    MMM-COVID19 not updating
    28 Posts 5 Posters 10.1k Views 5 Watching
      bjoern @sdetweil
      @sdetweil You have some Screens?
        Baraka @sdetweil
        @sdetweil Thanks for your module, it is working very good to show me only the new cases in Germany
          Baraka @sdetweil
          @sdetweil Could you display for cases at the graph the last count for today as option?
            Baraka @mumblebaj
            @mumblebaj yes, so this module is now death.
              sdetweil @bjoern
              @bjoern see this page, I have lots of charts shown Screenshot at 2020-10-15 07-18-23.png
                sdetweil @Baraka
                @Baraka no, I don’t think that is useful. my charts are intended to allow one to see the shape of the curve.
                here the middle chart on the right side shows Cumulative cases by country, you can see the good flat line til Aug 10th, while Italy is holding on (but starting to turn)
                and the volume of new cases is significantly more that each countries prior reported amount…
                I don’t need to know if its 875432 or 875555
                the actual number is pretty useless.
                IF you use the chart, and have access to a mouse, you can hover over the chart line to see the number used
                ( you can see the hover info in the same middle chart on the right side here)
                u can also turn off individual inputs to the chart. (by clicking on the box in the legend)
                here I turned off USA on the same chart , now u get a better view of the other countries
                mumblebajM B 2 Replies Last reply
                • mumblebajM
                  @sdetweil Nice one Sam. The RapidAPI seems to be working again for some reason. Not sure why but it is working.
                  B 1 Reply Last reply
                    Baraka @sdetweil
                    @sdetweil today morning no data or no chart for cases
                      Baraka @mumblebaj
                      @mumblebaj yes , you are right , we get data. time stamp at this morning looks good
                        sdetweil @Baraka
                        @Baraka looks good right now… sometimes they take awhile to release the data… I’ve seen til almost 2pm us eastern time (gmt+5)
                          Baraka @sdetweil
                          @sdetweil i have always this error message: [MyCovid19 Loading data for Chart “Cases”] since this morning. :-(
                            sdetweil @Baraka
                            @Baraka oh, sorry, was replying about my module… Not this one
                              Baraka @sdetweil
                              @sdetweil it is your module , who is not working at the moment
                                sdetweil @Baraka
                                @Baraka hm…
                                use a browser, go to this page
                                https://www.ecdc.europa.eu/en/publications-data/download-todays-data-geographic-distribution-covid-19-cases-worldwide
                                and click on download csv in the middle of the page
                                this is the data the module uses. I can access the file and it is current
                                also, can u look in the log (either the window for npm start, or pm2 logs --lines=??? for pm2
                                ??? is a number, default 15
                                the module should retry every 15 minutes
                                  Baraka
                                  i have this in the log:
                                  requested file exists=modules/MyCovid19/countries-rawdata-10-22-2020.csv sending back to module_16_MyCovid19_4881
                                  ready to get data id=module_16_MyCovid19_4881
                                  check for file =modules/MyCovid19/countries-rawdata-10-22-2020.csv
                                  processing id=module_16_MyCovid19_4881 file=modules/MyCovid19/countries-rawdata-10-22-2020.csv fields=[object Object]
                                  done processing file id=module_16_MyCovid19_4881
                                  have data, now filter id=module_16_MyCovid19_4881
                                  processing for [“Germany”]
                                  location=Germany
                                  there are 0 entries to filter
                                  send filtered data id=module_16_MyCovid19_4881
                                    sdetweil @Baraka
                                    @Baraka said in MMM-COVID19 not updating:
                                    ok, can u do an ls -laF on the file
                                    and then rename it to …csv.old (I might want to see it)
                                    I try not to download more than once a day to save peoples bandwidth
                                      Baraka @sdetweil
                                      @sdetweil i have rename the file and start new the mirror now i have the diagramm. Thanks
                                        sdetweil @Baraka
                                        @Baraka yes, I am interested in what is in the file, how big it is… if 0 size then I need to look at that in case of a download error…
                                          Baraka @sdetweil
                                          @sdetweil the old file has 468 bytes - > maybe corrupt , the new and correct has 3491729 bytes
                                          S 2 Replies Last reply
                                            sdetweil @Baraka
                                            @Baraka thank you…
