    Display waste bins in color
    52 Posts 3 Posters 26.4k Views 3 Watching
    • kusselinK
      kusselin
      Hi very thanks to you for the css… but i will only that the text an the standard icon for calender like in my photo is in the color…you know what i mean? No fa-icon in the christmas look …
      best regards
      • A
        ashishtank Module Developer @kusselin
        @kusselin Sorry I did not understand. do you want to have standard icons but with different color for icon and text ?
        • kusselinK
          kusselin
          @ashishtank said in Display waste bins in color:
          yes so is it!
          • A
            @kusselin Sorry was occupied with something. The symbol is optional, if you do not provide it then it will take the default icon.
            Below is my config and output, Notice the new year’s day.
            customEvents: [
            		"keyword": "Christmas Day",
            		"symbol": "calendar-icon-christmas",
            		"color": "red"
            		"keyword": "New Year's Day",
            		"color": "yellow"
            		"keyword": "Easter Sunday",
            		"symbol": "calendar-icon-easter",
            		"color": "blue"
            2020-12-21-22-54-04-Clipboard
            • kusselinK
              kusselin
              Hi no problem … I want something … thank you very much.
              But does the config have to be copied into the custom.css or the normal css?
              EDIT: I have this copied in my costum .css but the colours are not displayed :-)
              what make i wrong?
               * Magic Mirror                                      *
               * Custom CSS                                        *
               * By Michael Teeuw http://michaelteeuw.nl           *
               * MIT Licensed.                                     *
               * Add any custom CSS below.                         *
               * Changes to this files will be ignored by GIT. *
               body {
                 zoom: 70%;
                 margin: 5px;
                position: absolute;
                height: calc(100% - 10px);
                width: calc(100% - 10px);
              customEvents: [
              		"keyword": "Grüne Tonne plus",
              		"color": "green"
              		"keyword": "Biomüll",
              		"color": "brown"
              		"keyword": "Restmüll",
              		"color": "gray"
              		"keyword": "Glasbox",
              		"color": "blue"
              Green bin plus and glass box, etc. are the names of the words in the Google Calendar
              • A
                @kusselin The config is JSON and should never be added to css. you need to add this in config.json for calendars check below for new year’s day
                	header: "NL Holidays",
                				symbol: "calendar-check",
                				url: "webcal://www.calendarlabs.com/ical-calendar/ics/101/Netherlands_Holidays.ics"
                		customEvents: [
                				"color": "red"
                				"color": "yellow"
                				"color": "blue"
                • kusselinK
                  kusselin
                  Can You help me please in the config.js…
                  here is my code but ist not show :
                  			header: "Abfalltermine 2021",
                  						url: "https://xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                  				customEvents: [
                  		"color": "green"
                  		"color": "brown"
                  		"color": "gray"
                  		"color": "blue"
                  • A
                    @kusselin : looks like you are missing comma in your config.js
                    2020-12-27-14-06-58-Clipboard
                    • kusselinK
                      kusselin
                      @kusselin said in Display waste bins in color:
                      customEvents: [
                      “keyword”: “Grüne Tonne plus”,
                      “color”: “green”
                      “keyword”: “Biomüll”,
                      “color”: “brown”
                      “keyword”: “Restmüll”,
                      “color”: “gray”
                      “keyword”: “Glasbox”,
                      “color”: “blue”
                      now the code is so, but the colours are not displayed :-(
                      						url: "https://xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                      				customEvents: [
                      		"color": "green"
                      		"color": "brown"
                      		"color": "gray"
                      		"color": "blue"
                      • A
                        @kusselin Can you check if your code is reaching here ?
                        1. Open dev tool using ctrl + shift + i
                        2. Go to sources tab
                        3. Press control + P to get the files list
                        4. Type calendar.js
                        5. Keep break point at below position and also few more breakpoints before it.
                        6. Press F5 to reload the Magic Mirror
                        7. If it hits break point, you can press F10 to step to each line and you can press F8 to continue execution (if it reaches to highlighted line then it should work)
                        Also check if there are any errors in console.
