    MMM-awesome-alexa
    241 Posts 43 Posters 438.6k Views 47 Watching
      sdetweil @Ghost2000
      @Ghost2000
      sheesh
      node config-helper.js
      • G Offline
        Ghost2000
        i have see :D
        • G Offline
          Ghost2000
          Es kamm ein Weißer Punkt in der Mitte .
          pi@MagicMirror:~ $ pm2 log MagicMirror
          [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
          /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
          0|MagicMir | [2020-10-10 21:53:01.834] [LOG]    Connecting socket for: updatenotification
          0|MagicMir | [2020-10-10 21:53:01.835] [LOG]    Connecting socket for: MMM-awesome-alexa
          0|MagicMir | [2020-10-10 21:53:01.837] [LOG]    Connecting socket for: calendar
          0|MagicMir | [2020-10-10 21:53:01.837] [LOG]    Starting node helper for: calendar
          0|MagicMir | [2020-10-10 21:53:01.838] [LOG]    Connecting socket for: newsfeed
          0|MagicMir | [2020-10-10 21:53:01.839] [LOG]    Starting node helper for: newsfeed
          0|MagicMir | [2020-10-10 21:53:01.840] [LOG]    Sockets connected & modules started ...
          0|MagicMir | [2020-10-10 21:53:01.923] [LOG]    Launching application.
          0|MagicMir | [2020-10-10 21:53:04.573] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/public/basic.ics - Interval: 300000
          0|MagicMir | [2020-10-10 21:53:04.587] [LOG]    Create new news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
          0|MagicMir | [2020-10-10 21:53:04.639] [INFO]   Checking git for module: MMM-awesome-alexa
          0|MagicMir | [2020-10-10 21:53:05.080] [INFO]   Newsfeed-Fetcher: Broadcasting 49 items.
          0|MagicMir | [2020-10-10 21:53:18.720] [LOG]    transiting to state: listening
          0|MagicMir | [2020-10-10 21:53:24.107] [LOG]    transiting to state: busy
          0|MagicMir | [2020-10-10 21:53:24.641] [LOG]    transiting to state: idle
          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
          0|MagicMir | [2020-10-10 21:47:03.578] [ERROR]  (node:955) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
          0|MagicMir | [2020-10-10 21:47:03.579] [ERROR]  (node:955) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          0|MagicMir | [2020-10-10 21:47:03.580] [ERROR]  (node:955) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          0|MagicMir | [2020-10-10 21:53:05.121] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/public/basic.ics 404: Not Found
          0|MagicMir | [2020-10-10 21:53:05.401] [ERROR]  (node:2042) UnhandledPromiseRejectionWarning: Error: [object Object]
          0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js:1:6073
          0|MagicMir |     at processTicksAndRejections (internal/process/task_queues.js:89:5)
          0|MagicMir | [2020-10-10 21:53:05.402] [ERROR]  (node:2042) UnhandledPromiseRejectionWarning: Error: [object Object]
          0|MagicMir | [2020-10-10 21:53:05.403] [ERROR]  (node:2042) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
          0|MagicMir | [2020-10-10 21:53:05.403] [ERROR]  (node:2042) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          0|MagicMir | [2020-10-10 21:53:05.404] [ERROR]  (node:2042) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          0|MagicMir | [2020-10-10 21:53:24.640] [ERROR]  {"error":{"code":"com.amazon.alexahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able to validate the provided access token."}}
            aclertant
            Hello guys @sdetweil @Ghost2000 ,
            You are fighting hard :o) Thanks a lot this is usefull !
            To distract you lol is there a way to command a blue led ribbon like seen in some videos ? Of course the best way for a noob like me would be a gpio pin to choose in the config… but as the git module is dead, looks impossible right ?
            Thanks in advance
              sdetweil @aclertant
              @aclertant so it would seem. the code is very hard to work with. I am not the author, just trying to help
                aclertant
                Yes I know ;)
                  aclertant
                  BTW is this new alexa instance will appear in my alexa app ? as a dot or something very similar ?
