    MMM-COVID19-AMPEL (focus on Germany)
    Scheduled Pinned Locked Moved Health
    61 Posts 19 Posters 45.9k Views 20 Watching
      Baraka
      cool, habe es auch im Spiegel, :-) Top!
      • FoziF
        Fozi Project Sponsor @thgmirror
        @thgmirror That should work. I’ve done that with other modules, too.
          magic21nrw @thgmirror
          @thgmirror
          @Solis
          No need to do that. I uploaded a new Version of the module. Just replace the CityID with the “223” number with an array [“223”,“221”,“225”] and it will show the different cities below each other.
          Daniel
          FoziF B 3 Replies Last reply
          Reply Quote 2
          • FoziF
            Fozi Project Sponsor @magic21nrw
            @magic21nrw great! Thanks!
              Baraka @magic21nrw
              @magic21nrw Great Working Fine!!
                Baraka @magic21nrw
                @magic21nrw hi ,Vorschlag von mir du kannst noch ein Pfeilchen hoch und runter zum Vortag setzen. Dann bekommt man auch ein Gefühl , wo die Zahlen aktuell hingehen.
                M 1 Reply Last reply
                  magic21nrw @Baraka
                  @Baraka
                  It would be nice to have this but the data source only supports actual data with a timestamp.
                  If I would remember the old value it would show the arrow only after the first update at midnight when new data is available. This means when rebooting the mirror once at night would reset the old value.
                  Any idea how to make a history? I could write the values in a file once it gets new values but this seems a bit of overkill for it…
                  Any ideas how to solve this easily?
                  B 1 Reply Last reply
                    Binog
                    Hey, nice work ! Is it possible to merly see the value instead of Time-stamp and City?? a la “red - Incidense-value - red”
                      Baraka @magic21nrw
                      @magic21nrw hi ihabe gesehen, das die Zahlen im log auch stehen, vielleicht da auslesen?
                      • L
                        lucas781
                        Excellent work, thanks for that!
                        As a suggestion, maybe you could add the timestamp on the header instead of close to each city? For users having more than 1 city, there is no need to see the timestamp more than once.
                        FoziF M 2 Replies Last reply
                        • FoziF
                          Fozi Project Sponsor @lucas781
                          @lucas781 I’d second that proposal.
                            magic21nrw @lucas781
                            @lucas781
                            @Binog
                            I updated the module to reflect the change with the update time-stamp. You got two new configuration items now:
                            showUpdateDateInHeader: true, //Show update date in header
                            showUpdateDateInRow: false, //Show update date in each row
                            so you can customise it as you like. Defaults are displayed above.
                            @Baraka
                            Ich bekomme von der Datenabfrage immer nur die IST Werte. Im Log wird einfach was weg geschrieben, aber keine abfragbare Historie angezeigt. Das wird ein wenig schwieriger.
                            L B 2 Replies Last reply
                            • L
                              lucas781 @magic21nrw
                              @magic21nrw Thank you so much! It is even better now
                                Baraka @magic21nrw
                                @magic21nrw Sieht viel besser aus im Header ! :-)
                                  bjoern
                                  Kann man sich auch die Werte von Deutschland anzeigen lassen und interessant wäre der Vergleich zum Vortag.
                                    magic21nrw @bjoern
                                    @bjoern
                                    Wenn die Datenbank Deutschland gesamt enthält, einfach den Code als Stadt eingeben. Dann geht es.
                                    Selbst im Modul alle Städte aufzuaddieren sind zu viele Daten, die dann abgefragt werden müssten, das macht recht wenig sinn und das Modul nur schwergängig.
                                    Der Vergleich zum Vortag ist auf Grund der Datenbasis (keine Historie in der Datenbank) leider nicht möglich.
                                    • thgmirrorT
                                      thgmirror
                                      One Option may be to implement the following link:
                                      https://www.freenet.de/feed/dashboard/corona_startseite.html
                                      Greetings
                                      Thomas
                                        Baraka @magic21nrw
                                        @magic21nrw hi, im Moment funktioniert die Datenquelle nicht, das modul ist nicht zu sehen.
                                          magic21nrw @Baraka
                                          @Baraka
                                          Das stimmt, es gibt eine Störung bei der Datenbank. Wenn die Störung behoben ist, wird wieder ein Update kommen.
                                          Bei mir steht noch der Wert von Gestern mit 3.11.
                                            rantanplan
                                            Hallo,
                                            vielen Dank erst mal für diese geniale Modul.
                                            Besteht vielleicht die Möglichkeit die “Balken” rechts und links zu verkleinern, vielleicht auch nur einen darzustellen, rechts oder links?
                                            Mein MM2 läuft auf einem 7" Monitor, da ist recht wenig Platz.
                                            Vielen Dank schonmal
                                            rantanplan
                                            • 1 / 4
