    MMM-awesome-alexa
    241 Posts 43 Posters 461.1k Views 47 Watching
      sdetweil @Ghost2000
      @Ghost2000 said in MMM-awesome-alexa:
      http: // localhost: 3000 /
      • G
        Ghost2000
        • G
          Ghost2000
            • G
              Ghost2000
              it works with your settings.
              http: // localhost: 3000 /? code = ANMcPyM …
              DANKE DANKE DANKE DANKE DANKE ! LOVE YOU!
              • G
                Ghost2000
                > magicmirror@2.13.0 config:check /home/pi/MagicMirror
                > node js/check_config.js
                [2020-10-10 00:52:40.394] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                [2020-10-10 00:52:40.490] [INFO]   Your configuration file doesn't contain syntax errors :)
                Screen black… no Error
                G 1 Reply Last reply
                • G
                  Ghost2000 @Ghost2000
                  pi@MagicMirror:~ $ cd ~/MagicMirror/
                  pi@MagicMirror:~/MagicMirror $ pm2 log mm
                  [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                  0|mm       |     at Module._compile (internal/modules/cjs/loader.js:786:30)
                  0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                  0|mm       |     at Module.load (internal/modules/cjs/loader.js:645:32) {
                  0|mm       |   code: 'MODULE_NOT_FOUND',
                  0|mm       |   requireStack: [
                  0|mm       |     '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js',
                  0|mm       |     '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js',
                  0|mm       |     '/home/pi/MagicMirror/js/app.js',
                  0|mm       |     '/home/pi/MagicMirror/js/electron.js',
                  0|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                  0|mm       |     undefined
                  0|mm       |   ]
                  0|mm       | }
                  0|mm       | [2020-10-10 00:55:35.178] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  0|mm       | [2020-10-10 00:55:35.178] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  0|mm       | [2020-10-10 00:55:34.267] [LOG]    Initializing new module helper ...
                  0|mm       | [2020-10-10 00:55:34.268] [LOG]    Module helper loaded: mmpm
                  0|mm       | [2020-10-10 00:55:34.304] [LOG]    Initializing new module helper ...
                  0|mm       | [2020-10-10 00:55:34.305] [LOG]    Module helper loaded: updatenotification
                  0|mm       | [2020-10-10 00:55:34.306] [LOG]    No helper found for module: MMM-Carousel.
                  0|mm       | [2020-10-10 00:55:34.306] [LOG]    No helper found for module: clock.
                  0|mm       | [2020-10-10 00:55:35.154] [LOG]    Loading module helpers ...
                  0|mm       | [2020-10-10 00:55:35.156] [LOG]    No helper found for module: alert.
                  0|mm       | [2020-10-10 00:55:35.159] [LOG]    Initializing new module helper ...
                  0|mm       | [2020-10-10 00:55:35.160] [LOG]    Module helper loaded: mmpm
                  0|mm       | [2020-10-10 00:55:35.161] [LOG]    Initializing new module helper ...
                  0|mm       | [2020-10-10 00:55:35.161] [LOG]    Module helper loaded: updatenotification
                  0|mm       | [2020-10-10 00:55:35.162] [LOG]    No helper found for module: MMM-Carousel.
                  0|mm       | [2020-10-10 00:55:35.163] [LOG]    No helper found for module: clock.
                  0|mm       | [2020-10-10 00:55:35.253] [LOG]    Launching application.
                    sdetweil @Ghost2000
                    @Ghost2000 module not found, I am away for the rest of the evening
                      I have a script that does the 14 install steps
                      • G
                        Ghost2000
                        can you send me ?
                          sdetweil @Ghost2000
                          @Ghost2000 https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
                          • G
                            Ghost2000
                            Thx Good night
                            • G
                              Ghost2000
                              0|mm       |     at processTicksAndRejections (internal/process/task_queues.js:8        9:5)
                              0|mm       | [2020-10-10 01:57:43.816] [ERROR]  (node:15126) UnhandledPromiseRej        ectionWarning: Unhandled promise rejection. This error originated either by thro        wing inside of an async function without a catch block, or by rejecting a promis        e which was not handled with .catch(). (rejection id: 1)
                              0|mm       | [2020-10-10 01:57:43.819] [ERROR]  (node:15126) UnhandledPromiseRej        ectionWarning: Unhandled promise rejection. This error originated either by thro        wing inside of an async function without a catch block, or by rejecting a promis        e which was not handled with .catch(). (rejection id: 1)
                              0|mm       | [2020-10-10 01:57:43.820] [ERROR]  (node:15126) [DEP0018] Deprecati        onWarning: Unhandled promise rejections are deprecated. In the future, promise r        ejections that are not handled will terminate the Node.js process with a non-zer        o exit code.
