    Display waste bins in color
    52 Posts 3 Posters 24.9k Views 3 Watching
    • kusselinK Offline
      kusselin
      Can You help me please in the config.js…
      here is my code but ist not show :
      			header: "Abfalltermine 2021",
      						symbol: "calendar-check",
      						url: "https://xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
      				customEvents: [
      		"keyword": "Grüne Tonne plus",
      		"color": "green"
      		"keyword": "Biomüll",
      		"color": "brown"
      		"keyword": "Restmüll",
      		"color": "gray"
      		"keyword": "Glasbox",
      		"color": "blue"
        ashishtank Module Developer
        @kusselin : looks like you are missing comma in your config.js
        2020-12-27-14-06-58-Clipboard
        • kusselinK Offline
          kusselin
          @kusselin said in Display waste bins in color:
          customEvents: [
          “keyword”: “Grüne Tonne plus”,
          “color”: “green”
          “keyword”: “Biomüll”,
          “color”: “brown”
          “keyword”: “Restmüll”,
          “color”: “gray”
          “keyword”: “Glasbox”,
          “color”: “blue”
          now the code is so, but the colours are not displayed :-(
          						url: "https://xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
          				customEvents: [
          		"color": "green"
          		"color": "brown"
          		"color": "gray"
          		"color": "blue"
            @kusselin Can you check if your code is reaching here ?
            1. Open dev tool using ctrl + shift + i
            2. Go to sources tab
            3. Press control + P to get the files list
            4. Type calendar.js
            5. Keep break point at below position and also few more breakpoints before it.
            6. Press F5 to reload the Magic Mirror
            7. If it hits break point, you can press F10 to step to each line and you can press F8 to continue execution (if it reaches to highlighted line then it should work)
            Also check if there are any errors in console.
            ![0_1609090681231_42989268-d442-4247-a154-548820a43acb-image.png](Uploading 100%)
            2020-12-27-18-35-28-Magic-Mirror
            • kusselinK Offline
              kusselin
              Hi, its very difficult but i will try it
              I can do this with mozilla browser… right?
              In my config.js i no error because when an error is there the MM doesn‘t start then
              Is the code so correct… with the Biotonne usw.
              This is the word same in the google calender
              Must i open the dev console when MM is running?
              A S 2 Replies Last reply Reply Quote 0
                ashishtank Module Developer @kusselin
                @kusselin you can open dev tools in Mozilla browser as well (key might be different). Yes MM should be running.
                  sdetweil @kusselin
                  @kusselin if u set mm to allow remote access, then u can do the debugging on your windows machine w Firefox or Chrome
                  adress:"0.0.0.0",
                  ipWhitelist:[],
                  in config.js
                  then on pc
                  http://pi-address:mm-port
                  kusselinK 1 Reply Last reply Reply Quote 1
                  • kusselinK Offline
                    kusselin
                    @ashishtank said in Display waste bins in color:
                    is this right so:
                    /* global cloneObject */
                    /* Magic Mirror
                     * Module: Calendar
                     * By Michael Teeuw https://michaelteeuw.nl
                     * MIT Licensed.
                    Module.register("calendar", {
                    	// Define module defaults
                    	defaults: {
                    		maximumEntries: 10, // Total Maximum Entries
                    		maximumNumberOfDays: 365,
                    		displaySymbol: true,
                    		defaultSymbol: "calendar", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
                    		showLocation: false,
                    		displayRepeatingCountTitle: false,
                    		defaultRepeatingCountTitle: "",
                    		maxTitleLength: 25,
                    		maxLocationTitleLength: 25,
                    		wrapEvents: false, // wrap events to multiple lines breaking at maxTitleLength
                    		wrapLocationEvents: false,
                    		maxTitleLines: 3,
                    		maxEventTitleLines: 3,
                    		fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                    		animationSpeed: 2000,
                    		fade: true,
                    		urgency: 7,
                    		timeFormat: "relative",
                    		dateFormat: "MMM Do",
                    		dateEndFormat: "LT",
                    		fullDayEventDateFormat: "MMM Do",
                    		showEnd: false,
                    		getRelative: 6,
                    		fadePoint: 0.25, // Start on 1/4th of the list.
