Notification issued from MMM-MQTTbridge but nothing happens
As I posted elsewhere, after find the logs, I could get the errors removed, so now it posts the notification to REMOTE_ACTION, but nothing happens:
It does receive the MQTT command, but nothing happens on the NOTI:
0|mm | [MQTT bridge] MQTT message received. Topic: bathroom/mirror, message: MONITOROFF 0|mm | [2020-10-16 09:23:53.728] [LOG] 0|mm | [MQTT bridge] MQTT -> NOTI issued: 'REMOTE_ACTION', payload: {action: 'MONITOROFF' }Same thing happens for MONITORON, DIM and UNDIM.
The mqttdictionary file looks like this now:
var mqttHook = [ { mqttTopic: "bathroom/mirror", mqttPayload: [ { payloadValue: "MONITOROFF", mqttNotiCmd: ["MONITOROFF"] }, { payloadValue: "MONITORON", mqttNotiCmd: ["MONITORON"] }, { payloadValue: "UNDIM", mqttNotiCmd: ["UNDIM"] }, { payloadValue: "DIM", mqttNotiCmd: ["DIM"] }, ], }, ]; var mqttNotiCommands = [ { commandId: "MONITOROFF", notiID: "'REMOTE_ACTION'", notiPayload: "{action: 'MONITOROFF' }" }, { commandId: "MONITORON", notiID: "'REMOTE_ACTION'", notiPayload: "{action: 'MONITORON' }" }, { commandId: "DIM", notiID: "'REMOTE_ACTION'", notiPayload: "{action: 'BRIGHTNESS', value: '50')" }, { commandId: "UNDIM", notiID: "'REMOTE_ACTION'", notiPayload: "action: 'BRIGHTNESS', value: '255'}" }, ]; module.exports = { mqttHook, mqttNotiCommands};And the notification looks just like the one here in the documentation example here:
this.sendNotification('REMOTE_ACTION', {action: 'RESTART'});The ipWhitelisting has been both tried with [(“127.0.0.1”,“localhost”,“my.ip.range.0/24”)] and also with just [].
I can issue the commands MONITOROFF/MONITORON directly in the Remote-Control menu at /remote.htmlAny input from the developers on this? @Serge , @Bugsounet, @Jopyth :-)
Is it a MMM-MQTTbridge problem or a MMM-Remote-Control problem?
@fribse said in Notification issued from MMM-MQTTbridge but nothing happens:
0|mm | [MQTT bridge] MQTT -> NOTI issued: ‘REMOTE_ACTION’, payload: {action: ‘MONITOROFF’ }Seems that mqttbridg isseued the predefined noti so the problem is with nite receiving by remcontrol or with noti processing by remote control.
Send as well console log here -
notiID: “‘REMOTE_ACTION’”,
Try to remove double quotes here in config
And again, Serge sharp eyes found the errors. I was somply trying to hard to add quotes and stuff so it got messed up.
The working config for receiving commands from Home Assistant looks like this now:var mqttHook = [ { mqttTopic: "cmnd/bathroom/mirror", mqttPayload: [ { payloadValue: "MONITOROFF", mqttNotiCmd: ["MONITOROFF"] }, { payloadValue: "MONITORON", mqttNotiCmd: ["MONITORON"] }, { payloadValue: "UNDIM", mqttNotiCmd: ["UNDIM"] }, { payloadValue: "DIM", mqttNotiCmd: ["DIM"] }, ], }, ]; var mqttNotiCommands = [ { commandId: "MONITOROFF", notiID: 'REMOTE_ACTION', notiPayload: {action: 'MONITOROFF'} }, { commandId: "MONITORON", notiID: 'REMOTE_ACTION', notiPayload: {action: 'MONITORON'} }, { commandId: "DIM", notiID: 'REMOTE_ACTION', notiPayload: {action: 'BRIGHTNESS', value: '50'} }, { commandId: "UNDIM", notiID: 'REMOTE_ACTION', notiPayload: {action: 'BRIGHTNESS', value: '255'} }, ]; module.exports = { mqttHook, mqttNotiCommands};
