    MMM-SpeedTest Fails to Install
    4 Posts 2 Posters 603 Views 2 Watching
    • mumblebajM Offline
      mumblebaj Module Developer
      Hi @Bugsounet Thanks for the great module but I am having issues with installing the above module. I managed to install it fine on my Laptop running Ubuntu on Windows. When I tried to install it on my Raspberry Pi 3B+ I get an error. The error I get right at the end of the install is as follows:
      8734 silly lifecycle MMM-SpeedTest@1.0.0~postinstall: Args: [ '-c',
      8734 silly lifecycle   'echo \'Building SpeedTest module, please wait...\' && electron-rebuild 2>/dev/null >/dev/null' ]
      8735 silly lifecycle MMM-SpeedTest@1.0.0~postinstall: Returned: code: 1  signal: null
      8736 info lifecycle MMM-SpeedTest@1.0.0~postinstall: Failed to exec postinstall script
      8737 verbose stack Error: MMM-SpeedTest@1.0.0 postinstall: `echo 'Building SpeedTest module, please wait...' && electron-rebuild 2>/dev/null >/dev/null`
      8737 verbose stack Exit status 1
      8737 verbose stack     at EventEmitter.<anonymous> (/home/pi/.npm-global/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      8737 verbose stack     at EventEmitter.emit (events.js:180:13)
      8737 verbose stack     at ChildProcess.<anonymous> (/home/pi/.npm-global/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      8737 verbose stack     at ChildProcess.emit (events.js:180:13)
      8737 verbose stack     at maybeClose (internal/child_process.js:936:16)
      8737 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:220:5)
      8738 verbose pkgid MMM-SpeedTest@1.0.0
      8739 verbose cwd /home/pi/MagicMirror/modules/MMM-SpeedTest
      8740 verbose Linux 4.14.52-v7+
      8741 verbose argv "/usr/bin/node" "/home/pi/.npm-global/bin/npm" "install"
      8742 verbose node v9.11.2
      8743 verbose npm  v6.14.8
      8744 error code ELIFECYCLE
      8745 error errno 1
      8746 error MMM-SpeedTest@1.0.0 postinstall: `echo 'Building SpeedTest module, please wait...' && electron-rebuild 2>/dev/null >/dev/null`
      8746 error Exit status 1
      8747 error Failed at the MMM-SpeedTest@1.0.0 postinstall script.
      8747 error This is probably not a problem with npm. There is likely additional logging output above.
      8748 verbose exit [ 1, true ]
      I tried uploading the full log but keep getting an error.
        [[global:former-user]] @mumblebaj
        @mumblebaj hi, I see your log and I have see very old version of node and npm.
        Again I see an old Linux firmware. Try to update your rpi ;)
        mumblebajM 2 Replies Last reply Reply Quote 0
          mumblebaj Module Developer @Guest
          @Bugsounet Thanks for the response. Will update and try again.
            @Bugsounet Updated and it now works fine. Thanks @Bugsounet