                    		hidePrivate: false,
                    		hideOngoing: false,
                    		colored: false,
                    		coloredSymbolOnly: false,
                    		tableClass: "small",
                    				symbol: "calendar",
                    				url: "https://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                    		titleReplace: {
                    			"De verjaardag van ": "",
                    			"'s birthday": ""
                    		locationTitleReplace: {
                    			"street ": ""
                    		broadcastEvents: true,
                    		excludedEvents: [],
                    		sliceMultiDayEvents: false,
                    		broadcastPastEvents: false,
                    		nextDaysRelative: false
                    	// Define required scripts.
                    	getStyles: function () {
                    		return ["calendar.css", "font-awesome.css"];
                    	getScripts: function () {
                    		return ["moment.js"];
                    	// Define required translations.
                    	getTranslations: function () {
                    		// The translations for the default modules are defined in the core translation files.
                    		// Therefor we can just return false. Otherwise we should have returned a dictionary.
                    		// If you're trying to build your own module including translations, check out the documentation.
                    		return false;
                    	// Override start method.
                    	start: function () {
                    		Log.log("Starting module: " + this.name);
                    		// Set locale.
                    		moment.updateLocale(config.language, this.getLocaleSpecification(config.timeFormat));
                    		for (var c in this.config.calendars) {
                    			var calendar = this.config.calendars[c];
                    			calendar.url = calendar.url.replace("webcal://", "http://");
                    			var calendarConfig = {
                    				maximumEntries: calendar.maximumEntries,
                    				maximumNumberOfDays: calendar.maximumNumberOfDays,
                    				broadcastPastEvents: calendar.broadcastPastEvents
                    			if (calendar.symbolClass === "undefined" || calendar.symbolClass === null) {
                    				calendarConfig.symbolClass = "";
                    			if (calendar.titleClass === "undefined" || calendar.titleClass === null) {
                    				calendarConfig.titleClass = "";
                    			if (calendar.timeClass === "undefined" || calendar.timeClass === null) {
                    				calendarConfig.timeClass = "";
                    			// we check user and password here for backwards compatibility with old configs
                    			if (calendar.user && calendar.pass) {
                    				Log.warn("Deprecation warning: Please update your calendar authentication configuration.");
                    				Log.warn("https://github.com/MichMich/MagicMirror/tree/v2.1.2/modules/default/calendar#calendar-authentication-options");
                    				calendar.auth = {
                    					user: calendar.user,
                    					pass: calendar.pass
                    			this.addCalendar(calendar.url, calendar.auth, calendarConfig);
                    			// Trigger ADD_CALENDAR every fetchInterval to make sure there is always a calendar
                    			// fetcher running on the server side.
                    			var self = this;
                    			setInterval(function () {
                    				self.addCalendar(calendar.url, calendar.auth, calendarConfig);
                    			}, self.config.fetchInterval);
                    		this.calendarData = {};
                    		this.loaded = false;
                    	// Override socket notification handler.
                    	socketNotificationReceived: function (notification, payload) {
                    		if (this.identifier !== payload.id) {
                    			return;
                    		if (notification === "CALENDAR_EVENTS") {
                    			if (this.hasCalendarURL(payload.url)) {
                    				this.calendarData[payload.url] = payload.events;
                    				this.loaded = true;
                    				if (this.config.broadcastEvents) {
                    					this.broadcastEvents();
                    		} else if (notification === "FETCH_ERROR") {
                    			Log.error("Calendar Error. Could not fetch calendar: " + payload.url);
                    			this.loaded = true;
                    		} else if (notification === "INCORRECT_URL") {
                    			Log.error("Calendar Error. Incorrect url: " + payload.url);
                    		this.updateDom(this.config.animationSpeed);
                    	// Override dom generator.