                        ![0_1609090681231_42989268-d442-4247-a154-548820a43acb-image.png](Uploading 100%)
                        2020-12-27-18-35-28-Magic-Mirror
                        • kusselinK
                          kusselin
                          Hi, its very difficult but i will try it
                          I can do this with mozilla browser… right?
                          In my config.js i no error because when an error is there the MM doesn‘t start then
                          Is the code so correct… with the Biotonne usw.
                          This is the word same in the google calender
                          Must i open the dev console when MM is running?
                          A S 2 Replies Last reply Reply Quote 0
                          • A
                            @kusselin you can open dev tools in Mozilla browser as well (key might be different). Yes MM should be running.
                              sdetweil @kusselin
                              @kusselin if u set mm to allow remote access, then u can do the debugging on your windows machine w Firefox or Chrome
                              adress:"0.0.0.0",
                              ipWhitelist:[],
                              in config.js
                              then on pc
                              http://pi-address:mm-port
                              kusselinK 1 Reply Last reply Reply Quote 1
                              • kusselinK
                                kusselin
                                is this right so:
                                /* global cloneObject */
                                /* Magic Mirror
                                 * Module: Calendar
                                 * By Michael Teeuw https://michaelteeuw.nl
                                 * MIT Licensed.
                                Module.register("calendar", {
                                	// Define module defaults
                                	defaults: {
                                		maximumEntries: 10, // Total Maximum Entries
                                		maximumNumberOfDays: 365,
                                		displaySymbol: true,
                                		defaultSymbol: "calendar", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
                                		showLocation: false,
                                		displayRepeatingCountTitle: false,
                                		defaultRepeatingCountTitle: "",
                                		maxTitleLength: 25,
                                		maxLocationTitleLength: 25,
                                		wrapEvents: false, // wrap events to multiple lines breaking at maxTitleLength
                                		wrapLocationEvents: false,
                                		maxTitleLines: 3,
                                		maxEventTitleLines: 3,
                                		fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                		animationSpeed: 2000,
                                		fade: true,
                                		urgency: 7,
                                		timeFormat: "relative",
                                		dateFormat: "MMM Do",
                                		dateEndFormat: "LT",
                                		fullDayEventDateFormat: "MMM Do",
                                		showEnd: false,
                                		getRelative: 6,
                                		fadePoint: 0.25, // Start on 1/4th of the list.
                                		hidePrivate: false,
                                		hideOngoing: false,
                                		colored: false,
                                		coloredSymbolOnly: false,
                                		tableClass: "small",
                                				symbol: "calendar",
                                				url: "https://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                                		titleReplace: {
                                			"De verjaardag van ": "",
                                			"'s birthday": ""
                                		locationTitleReplace: {
                                			"street ": ""
                                		broadcastEvents: true,
                                		excludedEvents: [],
                                		sliceMultiDayEvents: false,
                                		broadcastPastEvents: false,
                                		nextDaysRelative: false
                                	// Define required scripts.
                                	getStyles: function () {
                                		return ["calendar.css", "font-awesome.css"];
                                	getScripts: function () {
                                		return ["moment.js"];
                                	// Define required translations.
                                	getTranslations: function () {
                                		// The translations for the default modules are defined in the core translation files.
                                		// Therefor we can just return false. Otherwise we should have returned a dictionary.
                                		// If you're trying to build your own module including translations, check out the documentation.
                                		return false;
                                	// Override start method.
                                	start: function () {
                                		Log.log("Starting module: " + this.name);
                                		// Set locale.
