    MMM-COVID19-AMPEL (focus on Germany)
    Scheduled Pinned Locked Moved Health
    61 Posts 19 Posters 43.1k Views 20 Watching
      magic21nrw
      this is something especially for the German users here. The Plugin shows the Incidence Value of COVID in a coloured way in order to see which restrictions is in place at the moment. I added this module for my Mirror and would like to share this with you. Version is still Alpha, but seems to work for me.
      In Germany the public restrictions are based on a level of new infections within 7 days per 100.000 people. This is called the incidence value. Based on this figures the alert level and restrictions are given
      Green smaller or equal than 30 Incidence Value (New infections in 7 Days / 100.000 Population)
      Yellow > 30
      Red > 50
      Dark-Red > 100
      You can find the repository here:
      https://github.com/magic21nrw/MMM-COVID19-AMPEL
      I think it is pretty self explanatory and lightweight because update frequency is very low (The values only get an update once a day so there is no need to poll frequently.)
      Daniel
      • FoziF Offline
        Fozi Project Sponsor
        Thanks for sharing that module! I‘ll give it a try later.
          Solis
          Thanks for sharing. Works fine
          Is it possible to show more than one Area?
            magic21nrw @Solis
            @Solis
            Not at the moment as I made it only for the purpose of displaying one place (where I live ;-) ) at a time. But the change would not be so huge as it is pretty easy to loop through the results in the object.
            I will think about it and have a look later. Anyone else voting for this feature?
            • thgmirrorT Offline
              thgmirror
              I vote for this feature!
              But isn’t it possible to use the module twice? Rename the folder etc which is described several times here in the forum?
              Greetings
              Thomas (who needs it for Bonn and Ratingen)
              FoziF M 2 Replies Last reply Reply Quote 0
                Baraka
                cool, habe es auch im Spiegel, :-) Top!
                • FoziF Offline
                  Fozi Project Sponsor @thgmirror
                  @thgmirror That should work. I’ve done that with other modules, too.
                    magic21nrw @thgmirror
                    @thgmirror
                    @Solis
                    No need to do that. I uploaded a new Version of the module. Just replace the CityID with the “223” number with an array [“223”,“221”,“225”] and it will show the different cities below each other.
                    Daniel
                    FoziF B 3 Replies Last reply Reply Quote 2
                    • FoziF Offline
                      Fozi Project Sponsor @magic21nrw
                      @magic21nrw great! Thanks!
                        Baraka @magic21nrw
                        @magic21nrw Great Working Fine!!
                          Baraka @magic21nrw
                          @magic21nrw hi ,Vorschlag von mir du kannst noch ein Pfeilchen hoch und runter zum Vortag setzen. Dann bekommt man auch ein Gefühl , wo die Zahlen aktuell hingehen.
                            magic21nrw @Baraka
                            @Baraka
                            It would be nice to have this but the data source only supports actual data with a timestamp.
                            If I would remember the old value it would show the arrow only after the first update at midnight when new data is available. This means when rebooting the mirror once at night would reset the old value.
                            Any idea how to make a history? I could write the values in a file once it gets new values but this seems a bit of overkill for it…
                            Any ideas how to solve this easily?
                              Binog
                              Hey, nice work ! Is it possible to merly see the value instead of Time-stamp and City?? a la “red - Incidense-value - red”
                                Baraka @magic21nrw
                                @magic21nrw hi ihabe gesehen, das die Zahlen im log auch stehen, vielleicht da auslesen?
                                • L Offline
                                  lucas781
                                  Excellent work, thanks for that!
                                  As a suggestion, maybe you could add the timestamp on the header instead of close to each city? For users having more than 1 city, there is no need to see the timestamp more than once.
                                  FoziF M 2 Replies Last reply Reply Quote 1
                                  • FoziF Offline
                                    Fozi Project Sponsor @lucas781
                                    @lucas781 I’d second that proposal.
                                      magic21nrw @lucas781
                                      @lucas781
                                      @Binog
                                      I updated the module to reflect the change with the update time-stamp. You got two new configuration items now:
                                      showUpdateDateInHeader: true, //Show update date in header
                                      showUpdateDateInRow: false, //Show update date in each row
                                      so you can customise it as you like. Defaults are displayed above.
                                      @Baraka
                                      Ich bekomme von der Datenabfrage immer nur die IST Werte. Im Log wird einfach was weg geschrieben, aber keine abfragbare Historie angezeigt. Das wird ein wenig schwieriger.
                                      L B 2 Replies Last reply Reply Quote 1
                                      • L Offline
                                        lucas781 @magic21nrw
                                        @magic21nrw Thank you so much! It is even better now
                                          Baraka @magic21nrw
                                          @magic21nrw Sieht viel besser aus im Header ! :-)
                                            bjoern
                                            Kann man sich auch die Werte von Deutschland anzeigen lassen und interessant wäre der Vergleich zum Vortag.
                                            • 1 / 4