                    	getDom: function () {
                    		var events = this.createEventList();
                    		var wrapper = document.createElement("table");
                    		wrapper.className = this.config.tableClass;
                    		if (events.length === 0) {
                    			wrapper.innerHTML = this.loaded ? this.translate("EMPTY") : this.translate("LOADING");
                    			wrapper.className = this.config.tableClass + " dimmed";
                    			return wrapper;
                    		if (this.config.fade && this.config.fadePoint < 1) {
                    			if (this.config.fadePoint < 0) {
                    				this.config.fadePoint = 0;
                    			var startFade = events.length * this.config.fadePoint;
                    			var fadeSteps = events.length - startFade;
                    		var currentFadeStep = 0;
                    		var lastSeenDate = "";
                    		for (var e in events) {
                    			var event = events[e];
                    			var dateAsString = moment(event.startDate, "x").format(this.config.dateFormat);
                    			if (this.config.timeFormat === "dateheaders") {
                    				if (lastSeenDate !== dateAsString) {
                    					var dateRow = document.createElement("tr");
                    					dateRow.className = "normal";
                    					var dateCell = document.createElement("td");
                    					dateCell.colSpan = "3";
                    					dateCell.innerHTML = dateAsString;
                    					dateCell.style.paddingTop = "10px";
                    					dateRow.appendChild(dateCell);
                    					wrapper.appendChild(dateRow);
                    					if (e >= startFade) {
                    						//fading
                    						currentFadeStep = e - startFade;
                    						dateRow.style.opacity = 1 - (1 / fadeSteps) * currentFadeStep;
                    					lastSeenDate = dateAsString;
                    			var eventWrapper = document.createElement("tr");
                    			if (this.config.colored && !this.config.coloredSymbolOnly) {
                    				eventWrapper.style.cssText = "color:" + this.colorForUrl(event.url);
                    			eventWrapper.className = "normal event";
                    			if (this.config.displaySymbol) {
                    				var symbolWrapper = document.createElement("td");
                    				if (this.config.colored && this.config.coloredSymbolOnly) {
                    					symbolWrapper.style.cssText = "color:" + this.colorForUrl(event.url);
                    				var symbolClass = this.symbolClassForUrl(event.url);
                    				symbolWrapper.className = "symbol align-right " + symbolClass;
                    				var symbols = this.symbolsForEvent(event);
                    				for (var i = 0; i < symbols.length; i++) {
                    					var symbol = document.createElement("span");
                    					symbol.className = "fa fa-fw fa-" + symbols[i];
                    					if (i > 0) {
                    						symbol.style.paddingLeft = "5px";
                    					symbolWrapper.appendChild(symbol);
                    				eventWrapper.appendChild(symbolWrapper);
                    			} else if (this.config.timeFormat === "dateheaders") {
                    				var blankCell = document.createElement("td");
                    				blankCell.innerHTML = "&nbsp;&nbsp;&nbsp;";
                    				eventWrapper.appendChild(blankCell);
                    			var titleWrapper = document.createElement("td"),
                    				repeatingCountTitle = "";
                    			if (this.config.displayRepeatingCountTitle && event.firstYear !== undefined) {
                    				repeatingCountTitle = this.countTitleForUrl(event.url);
                    				if (repeatingCountTitle !== "") {
                    					var thisYear = new Date(parseInt(event.startDate)).getFullYear(),
                    						yearDiff = thisYear - event.firstYear;
                    					repeatingCountTitle = ", " + yearDiff + ". " + repeatingCountTitle;
                    			titleWrapper.innerHTML = this.titleTransform(event.title, this.config.titleReplace, this.config.wrapEvents, this.config.maxTitleLength, this.config.maxTitleLines) + repeatingCountTitle;
                    			var titleClass = this.titleClassForUrl(event.url);
                    			if (!this.config.colored) {
                    				titleWrapper.className = "title bright " + titleClass;
                    			} else {
                    				titleWrapper.className = "title " + titleClass;
                    			var timeWrapper;
                    				if (event.fullDayEvent) {
                    					titleWrapper.colSpan = "2";
                    					titleWrapper.align = "left";
                    				} else {
