    MMM-Videoplayer - Play video files on your mirror
    20 Posts 6 Posters 10.4k Views 6 Watching
    • SnilleS
      Snille Module Developer @feigi
      @feigi Hmm… I found that I had forgotten a comma in the example configs… But It looks like you have that comma in your config. I tried it on a “clean” install (on both development and master branch) and with your config and it works. What does the log say? (pm2 log).
      • SnilleS
        Added some new stuff in v0.2. See first post… :)
        • SnilleS
          Added some new stuff again in v0.3. See first post…
            dherl0623
            Awesome module! I’m using it to play the old Windows 98 Mystery (Haunted House) Screensaver. I just ripped the video off of YouTube, reduced the quality and it plays perfectly! Thanks again!
            SnilleS 1 Reply Last reply Reply Quote 0
            • SnilleS
              Snille Module Developer @dherl0623
              @dherl0623 Thank you! :) I’m going to use it soon to play spooky stuff from AtmosFX on Halloween, It’s going to be timed with module scheduler over whole day. Suddenly a ghost appear in the background… :)
                dherl0623 @Snille
                @Snille That’s awesome! I just downloaded a leaves falling video from them! What would be the best way to play this fullscreen in the background behind all of the elements? Using the CSS in your example above is putting it over top of all of the other modules. Thanks again!
                • SnilleS
                  @dherl0623 Hm… I’m using the player in the region “fullscreen_below”. I have this player first in the config of all things that “can” show in the same region (that way it will always end up above the other things in the same region):
                  	disabled: false,
                  	module: 'MMM-Videoplayer',
                  	position: "fullscreen_below",
                  	classes: "scheduler turn90",
                  		random: true,
                  		loop: true,
                  		notification: "VIDEOPLAYER1",
                  		videolist: ["http://your.site.com/video/clip1.mp4",
                  					"http://your.site.com/video/clip2.mp4",
                  					"http://your.site.com/video/clip3.mp4",
                  					"http://your.site.com/video/clip4.mp4",
                  					"http://your.site.com/video/clip5.mp4",
                  					"http://your.site.com/video/clip6.mp4",
                  					"http://your.site.com/video/clip7.mp4",
                  					"http://your.site.com/video/clip8.mp4",
                  					"http://your.site.com/video/clip9.mp4",
                  					"http://your.site.com/video/clip10.mp4",
                  					"http://your.site.com/video/clip11.mp4"],
                  		module_schedule: [
                  			{from: '0 6 31 9 *', to: '5 6 31 9 *'},
                  			{from: '2 7 31 9 *', to: '7 7 31 9 *'},
                  			{from: '4 8 31 9 *', to: '9 8 31 9 *'},
                  			{from: '6 9 31 9 *', to: '11 9 31 9 *'},
                  			{from: '8 10 31 9 *', to: '13 10 31 9 *'},
                  			{from: '10 11 31 9 *', to: '15 11 31 9 *'},
                  			{from: '12 12 31 9 *', to: '17 12 31 9 *'},
                  			{from: '14 13 31 9 *', to: '19 13 31 9 *'},
                  			{from: '16 14 31 9 *', to: '21 14 31 9 *'},
                  			{from: '18 15 31 9 *', to: '23 15 31 9 *'},
                  			{from: '20 16 31 9 *', to: '25 16 31 9 *'},
                  			{from: '22 17 31 9 *', to: '27 17 31 9 *'},
                  			{from: '24 18 31 9 *', to: '29 18 31 9 *'},
                  			{from: '26 19 31 9 *', to: '31 19 31 9 *'},
                  			{from: '28 20 31 9 *', to: '33 20 31 9 *'},
                  			{from: '30 21 31 9 *', to: '35 21 31 9 *'},
                  			{from: '32 22 31 9 *', to: '37 22 31 9 *'},
                  			{from: '34 23 31 9 *', to: '39 23 31 9 *'},
                  Then I have set the “classes” on this player to “scheduler turn90”, the first class is for the MMM-ModuleScheduler to work and the second is for the player to be turned 90 degrees and set to full screen.
