    MMM-UKNationalRail - Rail departure info for specific UK Railway stations
    uk railtransport
    33 Posts 15 Posters 24.1k Views 16 Watching
    • F Offline
      funk0id
      Absolutely love this plugin, just wish it was still being improved :(
        dawookie1979
        Hello, i have the module working, i just cant get it to display the title.
        module: ‘MMM-UKNationalRail’,
        position: ‘bottom_left’,
        header: ‘Whittlesford Parkway’, //Optional - delete this line to turn OFF the header completely
        stationCode: ‘WLF’, // CRS code for station
        app_id: ‘xxxxxxxx’, // TransportAPI App ID
        app_key: ‘xxxxxxxxxx’, // TransportAPI App Key
        maxResults: 5, //Optional - Maximum results to display.
        showOrigin: false //Optional - Show the origin of the train in the table
        any ideas?
          sdetweil @dawookie1979
          @dawookie1979 u mean the header?
            dawookie1979
            yes the header is not showing
            • T Offline
              tenpinmark
              Does anyone have a multi-station configuration working? I also do not get any headers showing - anyone managed to solve that one?
              Thanks in advance
                Bob
                Headers have been broken for a while now. Happened after MM version update. Not sure if @nwootton is still working on this or not though.
                Also not been able to get multi-station working. The fix I used was just to have 2 modules listed one after each other (ie, duplicate the code in the config file, including API etc). That seems to work fine.
                • T Offline
                  tenpinmark
                  Hi Bob,
                  Thanks for the information. I’ve been playing and have fixed up the header not being shown and in addition have added column headings such as "Platform, To, From, Planned, Actual and Status to the displayed table.
                  I have seen in the forums elsewhere you do have to have multiple modules in order to get multiple stations which I suppose is OK, but a bit awkward. I may have a look to see if this can be all rolled into one config section.
                  One other feature I would like to work on is this: My partner travels home eveyday and says what train she is on, but never knows what time it will arrive at our home station - I want to see if it is possible to have a a listing of the possible trains with the departue and arrival times. As I’m very new to all this, it’s going to hurt my head coding it I suspect.
                  • G Offline
                    Glass92 @tenpinmark
                    @tenpinmark
                    Hi Tenpin,
                    Sounds like me and you want the same thing!
                    I’m currently having issues with my module updating after a refresh though, don’t know what is going on there! Essentially after I restart the Mirror, the module will work for a couple of hours, then when I get up the next day it will still be showing last nights times, almost like it’s frozen.
                    How did you get the Header sorted and column headings?
                    I am also using MMM-ModuleScheduler to display the specific Trains at different times.
                    I have three modules running see below, where my app id and app key I have replaced with xxx.
                    One for my partner, Monday to Friday from Home to Work in the morning. Stirling - Dundee (See Station Code is Stirling, calling_at: Dundee)
                    One for my partner, Monday to Friday from Work to Home in the evening. Dundee - Stirling (See Station Code is Stirling, called_at: Dundee)
                    One for me, Tuesday to Thursday from Home to Work in the morning. Stirling - Glasgow (See Station Code is Stirling, calling_at: Glasgow)
                    			module: 		'MMM-UKNationalRail',
                    			position: 		'bottom_left',
                    			header:			'Stirling - Glasgow',		//Optional - delete this line to turn OFF the header completely
                    			classes: 'scheduler',
                    				module_schedule: {from: '0 7 * * 2-4', to: '0 9 * * 2-4' },
                    				stationCode: 		'STG', 		// CRS code for station
                    				calling_at: 		'GLQ',
                    				app_id: 			'xxx', 		// TransportAPI App ID
                    				app_key: 			'xxx', 		// TransportAPI App Key
                    				maxResults: 		3,  		//Optional - Maximum results to display.
                    				showOrigin: 		true   	//Optional - Show the origin of the train in the table
                    			header:			'Stirling - Dundee',		//Optional - delete this line to turn OFF the header completely
                    				module_schedule: {from: '0 7 * * 1-5', to: '0 9 * * 1-5' },
                    				calling_at: 		'DEE',
                    			header:			'Dundee to Stirling',		//Optional - delete this line to turn OFF the header completely
                    				module_schedule: {from: '0 17 * * 1-5', to: '30 19 * * 1-5' },
                    				called_at: 			'DEE',
                    This is my partner’s trians for coming home
                    https://imgur.com/a/OGflgLi
                    See it doesn’t list Stirling. It lists end destination and origin station.
                      Bob
                      @tenpinmark Any chance you can post the code you used to fix it ? (or submit a fork to switch to instead)
                      @Glass92 I had similar problems (and only with this module). My solution was to create a cron job to reboot the mirror after midnight, which restarted the code. It’s not ideal, and actually introduces other issues with the HDMI port (will sometimes fail to initialise the display). I’ve since removed the cron job, and now just manually reboot if needed (usually once every couple of days)
                        alexbell62
                        Is there a way to make it work?
                          matt216
                          Getting emails from transportapi.com saying I’m over my call limit. Anyone else?
                            matt216
                            Looks like transportAPI.com has changed their free tier to just 30 calls per day. This module (for me) seems to have used almost 300 per day previously.
                            Also it doesn’t look like the module is maintained by the developer anymore.
                            1 Reply Last reply Reply Quote -1
                              Bungle68
                              Is anyone able to show how I can get arrivals as well as departures showing?
                              I tried this, but it’s still only showing Departures.
                              	header:		'Departure',		//Optional - delete this line to turn OFF the header completely
                              		stationCode: 		'CUF', 		// CRS code for station
                              		app_id: 		'8e9c6489', 	// TransportAPI App ID
                              		app_key: 		'd8*********************7c9c45550', 	// TransportAPI App Key
                              		showOrigin: 		false,   	//Optional - Show the origin of the train in the table
                              		type: "arrival,departure"
                                sdetweil @Bungle68
                                @Bungle68 it appears this module is no longer maintained, and most of the code is 6 years old.
                                wko knows what has changed in that time
                                  Bungle68 @sdetweil
                                  @sdetweil Thanks
                                  It seems to be working now, I just can’t get the platform numbers up.
                                  Is there an alternative module? 🙏
                                    sdetweil @Bungle68
                                    @Bungle68 sorry, no idea
                                      sdetweil @Bungle68
                                      @Bungle68 what shows for showPlatform:true??
                                      says - if no platform info