                    					timeWrapper = document.createElement("td");
                    					timeWrapper.className = "time light " + this.timeClassForUrl(event.url);
                    					timeWrapper.align = "left";
                    					timeWrapper.style.paddingLeft = "2px";
                    					timeWrapper.innerHTML = moment(event.startDate, "x").format("LT");
                    					eventWrapper.appendChild(timeWrapper);
                    					titleWrapper.align = "right";
                    				eventWrapper.appendChild(titleWrapper);
                    			} else {
                    				var now = new Date();
                    				// Define second, minute, hour, and day variables
                    				var oneSecond = 1000; // 1,000 milliseconds
                    				var oneMinute = oneSecond * 60;
                    				var oneHour = oneMinute * 60;
                    				var oneDay = oneHour * 24;
                    					//subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 one the next day
                    					event.endDate -= oneSecond;
                    					if (event.today) {
                    						timeWrapper.innerHTML = this.capFirst(this.translate("TODAY"));
                    					} else if (event.startDate - now < oneDay && event.startDate - now > 0) {
                    						timeWrapper.innerHTML = this.capFirst(this.translate("TOMORROW"));
                    					} else if (event.startDate - now < 2 * oneDay && event.startDate - now > 0) {
                    						if (this.translate("DAYAFTERTOMORROW") !== "DAYAFTERTOMORROW") {
                    							timeWrapper.innerHTML = this.capFirst(this.translate("DAYAFTERTOMORROW"));
                    						} else {
                    							timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow());
                    					} else {
                    						/* Check to see if the user displays absolute or relative dates with their events
                    						 * Also check to see if an event is happening within an 'urgency' time frameElement
                    						 * For example, if the user set an .urgency of 7 days, those events that fall within that
                    						 * time frame will be displayed with 'in xxx' time format or moment.fromNow()
                    						 * Note: this needs to be put in its own function, as the whole thing repeats again verbatim
                    						if (this.config.timeFormat === "absolute") {
                    							if (this.config.urgency > 1 && event.startDate - now < this.config.urgency * oneDay) {
                    								// This event falls within the config.urgency period that the user has set
                    								timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").from(moment().format("YYYYMMDD")));
                    							} else {
                    								timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").format(this.config.fullDayEventDateFormat));
                    						} else {
                    					if (this.config.showEnd) {
                    						timeWrapper.innerHTML += "-";
                    						timeWrapper.innerHTML += this.capFirst(moment(event.endDate, "x").format(this.config.fullDayEventDateFormat));
                    				} else {
                    					if (event.startDate >= new Date()) {
                    						if (event.startDate - now < 2 * oneDay) {
                    							// This event is within the next 48 hours (2 days)
                    							if (event.startDate - now < this.config.getRelative * oneHour) {
                    								// If event is within 6 hour, display 'in xxx' time format or moment.fromNow()
                    							} else {
                    								if (this.config.timeFormat === "absolute" && !this.config.nextDaysRelative) {
                    									timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").format(this.config.dateFormat));
                    								} else {
                    									// Otherwise just say 'Today/Tomorrow at such-n-such time'
                    									timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").calendar());
                    						} else {
                    								} else {
                    							} else {
                    					} else {
                    							this.translate("RUNNING", {
                    								fallback: this.translate("RUNNING") + " {timeUntilEnd}",
                    								timeUntilEnd: moment(event.endDate, "x").fromNow(true)
                    						timeWrapper.innerHTML += this.capFirst(moment(event.endDate, "x").format(this.config.dateEndFormat));
                    				//timeWrapper.innerHTML += ' - '+ moment(event.startDate,'x').format('lll');
                    			wrapper.appendChild(eventWrapper);
                    			// Create fade effect.
