    Weather Module struggles
    3 Posts 3 Posters 651 Views 3 Watching
    • ankonaskiff17A
      ankonaskiff17
      I gave the weather module a try and while I can get it to show the current weather, I can not get it to show the 5 day forecast after numerous changes. The page dedicated to this module says just use the module twice and and that is what I did, in addition to using weathergov as data source.
      I looked at the weather.js code and I am not great at reading code but it seems like there is no code to adjust in config.js
      For example there is a line
      timeFormat: config.timeFormat in weather.js
      Then this in config.js timeFormat: 12,
      The wiki?? page tells about the different options such as current, forecast, and daily as configuration items but again, I can’t find a corresponding lines in weather.js to result in image on page.
      As an aside to that, it looks like when placed in middle_center it is thinking it is in one of the X_third configurations as it draws a line full screen width under the location text. top_center and bottom_center draw the line correctly under location text.
      J 1 Reply Last reply
        jamaces @ankonaskiff17
        @ankonaskiff17
        these settings might help
        type: “daily”
        weatherEndpoint: “/onecall”,
        I could not get the 5day to work, kept on saying loading.
          sdetweil @jamaces
          @jamaces as i recall, there is a different apikey for 5 day…