                              0|mm       | [2020-10-10 01:57:43.823] [ERROR]  (node:15126) [DEP0018] Deprecati        onWarning: Unhandled promise rejections are deprecated. In the future, promise r        ejections that are not handled will terminate the Node.js process with a non-zer        o exit code.
                              0|mm       | [2020-10-10 01:57:44.478] [ERROR]  Calendar Error. Could not fetch        calendar:  https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/publ        ic/basic.ics 404: Not Found
                              0|mm       | [2020-10-10 02:00:07.079] [ERROR]  Calendar Error. Could not fetch        calendar:  https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/publ        ic/basic.ics 404: Not Found
                              0|mm       | [2020-10-10 02:00:07.387] [ERROR]  (node:15126) UnhandledPromiseRej        ectionWarning: Error: [object Object]
                              0|mm       |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.j        s:1:6073
                              0|mm       | [2020-10-10 02:00:07.388] [ERROR]  (node:15126) UnhandledPromiseRej        ectionWarning: Unhandled promise rejection. This error originated either by thro        wing inside of an async function without a catch block, or by rejecting a promis        e which was not handled with .catch(). (rejection id: 2)
                                sdetweil @Ghost2000
                                @Ghost2000 looks like a networking problem calendar catch fetch too
                                u ran the script?, do
                                pm2 stop 0
                                pm2 flush
                                pm2 start 0
                                pm2 logs --line=100 >somefile
                                post content of somefile
                                don’t truncate the log lines
                                • G
                                  Ghost2000 @sdetweil
                                  pi@MagicMirror:~ $ pm2 log mm
                                  0|mm       |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.j        s:1:6162
                                  0|mm       | [2020-10-10 16:05:13.621] [ERROR]  (node:1774) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 4)
                                  0|mm       | [2020-10-10 16:05:13.622] [ERROR]  (node:1774) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 4)
                                  0|mm       | [2020-10-10 16:42:49.278] [ERROR]  ERROR! Could not find main modul        e js file for MMM-Windy
                                  0|mm       | [2020-10-10 16:42:53.517] [ERROR]  (node:4326) UnhandledPromiseReje        ctionWarning: Error: [object Object]
                                  0|mm       | [2020-10-10 16:42:53.518] [ERROR]  (node:4326) UnhandledPromiseReje        ctionWarning: Error: [object Object]
                                  0|mm       | [2020-10-10 16:42:53.519] [ERROR]  (node:4326) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 1)
                                  0|mm       | [2020-10-10 16:42:53.520] [ERROR]  (node:4326) [DEP0018] Deprecatio        nWarning: Unhandled promise rejections are deprecated. In the future, promise re        jections that are not handled will terminate the Node.js process with a non-zero        exit code.
                                  0|mm       | [2020-10-10 16:42:48.826] [LOG]    Launching application.
                                  0|mm       | [2020-10-10 16:42:51.828] [LOG]    Create new calendar fetcher for        url: https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/private-c4        92e1e266741d80fd373303d2eb7f99/basic.ics - Interval: 300000
                                  0|mm       | [2020-10-10 16:42:51.848] [LOG]    starting internet monitor node h        elper
                                  0|mm       | [2020-10-10 16:42:51.854] [LOG]    Smart Touch module has started
                                  0|mm       | [2020-10-10 16:42:51.860] [LOG]    Create new news fetcher for url:        https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                  0|mm       | [2020-10-10 16:42:51.900] [INFO]   Checking git for module: mmpm
                                  0|mm       | [2020-10-10 16:42:51.901] [INFO]   Checking git for module: MMM-Car        ousel
                                  0|mm       | [2020-10-10 16:42:51.928] [INFO]   Checking git for module: MMM-awe        some-alexa
                                  0|mm       | [2020-10-10 16:42:51.954] [INFO]   Checking git for module: iFrame
                                  0|mm       | [2020-10-10 16:42:51.980] [INFO]   Checking git for module: MMM-OnS        creenMenu
                                  0|mm       | [2020-10-10 16:42:52.006] [INFO]   Checking git for module: interne        t-monitor
                                  0|mm       | [2020-10-10 16:42:52.031] [INFO]   Checking git for module: MMM-Rem        ote-Control
                                  0|mm       | [2020-10-10 16:42:52.065] [INFO]   Checking git for module: MMM-Sma        rtTouch
                                  0|mm       | [2020-10-10 16:42:53.295] [INFO]   Newsfeed-Fetcher: Broadcasting 5        3 items.