                                		moment.updateLocale(config.language, this.getLocaleSpecification(config.timeFormat));
                                		for (var c in this.config.calendars) {
                                			var calendar = this.config.calendars[c];
                                			calendar.url = calendar.url.replace("webcal://", "http://");
                                			var calendarConfig = {
                                				maximumEntries: calendar.maximumEntries,
                                				maximumNumberOfDays: calendar.maximumNumberOfDays,
                                				broadcastPastEvents: calendar.broadcastPastEvents
                                			if (calendar.symbolClass === "undefined" || calendar.symbolClass === null) {
                                				calendarConfig.symbolClass = "";
                                			if (calendar.titleClass === "undefined" || calendar.titleClass === null) {
                                				calendarConfig.titleClass = "";
                                			if (calendar.timeClass === "undefined" || calendar.timeClass === null) {
                                				calendarConfig.timeClass = "";
                                			// we check user and password here for backwards compatibility with old configs
                                			if (calendar.user && calendar.pass) {
                                				Log.warn("Deprecation warning: Please update your calendar authentication configuration.");
                                				Log.warn("https://github.com/MichMich/MagicMirror/tree/v2.1.2/modules/default/calendar#calendar-authentication-options");
                                				calendar.auth = {
                                					user: calendar.user,
                                					pass: calendar.pass
                                			this.addCalendar(calendar.url, calendar.auth, calendarConfig);
                                			// Trigger ADD_CALENDAR every fetchInterval to make sure there is always a calendar
                                			// fetcher running on the server side.
                                			var self = this;
                                			setInterval(function () {
                                				self.addCalendar(calendar.url, calendar.auth, calendarConfig);
                                			}, self.config.fetchInterval);
                                		this.calendarData = {};
                                		this.loaded = false;
                                	// Override socket notification handler.
                                	socketNotificationReceived: function (notification, payload) {
                                		if (this.identifier !== payload.id) {
                                			return;
                                		if (notification === "CALENDAR_EVENTS") {
                                			if (this.hasCalendarURL(payload.url)) {
                                				this.calendarData[payload.url] = payload.events;
                                				this.loaded = true;
                                				if (this.config.broadcastEvents) {
                                					this.broadcastEvents();
                                		} else if (notification === "FETCH_ERROR") {
                                			Log.error("Calendar Error. Could not fetch calendar: " + payload.url);
                                			this.loaded = true;
                                		} else if (notification === "INCORRECT_URL") {
                                			Log.error("Calendar Error. Incorrect url: " + payload.url);
                                		this.updateDom(this.config.animationSpeed);
                                	// Override dom generator.
                                	getDom: function () {
                                		var events = this.createEventList();
                                		var wrapper = document.createElement("table");
                                		wrapper.className = this.config.tableClass;
                                		if (events.length === 0) {
                                			wrapper.innerHTML = this.loaded ? this.translate("EMPTY") : this.translate("LOADING");
                                			wrapper.className = this.config.tableClass + " dimmed";
                                			return wrapper;
                                		if (this.config.fade && this.config.fadePoint < 1) {
                                			if (this.config.fadePoint < 0) {
                                				this.config.fadePoint = 0;
                                			var startFade = events.length * this.config.fadePoint;
                                			var fadeSteps = events.length - startFade;
                                		var currentFadeStep = 0;
                                		var lastSeenDate = "";
                                		for (var e in events) {
                                			var event = events[e];
                                			var dateAsString = moment(event.startDate, "x").format(this.config.dateFormat);
                                			if (this.config.timeFormat === "dateheaders") {
                                				if (lastSeenDate !== dateAsString) {
                                					var dateRow = document.createElement("tr");
                                					dateRow.className = "normal";
                                					var dateCell = document.createElement("td");
                                					dateCell.colSpan = "3";
                                					dateCell.innerHTML = dateAsString;
                                					dateCell.style.paddingTop = "10px";
                                					dateRow.appendChild(dateCell);
                                					wrapper.appendChild(dateRow);
                                					if (e >= startFade) {
                                						//fading
