-10 16:42:53.975] [INFO]   Calendar-Fetcher: Broadcasting 4        events.
                            sdetweil @Ghost2000
                            could i get the REST of the line ??
                            • G
                              Ghost2000 @sdetweil
                              pi@MagicMirror:~ $ pm2 logs --lines=100
                              PM2        | 2020-10-10T17:04:04: PM2 log: Stopping app:mm id:0
                              PM2        | 2020-10-10T17:04:05: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-10-10T17:04:05: PM2 log: pid=4305 msg=process killed
                              PM2        | 2020-10-10T17:04:05: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-10T17:04:05: PM2 log: App [mm:0] online
                              0|mm       | [2020-10-10 17:04:09.488] [ERROR]  ERROR! Could not find main module js file for MMM-Windy
                              0|mm       | [2020-10-10 17:04:13.694] [ERROR]  (node:4895) UnhandledPromiseRejectionWarning: Error: [object Object]
                              0|mm       |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js:1:6073
                              0|mm       |     at processTicksAndRejections (internal/process/task_queues.js:89:5)
                              0|mm       | [2020-10-10 17:04:13.695] [ERROR]  (node:4895) UnhandledPromiseRejectionWarning: Error: [object Object]
                              0|mm       | [2020-10-10 17:04:13.695] [ERROR]  (node:4895) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                              0|mm       | [2020-10-10 17:04:13.696] [ERROR]  (node:4895) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                              0|mm       |
                              0|mm       | > magicmirror@2.13.0 start /home/pi/MagicMirror
                              0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                              0|mm       |
                              0|mm       | [2020-10-10 17:04:07.203] [LOG]    Starting MagicMirror: v2.13.0
                              0|mm       | [2020-10-10 17:04:07.210] [LOG]    Loading config ...
                              0|mm       | [2020-10-10 17:04:07.215] [LOG]    Loading module helpers ...
                              0|mm       | [2020-10-10 17:04:07.217] [LOG]    No helper found for module: alert.
                              0|mm       | [2020-10-10 17:04:07.222] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-10 17:04:07.223] [LOG]    Module helper loaded: mmpm
                              0|mm       | [2020-10-10 17:04:07.259] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-10 17:04:07.259] [LOG]    Module helper loaded: updatenotification
                              0|mm       | [2020-10-10 17:04:07.260] [LOG]    No helper found for module: MMM-Carousel.
                              0|mm       | [2020-10-10 17:04:07.261] [LOG]    No helper found for module: clock.
                              0|mm       | [2020-10-10 17:04:08.117] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-10 17:04:08.117] [LOG]    Module helper loaded: MMM-awesome-alexa
                              0|mm       | [2020-10-10 17:04:08.118] [LOG]    No helper found for module: iFrame.
                              0|mm       | [2020-10-10 17:04:08.477] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-10 17:04:08.478] [LOG]    Module helper loaded: calendar
                              0|mm       | [2020-10-10 17:04:08.480] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-10 17:04:08.480] [LOG]    Module helper loaded: MMM-OnScreenMenu
                              0|mm       | [2020-10-10 17:04:08.481] [LOG]    No helper found for module: compliments.
                              0|mm       | [2020-10-10 17:04:08.639] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-10 17:04:08.640] [LOG]    Module helper loaded: internet-monitor
                              0|mm       | [2020-10-10 17:04:08.641] [LOG]    No helper found for module: MMM-windy.
                              0|mm       | [2020-10-10 17:04:08.642] [LOG]    No helper found for module: currentweather.
                              0|mm       | [2020-10-10 17:04:08.774] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-10 17:04:08.774] [LOG]    Module helper loaded: MMM-Remote-Control
                              0|mm       | [2020-10-10 17:04:08.775] [LOG]    No helper found for module: weatherforecast.
                              0|mm       | [2020-10-10 17:04:08.777] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-10 17:04:08.777] [LOG]    Module helper loaded: MMM-SmartTouch
                              0|mm       | [2020-10-10 17:04:08.797] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-10 17:04:08.798] [LOG]    Module helper loaded: newsfeed
                              0|mm       | [2020-10-10 17:04:08.798] [LOG]    All module helpers loaded.
                              0|mm       | [2020-10-10 17:04:08.892] [LOG]    Starting server on port 8080 ...
                              0|mm       | [2020-10-10 17:04:08.894] [INFO]   You're using a full whitelist configuration to allow for all IPs
                              0|mm       | [2020-10-10 17:04:08.900] [LOG]    Server started ...
