    MMM-awesome-alexa
    241 Posts 43 Posters 452.9k Views 47 Watching
    • A
      aclertant
      Yes I know ;)
      • A
        aclertant
        BTW is this new alexa instance will appear in my alexa app ? as a dot or something very similar ?
        The idea is to know if I could control this new alexa as usual with my homeAssistant and nodered :)
        • G
          Ghost2000
          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
          0|MagicMir | [2020-10-19 14:17:29.092] [ERROR]  (node:1019) [DEP0005] Deprecatio        nWarning: Buffer() is deprecated due to security and usability issues. Please us        e the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|MagicMir | [2020-10-19 14:17:29.093] [ERROR]  (node:1019) [DEP0005] Deprecatio        nWarning: Buffer() is deprecated due to security and usability issues. Please us        e the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|MagicMir | [2020-10-19 14:17:29.939] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Error: [object Object]
          0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.j        s:1:6073
          0|MagicMir |     at processTicksAndRejections (internal/process/task_queues.js:8        9:5)
          0|MagicMir | [2020-10-19 14:17:29.940] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Error: [object Object]
          0|MagicMir | [2020-10-19 14:17:29.941] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 1)
          0|MagicMir | [2020-10-19 14:17:29.942] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 1)
          0|MagicMir | [2020-10-19 14:17:29.942] [ERROR]  (node:1019) [DEP0018] Deprecatio        nWarning: Unhandled promise rejections are deprecated. In the future, promise re        jections that are not handled will terminate the Node.js process with a non-zero        exit code.
          0|MagicMir | [2020-10-19 14:17:29.943] [ERROR]  (node:1019) [DEP0018] Deprecatio        nWarning: Unhandled promise rejections are deprecated. In the future, promise re        jections that are not handled will terminate the Node.js process with a non-zero        exit code.
          0|MagicMir | [2020-10-19 23:45:02.464] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
          0|MagicMir | [2020-10-19 23:45:10.761] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
          0|MagicMir | [2020-10-19 23:45:18.513] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
            sdetweil @Ghost2000
            @Ghost2000 you will have to redo the code process as it as expired
            • G
              Ghost2000
              O
              How can I prevent this?
              How long is the code valid?
                sdetweil @Ghost2000
                @Ghost2000 the code is valid for 24 hours… MM has to be running all the time so it can fresh the token
                • G
                  Ghost2000
                    bsisco95
                    For some reason the wake word “Jarvis” will not work for me. Both “Alexa” and “Smart Mirror” do work when changed in the config file. Anyone else had this problem and know how to fix it? Thanks!
                      JonatanPN
                      After many attempts, I managed to install MMM-awesome-alexa, but I have a problem, no device from my account appears. I have tried saying “Alexa, search devices” it says it will search but then it says nothing.
                      If I try to run routines they don’t exist either, however from the Alexa application for my mobile, I can run routines, control devices and also, in the list of devices I see that “Jonatan’s Magic_Mirror_Alexa” appears although as offline.
                      It is as if it were an account with another profile, since it does not show devices or routines. But it works fine for the rest like asking the time and other information.
                      I tried creating a new amazon account but the same thing happens.
                      Does anyone know what can I do? 😔
                        rguardaya2008
                        Guys can somebody help me…
                        i tried installing this module into my magic mirror and i have been following the step by step process and i am already in the part were i already received the full config with refreshToken. However, when i tried to encode it in the config and restarts the magic mirror it only shows black/blank screen. please somebody help me what to do next…
                          sdetweil @rguardaya2008
                          @rguardaya2008 look in the console window were u start magic mirror , npm start or pm2,
                          if pm2, use the pm2 logs --lines=??? command (??? is 15 by default)
                          also, open the developers window, ctrl-shift-i,
                          and select the console tab and scroll up…
                          I made a script of the steps for the install , and there as a missing piece, which the scrip corrects
                          u can download it, make it executable, and it will do the whole install steps… (but not the auth step u just did, so keep that)
                          https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
                          R 1 Reply Last reply
                            rguardaya2008 @sdetweil
                            @sdetweil thank you! i did the step by step process you showed me and when i run it magic mirror was just running fine not like the black/blank screen like before. however i cannot find the alexa on it.
                              @rguardaya2008 u have to speak, alexa…
                                @sdetweil i think i have a problem with my mic… i tried troubleshooting but i get the same reply “rec WARN alsa: can’t encode 0-bit Unknown or not applicable
                                rec FAIL formats: can’t open input `default’: snd_pcm_open error: No such file or directory” when i record…
                                  @rguardaya2008 arecord -l
                                  will list the devices
                                  arecord -D plughw:card#:0 test.wav
                                  speak some words
                                  ctrl-c to end record
                                  aplay test.wav, do you hear your words?
                                  but if the mic is bad, nothing software can do to fix it…
                                    @sdetweil thank you for guiding me so far… i was able to record and play using the codes you gave me, the mic seems to be fine. however, still i cannot open alexa on my MM. what did i miss?
                                      @rguardaya2008 sorry. I do not know.
                                        stalker401
                                        So i’m at the point in the set pu where it’s saying “Getting response from Amazon…”, but it’s been going for like 30 mins. Any ideas on how long this should take, or did i probably make a mistake above?
                                          sdetweil @stalker401
                                          @stalker401 should be fairly instant.
                                            stalker401 @sdetweil
                                            @sdetweil Thanks, i’m not sure what i did wrong, but it helps to know that it should be quick
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