                                						currentFadeStep = e - startFade;
                                						dateRow.style.opacity = 1 - (1 / fadeSteps) * currentFadeStep;
                                					lastSeenDate = dateAsString;
                                			var eventWrapper = document.createElement("tr");
                                			if (this.config.colored && !this.config.coloredSymbolOnly) {
                                				eventWrapper.style.cssText = "color:" + this.colorForUrl(event.url);
                                			eventWrapper.className = "normal event";
                                			if (this.config.displaySymbol) {
                                				var symbolWrapper = document.createElement("td");
                                				if (this.config.colored && this.config.coloredSymbolOnly) {
                                					symbolWrapper.style.cssText = "color:" + this.colorForUrl(event.url);
                                				var symbolClass = this.symbolClassForUrl(event.url);
                                				symbolWrapper.className = "symbol align-right " + symbolClass;
                                				var symbols = this.symbolsForEvent(event);
                                				for (var i = 0; i < symbols.length; i++) {
                                					var symbol = document.createElement("span");
                                					symbol.className = "fa fa-fw fa-" + symbols[i];
                                					if (i > 0) {
                                						symbol.style.paddingLeft = "5px";
                                					symbolWrapper.appendChild(symbol);
                                				eventWrapper.appendChild(symbolWrapper);
                                			} else if (this.config.timeFormat === "dateheaders") {
                                				var blankCell = document.createElement("td");
                                				blankCell.innerHTML = "&nbsp;&nbsp;&nbsp;";
                                				eventWrapper.appendChild(blankCell);
                                			var titleWrapper = document.createElement("td"),
                                				repeatingCountTitle = "";
                                			if (this.config.displayRepeatingCountTitle && event.firstYear !== undefined) {
                                				repeatingCountTitle = this.countTitleForUrl(event.url);
                                				if (repeatingCountTitle !== "") {
                                					var thisYear = new Date(parseInt(event.startDate)).getFullYear(),
                                						yearDiff = thisYear - event.firstYear;
                                					repeatingCountTitle = ", " + yearDiff + ". " + repeatingCountTitle;
                                			titleWrapper.innerHTML = this.titleTransform(event.title, this.config.titleReplace, this.config.wrapEvents, this.config.maxTitleLength, this.config.maxTitleLines) + repeatingCountTitle;
                                			var titleClass = this.titleClassForUrl(event.url);
                                			if (!this.config.colored) {
                                				titleWrapper.className = "title bright " + titleClass;
                                			} else {
                                				titleWrapper.className = "title " + titleClass;
                                			var timeWrapper;
                                				if (event.fullDayEvent) {
                                					titleWrapper.colSpan = "2";
                                					titleWrapper.align = "left";
                                				} else {
                                					timeWrapper = document.createElement("td");
                                					timeWrapper.className = "time light " + this.timeClassForUrl(event.url);
                                					timeWrapper.align = "left";
                                					timeWrapper.style.paddingLeft = "2px";
                                					timeWrapper.innerHTML = moment(event.startDate, "x").format("LT");
                                					eventWrapper.appendChild(timeWrapper);
                                					titleWrapper.align = "right";
                                				eventWrapper.appendChild(titleWrapper);
                                			} else {
                                				var now = new Date();
                                				// Define second, minute, hour, and day variables
                                				var oneSecond = 1000; // 1,000 milliseconds
                                				var oneMinute = oneSecond * 60;
                                				var oneHour = oneMinute * 60;
                                				var oneDay = oneHour * 24;
                                					//subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 one the next day
                                					event.endDate -= oneSecond;
                                					if (event.today) {
                                						timeWrapper.innerHTML = this.capFirst(this.translate("TODAY"));
                                					} else if (event.startDate - now < oneDay && event.startDate - now > 0) {
                                						timeWrapper.innerHTML = this.capFirst(this.translate("TOMORROW"));
                                					} else if (event.startDate - now < 2 * oneDay && event.startDate - now > 0) {
                                						if (this.translate("DAYAFTERTOMORROW") !== "DAYAFTERTOMORROW") {
                                							timeWrapper.innerHTML = this.capFirst(this.translate("DAYAFTERTOMORROW"));
                                						} else {
                                							timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow());
                                					} else {
                                						/* Check to see if the user displays absolute or relative dates with their events
