    MMM-Astrology font color
    12 Posts 4 Posters 6.5k Views 4 Watching
    • justjim1220J
      justjim1220 Module Developer
      had to edit my first post, Apologies!
      Jim Hallock - 1995
      • L
        letmetakeaselfie
        thanks for the quick reply however that didn’t change the font color for me :/
        justjim1220J cowboysdudeC 2 Replies Last reply
        • justjim1220J
          justjim1220 Module Developer @letmetakeaselfie
          @letmetakeaselfie
          Strange, It works for me.
          And, you made the cahnge in the MMM-Astrology.css file?
          Or, ADD the full code snippet to your custom.css file
          Either way should work!
          Jim Hallock - 1995
          • cowboysdudeC
            cowboysdude Module Developer @letmetakeaselfie
            @letmetakeaselfie I wrote MMM-Astrology… do this… in your custom.css
            It worked for the title because there’s a class for that called ‘title’, I just edited it on github and added a class for description called ‘desc’
            Now you can go into your custom.css file like this:
            call your font [put this in the top of your custom.css file]
            @font-face {
            font-family: “DancingScript”;
            src:
            url(DancingScript-Regular.ttf) format(“truetype”);
            .MMM-Astrology .desc{
            font-family: DancingScript-Regular;
            color: blue;
            .MMM-Astrology .title{
            color: purple;
            justjim1220J 1 Reply Last reply
            • justjim1220J
              justjim1220 Module Developer @cowboysdude
              @cowboysdude
              the content is the same as the description, it changed color for me by just changing that part of the css
              Jim Hallock - 1995
              • cowboysdudeC
                cowboysdude Module Developer @justjim1220
                @justjim1220 NEVER advise ANYONE to change a css file, that is what the custom.css is for.
                And no your answer will not work… there are two different classes…one for title and one for description… IF he’s using the MMM-Astrology module I wrote…
                justjim1220J 2 Replies Last reply
                • justjim1220J
                  @cowboysdude
                  Sorry, I thought that was the reason for the css files, to make the changes to suit your needs.
                  I usually add to the custom.css file after I figure out what does what.
                  My apologies! :worried_face:
                  Jim Hallock - 1995
                  • justjim1220J
                    @cowboysdude
                    what is the content class in the css file?
                    Just curious, because that is how I figured out how to change the color of the description content…
                    gives me this…
                    and this…
                    gives me this…
                    When I go to figure out how things work, I make changes to the css file, then move it to my custom.css file, leaving the original intact. I was told to do it this way way back when I first started doing this. I guess I wasn’t told that changing the original was taboo, although, I have always felt I needed to keep the original intact to go back to just ‘in case’.
                    I was told this was the best way to learn, to play with things. Which I do. And if someone asks a question that I have had some experience with, I tend to return the help given to me by you and all the others who have been so awesome and patient with me.
                    I won’t give that advise anymore, I really am sorry, :pensive_face:
                    Jim Hallock - 1995
                    X 1 Reply Last reply
                    • L
                      letmetakeaselfie
                      That worked thank you both very much!
                      • X
                        Xoni @justjim1220
                        @justjim1220 said in MMM-Astrology font color:
                        @cowboysdude
                        gives me this…
                        and this…
                        gives me this…
                        sorry to revive an old thread,
                        #1 the css does work to change colors. thank you…
                        #2 how in the hell did you get your hscope to look that way i like it a lot.