                  My CSS entry for this player looks like this:
                  /* MMM-Videoplayer ----------------------------------*/
                  .MMM-Videoplayer video {
                      width: 1080px;
                      height: 1920px;
                  .turn90 video {
                      position: absolute;
                      transform:rotate(90deg);
                      transform-origin: bottom left;
                      width: 100vh;
                      height: 100vw;
                      margin-top: -100vw;
                      object-fit: cover;
                  That’s it. :)
                  • F
                    feigi
                    @Snille
                    Thank you very much for your answer. Sorry for my late reply, but i did not have time to cover this through the week.
                    I updated to the latest version and disabled all other modules on my rPI.
                    But none the less, it does not load the (or any other video).
                    I dont see any errors:
                    [2020-10-25 19:30:29.738] [LOG] Starting MagicMirror: v2.12.0
                    [2020-10-25 19:30:29.749] [LOG] Loading config …
                    [2020-10-25 19:30:29.758] [LOG] Loading module helpers …
                    [2020-10-25 19:30:29.761] [LOG] No helper found for module: MMM-VideoPlayer.
                    [2020-10-25 19:30:29.762] [LOG] All module helpers loaded.
                    [2020-10-25 19:30:29.981] [LOG] Starting server on port 8080 …
                    [2020-10-25 19:30:30.000] [LOG] Server started …
                    [2020-10-25 19:30:30.001] [LOG] Sockets connected & modules started …
                    [2020-10-25 19:30:30.145] [LOG] Launching application.
                    Did already someone had success to test this on rPI?
                    Or what could i do for some more debug?
                    Cheers,
                    Feigi
                    S SnilleS 2 Replies Last reply Reply Quote 0
                      sdetweil @feigi
                      @feigi which version, there are 3? google search ‘mmm-videoplayer github’
                      Snille’s version does not have a node_helper.js file
                      the others do
                      • SnilleS
                        @feigi Yes, as @sdetweil said, I’m not using a “node_helper” at all. It’s not needed for the player. It looks like it’s loading as it should. If you don’t see the video, try putting it in another region just to see if it plays. I have only tested the player on my mirror (Ubuntu server with XFCE desktop on a Intel NUC machine) and on a Ubuntu server (running in a container (LXC) then accessing the mirror from a Windows 10 machine in Chrome). And both of them are working… But I can imagine that the RPi may struggle…
                        • F
                          feigi @Snille
                          @Snille Yes, i use your Version. The content of my cloned folder on the rPI is identical to your folder on github. So i am using the same Version.
                          Why its showing that its trying to load a node_helper, i have no idea. I dont even know what that is :) I just started the MM without any other modules than yours and did not see an Error and just wanted to show that.
                          But its ok if this is not possible to play on a rPI. Was worth a try!
                          Thanks anyway for your support and the great work! :)
                            sdetweil @feigi
                            @feigi said in MMM-Videoplayer - Play video files on your mirror:
                            the system ALWAYS tries and reports… nothing worrisome…
                            • BKeyportB
                              BKeyport Module Developer
                              One minor note - in your readme on github, there’s no install instructions. I’d add that…
                              Seems to be good otherwise.
                              • SnilleS
                                Snille Module Developer @BKeyport
                                @BKeyport Oh! Good point! I’ll fix that. Thank you! :)
                                • SnilleS
                                  Added a new function in v0.4. See first post…
                                  • E
                                    elitecybernet
                                    @Snille i had tried your mmm videoplayer, im curious is it no sound for playing video ?Or i need to do something on my config? I want to play with hdmi sound in my monitor.
                                    thank for your support. good job
                                    • SnilleS
                                      Snille Module Developer @elitecybernet
                                      @elitecybernet Hi! Yes, default is “no sound”, because if you set it to yes, it will not “autoplay”. But you can just change the option: muted to false.
                                        position: 'middle_center',
                                          muted: false,
                                      Like so… :)