                                						 * Also check to see if an event is happening within an 'urgency' time frameElement
                                						 * For example, if the user set an .urgency of 7 days, those events that fall within that
                                						 * time frame will be displayed with 'in xxx' time format or moment.fromNow()
                                						 * Note: this needs to be put in its own function, as the whole thing repeats again verbatim
                                						if (this.config.timeFormat === "absolute") {
                                							if (this.config.urgency > 1 && event.startDate - now < this.config.urgency * oneDay) {
                                								// This event falls within the config.urgency period that the user has set
                                								timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").from(moment().format("YYYYMMDD")));
                                							} else {
                                								timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").format(this.config.fullDayEventDateFormat));
                                						} else {
                                					if (this.config.showEnd) {
                                						timeWrapper.innerHTML += "-";
                                						timeWrapper.innerHTML += this.capFirst(moment(event.endDate, "x").format(this.config.fullDayEventDateFormat));
                                				} else {
                                					if (event.startDate >= new Date()) {
                                						if (event.startDate - now < 2 * oneDay) {
                                							// This event is within the next 48 hours (2 days)
                                							if (event.startDate - now < this.config.getRelative * oneHour) {
                                								// If event is within 6 hour, display 'in xxx' time format or moment.fromNow()
                                							} else {
                                								if (this.config.timeFormat === "absolute" && !this.config.nextDaysRelative) {
                                									timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").format(this.config.dateFormat));
                                								} else {
                                									// Otherwise just say 'Today/Tomorrow at such-n-such time'
                                									timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").calendar());
                                						} else {
                                								} else {
                                							} else {
                                					} else {
                                							this.translate("RUNNING", {
                                								fallback: this.translate("RUNNING") + " {timeUntilEnd}",
                                								timeUntilEnd: moment(event.endDate, "x").fromNow(true)
                                						timeWrapper.innerHTML += this.capFirst(moment(event.endDate, "x").format(this.config.dateEndFormat));
                                				//timeWrapper.innerHTML += ' - '+ moment(event.startDate,'x').format('lll');
                                			wrapper.appendChild(eventWrapper);
                                			// Create fade effect.
                                				eventWrapper.style.opacity = 1 - (1 / fadeSteps) * currentFadeStep;
                                			if (this.config.showLocation) {
                                				if (event.location !== false) {
                                					var locationRow = document.createElement("tr");
                                					locationRow.className = "normal xsmall light";
                                						var symbolCell = document.createElement("td");
                                						locationRow.appendChild(symbolCell);
                                					var descCell = document.createElement("td");
                                					descCell.className = "location";
                                					descCell.colSpan = "2";
                                					descCell.innerHTML = this.titleTransform(event.location, this.config.locationTitleReplace, this.config.wrapLocationEvents, this.config.maxLocationTitleLength, this.config.maxEventTitleLines);
                                					locationRow.appendChild(descCell);
                                					wrapper.appendChild(locationRow);
                                						locationRow.style.opacity = 1 - (1 / fadeSteps) * currentFadeStep;
                                		return wrapper;
                                	 * This function accepts a number (either 12 or 24) and returns a moment.js LocaleSpecification with the
                                	 * corresponding timeformat to be used in the calendar display. If no number is given (or otherwise invalid input)
                                	 * it will a localeSpecification object with the system locale time format.
                                	 * @param {number} timeFormat Specifies either 12 or 24 hour time format
                                	 * @returns {moment.LocaleSpecification} formatted time
                                	getLocaleSpecification: function (timeFormat) {
                                		switch (timeFormat) {
                                			case 12: {
                                				return { longDateFormat: { LT: "h:mm A" } };
                                			case 24: {
                                				return { longDateFormat: { LT: "HH:mm" } };
                                			default: {
                                				return { longDateFormat: { LT: moment.localeData().longDateFormat("LT") } };
                                	 * Checks if this config contains the calendar url.