                                  0|mm       | [2020-10-10 16:42:53.975] [INFO]   Calendar-Fetcher: Broadcasting 4        events.
                                    sdetweil @Ghost2000
                                    could i get the REST of the line ??
                                    • G
                                      Ghost2000 @sdetweil
                                      pi@MagicMirror:~ $ pm2 logs --lines=100
                                      PM2        | 2020-10-10T17:04:04: PM2 log: Stopping app:mm id:0
                                      PM2        | 2020-10-10T17:04:05: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                      PM2        | 2020-10-10T17:04:05: PM2 log: pid=4305 msg=process killed
                                      PM2        | 2020-10-10T17:04:05: PM2 log: App [mm:0] starting in -fork mode-
                                      PM2        | 2020-10-10T17:04:05: PM2 log: App [mm:0] online
                                      0|mm       | [2020-10-10 17:04:09.488] [ERROR]  ERROR! Could not find main module js file for MMM-Windy
                                      0|mm       | [2020-10-10 17:04:13.694] [ERROR]  (node:4895) UnhandledPromiseRejectionWarning: Error: [object Object]
                                      0|mm       |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js:1:6073
                                      0|mm       |     at processTicksAndRejections (internal/process/task_queues.js:89:5)
                                      0|mm       | [2020-10-10 17:04:13.695] [ERROR]  (node:4895) UnhandledPromiseRejectionWarning: Error: [object Object]
                                      0|mm       | [2020-10-10 17:04:13.695] [ERROR]  (node:4895) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                                      0|mm       | [2020-10-10 17:04:13.696] [ERROR]  (node:4895) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                      0|mm       |
                                      0|mm       | > magicmirror@2.13.0 start /home/pi/MagicMirror
                                      0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                      0|mm       |
                                      0|mm       | [2020-10-10 17:04:07.203] [LOG]    Starting MagicMirror: v2.13.0
                                      0|mm       | [2020-10-10 17:04:07.210] [LOG]    Loading config ...
                                      0|mm       | [2020-10-10 17:04:07.215] [LOG]    Loading module helpers ...
                                      0|mm       | [2020-10-10 17:04:07.217] [LOG]    No helper found for module: alert.
                                      0|mm       | [2020-10-10 17:04:07.222] [LOG]    Initializing new module helper ...
                                      0|mm       | [2020-10-10 17:04:07.223] [LOG]    Module helper loaded: mmpm
                                      0|mm       | [2020-10-10 17:04:07.259] [LOG]    Initializing new module helper ...
                                      0|mm       | [2020-10-10 17:04:07.259] [LOG]    Module helper loaded: updatenotification
                                      0|mm       | [2020-10-10 17:04:07.260] [LOG]    No helper found for module: MMM-Carousel.
                                      0|mm       | [2020-10-10 17:04:07.261] [LOG]    No helper found for module: clock.
                                      0|mm       | [2020-10-10 17:04:08.117] [LOG]    Initializing new module helper ...
                                      0|mm       | [2020-10-10 17:04:08.117] [LOG]    Module helper loaded: MMM-awesome-alexa
                                      0|mm       | [2020-10-10 17:04:08.118] [LOG]    No helper found for module: iFrame.
                                      0|mm       | [2020-10-10 17:04:08.477] [LOG]    Initializing new module helper ...
                                      0|mm       | [2020-10-10 17:04:08.478] [LOG]    Module helper loaded: calendar
                                      0|mm       | [2020-10-10 17:04:08.480] [LOG]    Initializing new module helper ...
                                      0|mm       | [2020-10-10 17:04:08.480] [LOG]    Module helper loaded: MMM-OnScreenMenu
                                      0|mm       | [2020-10-10 17:04:08.481] [LOG]    No helper found for module: compliments.
                                      0|mm       | [2020-10-10 17:04:08.639] [LOG]    Initializing new module helper ...
                                      0|mm       | [2020-10-10 17:04:08.640] [LOG]    Module helper loaded: internet-monitor
                                      0|mm       | [2020-10-10 17:04:08.641] [LOG]    No helper found for module: MMM-windy.
                                      0|mm       | [2020-10-10 17:04:08.642] [LOG]    No helper found for module: currentweather.
                                      0|mm       | [2020-10-10 17:04:08.774] [LOG]    Initializing new module helper ...
                                      0|mm       | [2020-10-10 17:04:08.774] [LOG]    Module helper loaded: MMM-Remote-Control
                                      0|mm       | [2020-10-10 17:04:08.775] [LOG]    No helper found for module: weatherforecast.
                                      0|mm       | [2020-10-10 17:04:08.777] [LOG]    Initializing new module helper ...