                  The idea is to know if I could control this new alexa as usual with my homeAssistant and nodered :)
                  • G Offline
                    Ghost2000
                    0|MagicMir | [2020-10-19 14:17:29.092] [ERROR]  (node:1019) [DEP0005] Deprecatio        nWarning: Buffer() is deprecated due to security and usability issues. Please us        e the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                    0|MagicMir | [2020-10-19 14:17:29.093] [ERROR]  (node:1019) [DEP0005] Deprecatio        nWarning: Buffer() is deprecated due to security and usability issues. Please us        e the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                    0|MagicMir | [2020-10-19 14:17:29.939] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Error: [object Object]
                    0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.j        s:1:6073
                    0|MagicMir |     at processTicksAndRejections (internal/process/task_queues.js:8        9:5)
                    0|MagicMir | [2020-10-19 14:17:29.940] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Error: [object Object]
                    0|MagicMir | [2020-10-19 14:17:29.941] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 1)
                    0|MagicMir | [2020-10-19 14:17:29.942] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 1)
                    0|MagicMir | [2020-10-19 14:17:29.942] [ERROR]  (node:1019) [DEP0018] Deprecatio        nWarning: Unhandled promise rejections are deprecated. In the future, promise re        jections that are not handled will terminate the Node.js process with a non-zero        exit code.
                    0|MagicMir | [2020-10-19 14:17:29.943] [ERROR]  (node:1019) [DEP0018] Deprecatio        nWarning: Unhandled promise rejections are deprecated. In the future, promise re        jections that are not handled will terminate the Node.js process with a non-zero        exit code.
                    0|MagicMir | [2020-10-19 23:45:02.464] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
                    0|MagicMir | [2020-10-19 23:45:10.761] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
                    0|MagicMir | [2020-10-19 23:45:18.513] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
                      sdetweil @Ghost2000
                      @Ghost2000 you will have to redo the code process as it as expired
                      • G Offline
                        Ghost2000
                        O
                        How can I prevent this?
                        How long is the code valid?
                          sdetweil @Ghost2000
                          @Ghost2000 the code is valid for 24 hours… MM has to be running all the time so it can fresh the token
                          • G Offline
                            Ghost2000
                              bsisco95
                              For some reason the wake word “Jarvis” will not work for me. Both “Alexa” and “Smart Mirror” do work when changed in the config file. Anyone else had this problem and know how to fix it? Thanks!
                                JonatanPN
                                After many attempts, I managed to install MMM-awesome-alexa, but I have a problem, no device from my account appears. I have tried saying “Alexa, search devices” it says it will search but then it says nothing.
                                If I try to run routines they don’t exist either, however from the Alexa application for my mobile, I can run routines, control devices and also, in the list of devices I see that “Jonatan’s Magic_Mirror_Alexa” appears although as offline.
                                It is as if it were an account with another profile, since it does not show devices or routines. But it works fine for the rest like asking the time and other information.
                                I tried creating a new amazon account but the same thing happens.
                                Does anyone know what can I do? 😔
                                  rguardaya2008
                                  Guys can somebody help me…
                                  i tried installing this module into my magic mirror and i have been following the step by step process and i am already in the part were i already received the full config with refreshToken. However, when i tried to encode it in the config and restarts the magic mirror it only shows black/blank screen. please somebody help me what to do next…
                                    sdetweil @rguardaya2008
                                    @rguardaya2008 look in the console window were u start magic mirror , npm start or pm2,
                                    if pm2, use the pm2 logs --lines=??? command (??? is 15 by default)
                                    also, open the developers window, ctrl-shift-i,
                                    and select the console tab and scroll up…
                                    I made a script of the steps for the install , and there as a missing piece, which the scrip corrects
                                    u can download it, make it executable, and it will do the whole install steps… (but not the auth step u just did, so keep that)
                                    https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
                                      rguardaya2008 @sdetweil
                                      @sdetweil thank you! i did the step by step process you showed me and when i run it magic mirror was just running fine not like the black/blank screen like before. however i cannot find the alexa on it.
                                        @rguardaya2008 u have to speak, alexa…
                                          @sdetweil i think i have a problem with my mic… i tried troubleshooting but i get the same reply “rec WARN alsa: can’t encode 0-bit Unknown or not applicable
                                          rec FAIL formats: can’t open input `default’: snd_pcm_open error: No such file or directory” when i record…
                                            @rguardaya2008 arecord -l
                                            will list the devices
                                            arecord -D plughw:card#:0 test.wav
                                            speak some words
                                            ctrl-c to end record
                                            aplay test.wav, do you hear your words?
                                            but if the mic is bad, nothing software can do to fix it…
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
