    MMM-Videoplayer - Play video files on your mirror
    20 Posts 6 Posters 10.1k Views 6 Watching
    • SnilleS Offline
      Snille Module Developer @dherl0623
      @dherl0623 Hm… I’m using the player in the region “fullscreen_below”. I have this player first in the config of all things that “can” show in the same region (that way it will always end up above the other things in the same region):
      	disabled: false,
      	module: 'MMM-Videoplayer',
      	position: "fullscreen_below",
      	classes: "scheduler turn90",
      		random: true,
      		loop: true,
      		notification: "VIDEOPLAYER1",
      		videolist: ["http://your.site.com/video/clip1.mp4",
      					"http://your.site.com/video/clip2.mp4",
      					"http://your.site.com/video/clip3.mp4",
      					"http://your.site.com/video/clip4.mp4",
      					"http://your.site.com/video/clip5.mp4",
      					"http://your.site.com/video/clip6.mp4",
      					"http://your.site.com/video/clip7.mp4",
      					"http://your.site.com/video/clip8.mp4",
      					"http://your.site.com/video/clip9.mp4",
      					"http://your.site.com/video/clip10.mp4",
      					"http://your.site.com/video/clip11.mp4"],
      		module_schedule: [
      			{from: '0 6 31 9 *', to: '5 6 31 9 *'},
      			{from: '2 7 31 9 *', to: '7 7 31 9 *'},
      			{from: '4 8 31 9 *', to: '9 8 31 9 *'},
      			{from: '6 9 31 9 *', to: '11 9 31 9 *'},
      			{from: '8 10 31 9 *', to: '13 10 31 9 *'},
      			{from: '10 11 31 9 *', to: '15 11 31 9 *'},
      			{from: '12 12 31 9 *', to: '17 12 31 9 *'},
      			{from: '14 13 31 9 *', to: '19 13 31 9 *'},
      			{from: '16 14 31 9 *', to: '21 14 31 9 *'},
      			{from: '18 15 31 9 *', to: '23 15 31 9 *'},
      			{from: '20 16 31 9 *', to: '25 16 31 9 *'},
      			{from: '22 17 31 9 *', to: '27 17 31 9 *'},
      			{from: '24 18 31 9 *', to: '29 18 31 9 *'},
      			{from: '26 19 31 9 *', to: '31 19 31 9 *'},
      			{from: '28 20 31 9 *', to: '33 20 31 9 *'},
      			{from: '30 21 31 9 *', to: '35 21 31 9 *'},
      			{from: '32 22 31 9 *', to: '37 22 31 9 *'},
      			{from: '34 23 31 9 *', to: '39 23 31 9 *'},
      Then I have set the “classes” on this player to “scheduler turn90”, the first class is for the MMM-ModuleScheduler to work and the second is for the player to be turned 90 degrees and set to full screen.
      My CSS entry for this player looks like this:
      /* MMM-Videoplayer ----------------------------------*/
      .MMM-Videoplayer video {
          width: 1080px;
          height: 1920px;
      .turn90 video {
          position: absolute;
          transform:rotate(90deg);
          transform-origin: bottom left;
          width: 100vh;
          height: 100vw;
          margin-top: -100vw;
          object-fit: cover;
      That’s it. :)
      • F Offline
        feigi
        @Snille
        Thank you very much for your answer. Sorry for my late reply, but i did not have time to cover this through the week.
        I updated to the latest version and disabled all other modules on my rPI.
        But none the less, it does not load the (or any other video).
        I dont see any errors:
        [2020-10-25 19:30:29.738] [LOG] Starting MagicMirror: v2.12.0
        [2020-10-25 19:30:29.749] [LOG] Loading config …
        [2020-10-25 19:30:29.758] [LOG] Loading module helpers …
        [2020-10-25 19:30:29.761] [LOG] No helper found for module: MMM-VideoPlayer.
        [2020-10-25 19:30:29.762] [LOG] All module helpers loaded.
        [2020-10-25 19:30:29.981] [LOG] Starting server on port 8080 …
        [2020-10-25 19:30:30.000] [LOG] Server started …
        [2020-10-25 19:30:30.001] [LOG] Sockets connected & modules started …
        [2020-10-25 19:30:30.145] [LOG] Launching application.
        Did already someone had success to test this on rPI?
        Or what could i do for some more debug?
        Cheers,
        Feigi
        S SnilleS 2 Replies Last reply Reply Quote 0
          sdetweil @feigi
          @feigi which version, there are 3? google search ‘mmm-videoplayer github’
          Snille’s version does not have a node_helper.js file
          the others do
          • SnilleS Offline
            Snille Module Developer @feigi
            @feigi Yes, as @sdetweil said, I’m not using a “node_helper” at all. It’s not needed for the player. It looks like it’s loading as it should. If you don’t see the video, try putting it in another region just to see if it plays. I have only tested the player on my mirror (Ubuntu server with XFCE desktop on a Intel NUC machine) and on a Ubuntu server (running in a container (LXC) then accessing the mirror from a Windows 10 machine in Chrome). And both of them are working… But I can imagine that the RPi may struggle…
            • F Offline
              feigi @Snille
              @Snille Yes, i use your Version. The content of my cloned folder on the rPI is identical to your folder on github. So i am using the same Version.
              Why its showing that its trying to load a node_helper, i have no idea. I dont even know what that is :) I just started the MM without any other modules than yours and did not see an Error and just wanted to show that.
              But its ok if this is not possible to play on a rPI. Was worth a try!
              Thanks anyway for your support and the great work! :)
                sdetweil @feigi
                @feigi said in MMM-Videoplayer - Play video files on your mirror:
                the system ALWAYS tries and reports… nothing worrisome…
                • BKeyportB Offline
                  BKeyport Module Developer
                  One minor note - in your readme on github, there’s no install instructions. I’d add that…
                  Seems to be good otherwise.
                  SnilleS 1 Reply Last reply Reply Quote 0
                  • SnilleS Offline
                    Snille Module Developer @BKeyport
                    @BKeyport Oh! Good point! I’ll fix that. Thank you! :)
                    • SnilleS Offline
                      Added a new function in v0.4. See first post…
                      • E Offline
                        elitecybernet
                        @Snille i had tried your mmm videoplayer, im curious is it no sound for playing video ?Or i need to do something on my config? I want to play with hdmi sound in my monitor.
                        thank for your support. good job
                        • SnilleS Offline
                          Snille Module Developer @elitecybernet
                          @elitecybernet Hi! Yes, default is “no sound”, because if you set it to yes, it will not “autoplay”. But you can just change the option: muted to false.
                            position: 'middle_center',
                              muted: false,
                          Like so… :)
