    "absolute" does not mean absolute in default calendar module
    20 Posts 4 Posters 3.9k Views 4 Watching
    • AlvingerA Offline
      Alvinger @sdetweil
      @sdetweil the latest development version solved the offset problem for me. As far as the “absolute” problem I rewrote the relevant section of calendar.js. As I have already forked MagicMirror to make it run on my IOS 9.3.5 Ipads I can’t submit a PR (at least I don’t know exactly how to do that) but would be happy to send you the calendar.js file.
      There is still a problem with full day recurring events.
      I can PM you a link to a relevant public (but inofficial) calendar with the issues.
        sdetweil @Alvinger
        @Alvinger ok. the latest fixes, Monday did address full day recurring
        I would be happy to see the cal
        • BKeyportB Offline
          BKeyport Module Developer
          Absolute isn’t absolute, without other tags…
          getRelative and urgency also need to be set.
          // Force Absolute to Absolute all the time, michmich *really* hates solid dates, apparently.
          timeformat: "absolute",
          getRelative: 0,
          urgency: 0 ,
          AlvingerA 1 Reply Last reply Reply Quote 0
            A Former User
            AlvingerA 2 Replies Last reply Reply Quote 0
            • AlvingerA Offline
              Alvinger @Guest
              @hango correct, that’s all I did. But I changed it in all MM files. If I just knew exactly which files are executed in the browser I could have changed just those. As the iPads require a server (which can handle the latest ES) one only needs to change the browser-executed files.
              • AlvingerA Offline
                Alvinger @BKeyport
                @BKeyport well almost! I have this exact config but running events are still changed to “ends in xx min”! And all day events still shows as “today”
                I’ve done a rewrite of the relevant section of calendar.js but can’t use my github clone repo to make a PR.
                  sdetweil @Alvinger
                  @Alvinger u needed to.make a fork, and then clone that. fork button is upper right
                  • AlvingerA Offline
                    Alvinger @sdetweil
                    @sdetweil I know. But I have already forked the MM master and made changes to use my Ipad 2. How do I make a new branch containing the latest MM development files? My plan was to wait until the new version was merged into Master and then do my Ipad2-related changes. Github won’t allow me to have multiple repositories with the same name.
                    • AlvingerA Offline
                      Alvinger
                      @sdetweil I have created a PR for the proposed calendar changes.
                        sdetweil @Alvinger
                        @Alvinger what branch did u use when u made your changes?