                              0|mm       | [2020-10-10 17:04:08.901] [LOG]    Connecting socket for: mmpm
                              0|mm       | [2020-10-10 17:04:08.902] [LOG]    Starting module helper: mmpm
                              0|mm       | [2020-10-10 17:04:08.902] [LOG]    Connecting socket for: updatenotification
                              0|mm       | [2020-10-10 17:04:08.903] [LOG]    Connecting socket for: MMM-awesome-alexa
                              0|mm       | [2020-10-10 17:04:08.904] [LOG]    Connecting socket for: calendar
                              0|mm       | [2020-10-10 17:04:08.904] [LOG]    Starting node helper for: calendar
                              0|mm       | [2020-10-10 17:04:08.905] [LOG]    Connecting socket for: MMM-OnScreenMenu
                              0|mm       | [2020-10-10 17:04:08.906] [LOG]    Connecting socket for: internet-monitor
                              0|mm       | [2020-10-10 17:04:08.906] [LOG]    internet-monitor helper started ...
                              0|mm       | [2020-10-10 17:04:08.907] [LOG]    Connecting socket for: MMM-Remote-Control
                              0|mm       | [2020-10-10 17:04:08.907] [LOG]    Starting node helper for: MMM-Remote-Control
                              0|mm       | [2020-10-10 17:04:08.914] [LOG]    Connecting socket for: MMM-SmartTouch
                              0|mm       | [2020-10-10 17:04:08.914] [LOG]    Connecting socket for: newsfeed
                              0|mm       | [2020-10-10 17:04:08.915] [LOG]    Starting node helper for: newsfeed
                              0|mm       | [2020-10-10 17:04:08.915] [LOG]    Sockets connected & modules started ...
                              0|mm       | [2020-10-10 17:04:08.991] [LOG]    Launching application.
                              0|mm       | [2020-10-10 17:04:12.070] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/private-c492e1e266741d80fd373303d2eb7f99/basic.ics - Interval: 300000
                              0|mm       | [2020-10-10 17:04:12.112] [LOG]    starting internet monitor node helper
                              0|mm       | [2020-10-10 17:04:12.124] [LOG]    Smart Touch module has started
                              0|mm       | [2020-10-10 17:04:12.132] [LOG]    Create new news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                              0|mm       | [2020-10-10 17:04:12.186] [INFO]   Checking git for module: mmpm
                              0|mm       | [2020-10-10 17:04:12.187] [INFO]   Checking git for module: MMM-Carousel
                              0|mm       | [2020-10-10 17:04:12.214] [INFO]   Checking git for module: MMM-awesome-alexa
                              0|mm       | [2020-10-10 17:04:12.243] [INFO]   Checking git for module: iFrame
                              0|mm       | [2020-10-10 17:04:12.268] [INFO]   Checking git for module: MMM-OnScreenMenu
                              0|mm       | [2020-10-10 17:04:12.294] [INFO]   Checking git for module: internet-monitor
                              0|mm       | [2020-10-10 17:04:12.320] [INFO]   Checking git for module: MMM-Remote-Control
                              0|mm       | [2020-10-10 17:04:12.346] [INFO]   Checking git for module: MMM-SmartTouch
                              0|mm       | [2020-10-10 17:04:13.525] [INFO]   Newsfeed-Fetcher: Broadcasting 54 items.
                              0|mm       | [2020-10-10 17:04:14.299] [INFO]   Calendar-Fetcher: Broadcasting 4 events.
                              S 2 Replies Last reply
                                sdetweil @Ghost2000
                                not THE problem, but you should fix it
                                MMM-Windy.js not in MMM-Windy folder
                                  sdetweil @Ghost2000
                                  @Ghost2000 node_helper?? no idea, the author has minified his code its really hard to figure out what is going on.
                                  • G
                                    Ghost2000
                                    Does it work for you?
                                      sdetweil @Ghost2000
                                      @Ghost2000 yes, i ran my do-install.sh script, did the avs config which we went thru yesterday,
                                      added the generated config to the bottom of my config.js and restarted my 2.13 MM…
                                      also, use my MM install script, not manual install , before that
                                      • G
                                        Ghost2000 @sdetweil
                                        @sdetweil said in MMM-awesome-alexa:
                                        MMM-Windy.js
                                        It’s in the folder
                                          sdetweil @Ghost2000
                                          @Ghost2000 computer says not… make sure there is no leading or trailing space on the file name… (or folder name)
                                          • G
                                            Ghost2000 @sdetweil
                                            @sdetweil Do I have to delete everything?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