                                	 * @param {string} url The calendar url
                                	 * @returns {boolean} True if the calendar config contains the url, False otherwise
                                	hasCalendarURL: function (url) {
                                			if (calendar.url === url) {
                                				return true;
                                		return false;
                                	 * Creates the sorted list of all events.
                                	 * @returns {object[]} Array with events.
                                	createEventList: function () {
                                		var events = [];
                                		var today = moment().startOf("day");
                                		var future = moment().startOf("day").add(this.config.maximumNumberOfDays, "days").toDate();
                                		for (var c in this.calendarData) {
                                			var calendar = this.calendarData[c];
                                			for (var e in calendar) {
                                				var event = JSON.parse(JSON.stringify(calendar[e])); // clone object
                                				if (event.endDate < now) {
                                					continue;
                                				if (this.config.hidePrivate) {
                                					if (event.class === "PRIVATE") {
                                						// do not add the current event, skip it
                                						continue;
                                				if (this.config.hideOngoing) {
                                					if (event.startDate < now) {
                                						continue;
                                				if (this.listContainsEvent(events, event)) {
                                					continue;
                                				event.url = c;
                                				event.today = event.startDate >= today && event.startDate < today + 24 * 60 * 60 * 1000;
                                				/* if sliceMultiDayEvents is set to true, multiday events (events exceeding at least one midnight) are sliced into days,
                                				 * otherwise, esp. in dateheaders mode it is not clear how long these events are.
                                				var maxCount = Math.ceil((event.endDate - 1 - moment(event.startDate, "x").endOf("day").format("x")) / (1000 * 60 * 60 * 24)) + 1;
                                				if (this.config.sliceMultiDayEvents && maxCount > 1) {
                                					var splitEvents = [];
                                					var midnight = moment(event.startDate, "x").clone().startOf("day").add(1, "day").format("x");
                                					var count = 1;
                                					while (event.endDate > midnight) {
                                						var thisEvent = JSON.parse(JSON.stringify(event)); // clone object
                                						thisEvent.today = thisEvent.startDate >= today && thisEvent.startDate < today + 24 * 60 * 60 * 1000;
                                						thisEvent.endDate = midnight;
                                						thisEvent.title += " (" + count + "/" + maxCount + ")";
                                						splitEvents.push(thisEvent);
                                						event.startDate = midnight;
                                						count += 1;
                                						midnight = moment(midnight, "x").add(1, "day").format("x"); // next day
                                					// Last day
                                					event.title += " (" + count + "/" + maxCount + ")";
                                					splitEvents.push(event);
                                					for (event of splitEvents) {
                                						if (event.endDate > now && event.endDate <= future) {
                                							events.push(event);
                                				} else {
                                					events.push(event);
                                		events.sort(function (a, b) {
                                			return a.startDate - b.startDate;
                                		return events.slice(0, this.config.maximumEntries);
                                	listContainsEvent: function (eventList, event) {
                                		for (var evt of eventList) {
                                			if (evt.title === event.title && parseInt(evt.startDate) === parseInt(event.startDate)) {
                                				return true;
                                		return false;
                                	 * Requests node helper to add calendar url.
                                	 * @param {string} url The calendar url to add
                                	 * @param {object} auth The authentication method and credentials
                                	 * @param {object} calendarConfig The config of the specific calendar
                                	addCalendar: function (url, auth, calendarConfig) {
                                		this.sendSocketNotification("ADD_CALENDAR", {
                                			url: url,
                                			excludedEvents: calendarConfig.excludedEvents || this.config.excludedEvents,
                                			maximumEntries: calendarConfig.maximumEntries || this.config.maximumEntries,
                                			maximumNumberOfDays: calendarConfig.maximumNumberOfDays || this.config.maximumNumberOfDays,
                                			fetchInterval: this.config.fetchInterval,
                                			symbolClass: calendarConfig.symbolClass,
                                			titleClass: calendarConfig.titleClass,
                                			timeClass: calendarConfig.timeClass,
                                			auth: auth,
                                			broadcastPastEvents: calendarConfig.broadcastPastEvents || this.config.broadcastPastEvents
                                	 * Retrieves the symbols for a specific event.
