    Display waste bins in color
    52 Posts 3 Posters 19.6k Views 3 Watching
      ashishtank Module Developer @kusselin
      @kusselin Hi it is possible with both JavaScript and CSS. Based on bin type you can either create css class like .biobin or .residualbin and in that class have image background of that bin type or you can directly assign image source to bin type. It would be easier if you post some code here…
      Below is quick example with .css
      body {
         background-color: #cccccc;
      .bin{
      height:350px;
      width:300px;
      background-size: cover;
      .biobin{
      background-image: url("https://cdn0.iconfinder.com/data/icons/garbage-items-cartoon-style/512/al396_14-512.png");
      .residualbin {
      background-image: url("https://safe.onoffmarket.com/data/item/201201/1325650700_l1")
      < div class=" bin biobin">bio bin
      < /div>
      < div class="bin residualbin"> residual bin
      < /div>
      • kusselinK Offline
        kusselin
        @ashishtank said in Display waste bins in color:
        Hello, thank you for the info!
        What code should I post? what you write here is great with the bins … it looks a bit like Fhem.
        Where does that have to go? ind the costum.css?
        Greeting
        The standard Google calendar then shows, for example, “in 23 days” and you can then display the text in blue, for example, for the glass box … gray for residual waste and green for paper ??
          @kusselin can you post screenshot of what you have right now ? If you have created your own module then it will go into that module’s css. if you are using other module and want to display it over there then you can put it in custom.css.
          Here logic is based on data you need to assign the css class to html elements and then they will show the visuals.
          • kusselinK Offline
            kusselin
            hi ashistank,
            i have the standard calender what come with MagicMirror when you install it.
            there you see now…
            Biotonne…in 5 Tagen
            Restmüll…in 10 Tagen
            and the font i will not in white…i will Biotonne in brown and Restmüll the colour in grey
            what musst i do in what css item??
            Best regards
            here a picture…glasbox the font in blue bio in brown rest in grey paper in green…what must i do in what css?
            Abfallkalender
              @kusselin Hi it is already possible with default calendar module. Sorry was not aware of that feature. while looking at code I found that you can configure your custom class and font color based on title of the event using custom events property in config.
              	header: "NL Holidays",
              				symbol: "calendar-check",
              				url: "webcal://www.calendarlabs.com/ical-calendar/ics/101/Netherlands_Holidays.ics",
              		customEvents: [
              				"keyword": "Christmas Day",
              				"symbol": "calendar-icon-christmas",
              				"color": "red"
              				"keyword": "Easter Sunday",
              				"symbol": "calendar-icon-easter",
              				"color": "blue"
              you will need to add below css classes in custom.css, Make sure to name your css class with .fa- but while adding it in config remove it. in above config symbols calendar-icon-christmas and calendar-icon-easter are css classes with out .fa-
              .fa-calendar-icon-christmas
              	background-image: url('https://cdn.iconscout.com/icon/premium/png-256-thumb/christmas-ball-1429333-1209909.png');
              	width: 20px;
              	height: 20px;
              	background-size: contain;
              	background-repeat: no-repeat;
              .fa-calendar-icon-easter
              	background-image: url('https://icons.iconarchive.com/icons/iconka/easter-egg-bunny/256/green-love-icon.png');
              	width: 20px;
              	height: 20px;
              below should be output. Same way you can do it for different bins based on title of the event (Biotonne or Restmüll)
              • kusselinK Offline
                kusselin
                Hi I will get back to you on this, it will not possible with only css but you also need to do some changes in javascript file to assign correct css class to the first checbox icon based on the bin type text.
                ohjeee o.k. thank you very much
                  @kusselin Edited my answer above.
                  • kusselinK Offline
                    kusselin
                    Hi very thanks to you for the css… but i will only that the text an the standard icon for calender like in my photo is in the color…you know what i mean? No fa-icon in the christmas look …
                    best regards
                      @kusselin Sorry I did not understand. do you want to have standard icons but with different color for icon and text ?
                      • kusselinK Offline
                        kusselin
                        yes so is it!
                        • 1 / 6