                                      0|mm       | [2020-10-10 17:04:08.777] [LOG]    Module helper loaded: MMM-SmartTouch
                                      0|mm       | [2020-10-10 17:04:08.797] [LOG]    Initializing new module helper ...
                                      0|mm       | [2020-10-10 17:04:08.798] [LOG]    Module helper loaded: newsfeed
                                      0|mm       | [2020-10-10 17:04:08.798] [LOG]    All module helpers loaded.
                                      0|mm       | [2020-10-10 17:04:08.892] [LOG]    Starting server on port 8080 ...
                                      0|mm       | [2020-10-10 17:04:08.894] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                      0|mm       | [2020-10-10 17:04:08.900] [LOG]    Server started ...
                                      0|mm       | [2020-10-10 17:04:08.901] [LOG]    Connecting socket for: mmpm
                                      0|mm       | [2020-10-10 17:04:08.902] [LOG]    Starting module helper: mmpm
                                      0|mm       | [2020-10-10 17:04:08.902] [LOG]    Connecting socket for: updatenotification
                                      0|mm       | [2020-10-10 17:04:08.903] [LOG]    Connecting socket for: MMM-awesome-alexa
                                      0|mm       | [2020-10-10 17:04:08.904] [LOG]    Connecting socket for: calendar
                                      0|mm       | [2020-10-10 17:04:08.904] [LOG]    Starting node helper for: calendar
                                      0|mm       | [2020-10-10 17:04:08.905] [LOG]    Connecting socket for: MMM-OnScreenMenu
                                      0|mm       | [2020-10-10 17:04:08.906] [LOG]    Connecting socket for: internet-monitor
                                      0|mm       | [2020-10-10 17:04:08.906] [LOG]    internet-monitor helper started ...
                                      0|mm       | [2020-10-10 17:04:08.907] [LOG]    Connecting socket for: MMM-Remote-Control
                                      0|mm       | [2020-10-10 17:04:08.907] [LOG]    Starting node helper for: MMM-Remote-Control
                                      0|mm       | [2020-10-10 17:04:08.914] [LOG]    Connecting socket for: MMM-SmartTouch
                                      0|mm       | [2020-10-10 17:04:08.914] [LOG]    Connecting socket for: newsfeed
                                      0|mm       | [2020-10-10 17:04:08.915] [LOG]    Starting node helper for: newsfeed
                                      0|mm       | [2020-10-10 17:04:08.915] [LOG]    Sockets connected & modules started ...
                                      0|mm       | [2020-10-10 17:04:08.991] [LOG]    Launching application.
                                      0|mm       | [2020-10-10 17:04:12.070] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/private-c492e1e266741d80fd373303d2eb7f99/basic.ics - Interval: 300000
                                      0|mm       | [2020-10-10 17:04:12.112] [LOG]    starting internet monitor node helper
                                      0|mm       | [2020-10-10 17:04:12.124] [LOG]    Smart Touch module has started
                                      0|mm       | [2020-10-10 17:04:12.132] [LOG]    Create new news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                      0|mm       | [2020-10-10 17:04:12.186] [INFO]   Checking git for module: mmpm
                                      0|mm       | [2020-10-10 17:04:12.187] [INFO]   Checking git for module: MMM-Carousel
                                      0|mm       | [2020-10-10 17:04:12.214] [INFO]   Checking git for module: MMM-awesome-alexa
                                      0|mm       | [2020-10-10 17:04:12.243] [INFO]   Checking git for module: iFrame
                                      0|mm       | [2020-10-10 17:04:12.268] [INFO]   Checking git for module: MMM-OnScreenMenu
                                      0|mm       | [2020-10-10 17:04:12.294] [INFO]   Checking git for module: internet-monitor
                                      0|mm       | [2020-10-10 17:04:12.320] [INFO]   Checking git for module: MMM-Remote-Control
                                      0|mm       | [2020-10-10 17:04:12.346] [INFO]   Checking git for module: MMM-SmartTouch
                                      0|mm       | [2020-10-10 17:04:13.525] [INFO]   Newsfeed-Fetcher: Broadcasting 54 items.
                                      0|mm       | [2020-10-10 17:04:14.299] [INFO]   Calendar-Fetcher: Broadcasting 4 events.
                                      S 2 Replies Last reply
                                        sdetweil @Ghost2000
                                        not THE problem, but you should fix it
                                        MMM-Windy.js not in MMM-Windy folder
                                          sdetweil @Ghost2000
                                          @Ghost2000 node_helper?? no idea, the author has minified his code its really hard to figure out what is going on.
                                          • G
                                            Ghost2000
                                            Does it work for you?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