                                	 * @param {object} event Event to look for.
                                	 * @returns {string[]} The symbols
                                	symbolsForEvent: function (event) {
                                		let symbols = this.getCalendarPropertyAsArray(event.url, "symbol", this.config.defaultSymbol);
                                		if (event.recurringEvent === true && this.hasCalendarProperty(event.url, "recurringSymbol")) {
                                			symbols = this.mergeUnique(this.getCalendarPropertyAsArray(event.url, "recurringSymbol", this.config.defaultSymbol), symbols);
                                		if (event.fullDayEvent === true && this.hasCalendarProperty(event.url, "fullDaySymbol")) {
                                			symbols = this.mergeUnique(this.getCalendarPropertyAsArray(event.url, "fullDaySymbol", this.config.defaultSymbol), symbols);
                                		return symbols;
                                	mergeUnique: function (arr1, arr2) {
                                		return arr1.concat(
                                			arr2.filter(function (item) {
                                				return arr1.indexOf(item) === -1;
                                	 * Retrieves the symbolClass for a specific calendar url.
                                	 * @returns {string} The class to be used for the symbols of the calendar
                                	symbolClassForUrl: function (url) {
                                		return this.getCalendarProperty(url, "symbolClass", "");
                                	 * Retrieves the titleClass for a specific calendar url.
                                	 * @returns {string} The class to be used for the title of the calendar
                                	titleClassForUrl: function (url) {
                                		return this.getCalendarProperty(url, "titleClass", "");
                                	 * Retrieves the timeClass for a specific calendar url.
                                	 * @returns {string} The class to be used for the time of the calendar
                                	timeClassForUrl: function (url) {
                                		return this.getCalendarProperty(url, "timeClass", "");
                                	 * Retrieves the calendar name for a specific calendar url.
                                	 * @returns {string} The name of the calendar
                                	calendarNameForUrl: function (url) {
                                		return this.getCalendarProperty(url, "name", "");
                                	 * Retrieves the color for a specific calendar url.
                                	 * @returns {string} The color
                                	colorForUrl: function (url) {
                                		return this.getCalendarProperty(url, "color", "#fff");
                                	 * Retrieves the count title for a specific calendar url.
                                	 * @returns {string} The title
                                	countTitleForUrl: function (url) {
                                		return this.getCalendarProperty(url, "repeatingCountTitle", this.config.defaultRepeatingCountTitle);
                                	 * Helper method to retrieve the property for a specific calendar url.
                                	 * @param {string} property The property to look for
                                	 * @param {string} defaultValue The value if the property is not found
                                	 * @returns {*} The property
                                	getCalendarProperty: function (url, property, defaultValue) {
                                			if (calendar.url === url && calendar.hasOwnProperty(property)) {
                                				return calendar[property];
                                		return defaultValue;
                                	getCalendarPropertyAsArray: function (url, property, defaultValue) {
                                		let p = this.getCalendarProperty(url, property, defaultValue);
                                		if (!(p instanceof Array)) p = [p];
                                		return p;
                                	hasCalendarProperty: function (url, property) {
                                		return !!this.getCalendarProperty(url, property, undefined);
                                	 * Shortens a string if it's longer than maxLength and add a ellipsis to the end
                                	 * @param {string} string Text string to shorten
                                	 * @param {number} maxLength The max length of the string
                                	 * @param {boolean} wrapEvents Wrap the text after the line has reached maxLength
                                	 * @param {number} maxTitleLines The max number of vertical lines before cutting event title
                                	 * @returns {string} The shortened string
                                	shorten: function (string, maxLength, wrapEvents, maxTitleLines) {
                                		if (typeof string !== "string") {
                                			return "";
                                		if (wrapEvents === true) {
                                			var temp = "";
                                			var currentLine = "";
                                			var words = string.split(" ");
                                			var line = 0;
                                			for (var i = 0; i < words.length; i++) {
                                				var word = words[i];
                                				if (currentLine.length + word.length < (typeof maxLength === "number" ? maxLength : 25) - 1) {
                                					// max - 1 to account for a space
