    MMM-COVID19 not updating
    28 Posts 5 Posters 8.9k Views 5 Watching
      Baraka @mumblebaj
      @mumblebaj yes, so this module is now death.
        sdetweil @bjoern
        @bjoern see this page, I have lots of charts shown Screenshot at 2020-10-15 07-18-23.png
          sdetweil @Baraka
          @Baraka no, I don’t think that is useful. my charts are intended to allow one to see the shape of the curve.
          here the middle chart on the right side shows Cumulative cases by country, you can see the good flat line til Aug 10th, while Italy is holding on (but starting to turn)
          and the volume of new cases is significantly more that each countries prior reported amount…
          I don’t need to know if its 875432 or 875555
          the actual number is pretty useless.
          IF you use the chart, and have access to a mouse, you can hover over the chart line to see the number used
          ( you can see the hover info in the same middle chart on the right side here)
          u can also turn off individual inputs to the chart. (by clicking on the box in the legend)
          here I turned off USA on the same chart , now u get a better view of the other countries
          mumblebajM B 2 Replies Last reply Reply Quote 0
          • mumblebajM Offline
            @sdetweil Nice one Sam. The RapidAPI seems to be working again for some reason. Not sure why but it is working.
              Baraka @sdetweil
              @sdetweil today morning no data or no chart for cases
                Baraka @mumblebaj
                @mumblebaj yes , you are right , we get data. time stamp at this morning looks good
                  sdetweil @Baraka
                  @Baraka looks good right now… sometimes they take awhile to release the data… I’ve seen til almost 2pm us eastern time (gmt+5)
                    Baraka @sdetweil
                    @sdetweil i have always this error message: [MyCovid19 Loading data for Chart “Cases”] since this morning. :-(
                      sdetweil @Baraka
                      @Baraka oh, sorry, was replying about my module… Not this one
                        Baraka @sdetweil
                        @sdetweil it is your module , who is not working at the moment
                          sdetweil @Baraka
                          @Baraka hm…
                          use a browser, go to this page
                          https://www.ecdc.europa.eu/en/publications-data/download-todays-data-geographic-distribution-covid-19-cases-worldwide
                          and click on download csv in the middle of the page
                          this is the data the module uses. I can access the file and it is current
                          also, can u look in the log (either the window for npm start, or pm2 logs --lines=??? for pm2
                          ??? is a number, default 15
                          the module should retry every 15 minutes
                            Baraka
                            i have this in the log:
                            requested file exists=modules/MyCovid19/countries-rawdata-10-22-2020.csv sending back to module_16_MyCovid19_4881
                            ready to get data id=module_16_MyCovid19_4881
                            check for file =modules/MyCovid19/countries-rawdata-10-22-2020.csv
                            processing id=module_16_MyCovid19_4881 file=modules/MyCovid19/countries-rawdata-10-22-2020.csv fields=[object Object]
                            done processing file id=module_16_MyCovid19_4881
                            have data, now filter id=module_16_MyCovid19_4881
                            processing for [“Germany”]
                            location=Germany
                            there are 0 entries to filter
                            send filtered data id=module_16_MyCovid19_4881
                              sdetweil @Baraka
                              @Baraka said in MMM-COVID19 not updating:
                              ok, can u do an ls -laF on the file
                              and then rename it to …csv.old (I might want to see it)
                              I try not to download more than once a day to save peoples bandwidth
                                Baraka @sdetweil
                                @sdetweil i have rename the file and start new the mirror now i have the diagramm. Thanks
                                  sdetweil @Baraka
                                  @Baraka yes, I am interested in what is in the file, how big it is… if 0 size then I need to look at that in case of a download error…
                                    Baraka @sdetweil
                                    @sdetweil the old file has 468 bytes - > maybe corrupt , the new and correct has 3491729 bytes
                                      sdetweil @Baraka
                                      @Baraka thank you…
                                        sdetweil @Baraka
                                        @Baraka I have pushed a fix for the small file problem… it will erase it and act like it wasn’t there
                                        git pull to get the update
                                          Baraka @sdetweil
                                          @sdetweil No Graph is displayed, something has changed in csv file…
                                            sdetweil @Baraka
                                            @Baraka someone posted an issue for my MyCovid19 module. the source has changed publishing dates and maybe format
                                            I have updated my module.