                                					currentLine += word + " ";
                                				} else {
                                					line++;
                                					if (line > maxTitleLines - 1) {
                                						if (i < words.length) {
                                							currentLine += "&hellip;";
                                						break;
                                					if (currentLine.length > 0) {
                                						temp += currentLine + "<br>" + word + " ";
                                					} else {
                                						temp += word + "<br>";
                                					currentLine = "";
                                			return (temp + currentLine).trim();
                                		} else {
                                			if (maxLength && typeof maxLength === "number" && string.length > maxLength) {
                                				return string.trim().slice(0, maxLength) + "&hellip;";
                                			} else {
                                				return string.trim();
                                	 * Capitalize the first letter of a string
                                	 * @param {string} string The string to capitalize
                                	 * @returns {string} The capitalized string
                                	capFirst: function (string) {
                                		return string.charAt(0).toUpperCase() + string.slice(1);
                                	 * Transforms the title of an event for usage.
                                	 * Replaces parts of the text as defined in config.titleReplace.
                                	 * Shortens title based on config.maxTitleLength and config.wrapEvents
                                	 * @param {string} title The title to transform.
                                	 * @param {object} titleReplace Pairs of strings to be replaced in the title
                                	 * @param {number} maxTitleLength The max length of the string
                                	 * @returns {string} The transformed title.
                                	titleTransform: function (title, titleReplace, wrapEvents, maxTitleLength, maxTitleLines) {
                                		for (var needle in titleReplace) {
                                			var replacement = titleReplace[needle];
                                			var regParts = needle.match(/^\/(.+)\/([gim]*)$/);
                                			if (regParts) {
                                				// the parsed pattern is a regexp.
                                				needle = new RegExp(regParts[1], regParts[2]);
                                			title = title.replace(needle, replacement);
                                		title = this.shorten(title, maxTitleLength, wrapEvents, maxTitleLines);
                                		return title;
                                	 * Broadcasts the events to all other modules for reuse.
                                	 * The all events available in one array, sorted on startdate.
                                	broadcastEvents: function () {
                                		var eventList = [];
                                		for (var url in this.calendarData) {
                                			var calendar = this.calendarData[url];
                                				var event = cloneObject(calendar[e]);
                                				event.symbol = this.symbolsForEvent(event);
                                				event.calendarName = this.calendarNameForUrl(url);
                                				event.color = this.colorForUrl(url);
                                				delete event.url;
                                				eventList.push(event);
                                		eventList.sort(function (a, b) {
                                		this.sendNotification("CALENDAR_EVENTS", eventList);
                                • kusselinK
                                  kusselin @sdetweil
                                  @sdetweil said in Display waste bins in color:
                                  adress:"0.0.0.0",
                                  ipWhitelist:[],
                                  in config.js
                                  then on pc
                                  Yes, have it so!!
                                  • A
                                    @kusselin Looks like you are using very old calendar module (so as Magic Mirror). Please update the Magic Mirror to latest version and then test (make sure to keep backup of you config.js and other custom.css files).
                                    2020-12-28 10_52_18-DiffNow - Compare Files, URLs, and Clipboard Contents Online.png
                                    • kusselinK
                                      kusselin
                                      Hi, the calender module is the standard module wich is automatic install to magic mirror.
                                      My MM is actually up to date. So i can‘t update my MM and i have no info to update the calender module from remote app.
                                      So what can i do??
                                      Best regards
                                        sdetweil @kusselin
                                        @kusselin can u do
                                        grep version package.json
                                        • kusselinK
                                          kusselin
                                          Sorry i m not at home… tomorrow…
                                            sdetweil @kusselin
                                            @kusselin no problem… i’ll be around