                    				eventWrapper.style.opacity = 1 - (1 / fadeSteps) * currentFadeStep;
                    			if (this.config.showLocation) {
                    				if (event.location !== false) {
                    					var locationRow = document.createElement("tr");
                    					locationRow.className = "normal xsmall light";
                    						var symbolCell = document.createElement("td");
                    						locationRow.appendChild(symbolCell);
                    					var descCell = document.createElement("td");
                    					descCell.className = "location";
                    					descCell.colSpan = "2";
                    					descCell.innerHTML = this.titleTransform(event.location, this.config.locationTitleReplace, this.config.wrapLocationEvents, this.config.maxLocationTitleLength, this.config.maxEventTitleLines);
                    					locationRow.appendChild(descCell);
                    					wrapper.appendChild(locationRow);
                    						locationRow.style.opacity = 1 - (1 / fadeSteps) * currentFadeStep;
                    		return wrapper;
                    	 * This function accepts a number (either 12 or 24) and returns a moment.js LocaleSpecification with the
                    	 * corresponding timeformat to be used in the calendar display. If no number is given (or otherwise invalid input)
                    	 * it will a localeSpecification object with the system locale time format.
                    	 * @param {number} timeFormat Specifies either 12 or 24 hour time format
                    	 * @returns {moment.LocaleSpecification} formatted time
                    	getLocaleSpecification: function (timeFormat) {
                    		switch (timeFormat) {
                    			case 12: {
                    				return { longDateFormat: { LT: "h:mm A" } };
                    			case 24: {
                    				return { longDateFormat: { LT: "HH:mm" } };
                    			default: {
                    				return { longDateFormat: { LT: moment.localeData().longDateFormat("LT") } };
                    	 * Checks if this config contains the calendar url.
                    	 * @param {string} url The calendar url
                    	 * @returns {boolean} True if the calendar config contains the url, False otherwise
                    	hasCalendarURL: function (url) {
                    			if (calendar.url === url) {
                    				return true;
                    		return false;
                    	 * Creates the sorted list of all events.
                    	 * @returns {object[]} Array with events.
                    	createEventList: function () {
                    		var events = [];
                    		var today = moment().startOf("day");
                    		var future = moment().startOf("day").add(this.config.maximumNumberOfDays, "days").toDate();
                    		for (var c in this.calendarData) {
                    			var calendar = this.calendarData[c];
                    			for (var e in calendar) {
                    				var event = JSON.parse(JSON.stringify(calendar[e])); // clone object
                    				if (event.endDate < now) {
                    					continue;
                    				if (this.config.hidePrivate) {
                    					if (event.class === "PRIVATE") {
                    						// do not add the current event, skip it
                    						continue;
                    				if (this.config.hideOngoing) {
                    					if (event.startDate < now) {
                    						continue;
                    				if (this.listContainsEvent(events, event)) {
                    					continue;
                    				event.url = c;
                    				event.today = event.startDate >= today && event.startDate < today + 24 * 60 * 60 * 1000;
                    				/* if sliceMultiDayEvents is set to true, multiday events (events exceeding at least one midnight) are sliced into days,
                    				 * otherwise, esp. in dateheaders mode it is not clear how long these events are.
                    				var maxCount = Math.ceil((event.endDate - 1 - moment(event.startDate, "x").endOf("day").format("x")) / (1000 * 60 * 60 * 24)) + 1;
                    				if (this.config.sliceMultiDayEvents && maxCount > 1) {
                    					var splitEvents = [];
                    					var midnight = moment(event.startDate, "x").clone().startOf("day").add(1, "day").format("x");
                    					var count = 1;
                    					while (event.endDate > midnight) {
                    						var thisEvent = JSON.parse(JSON.stringify(event)); // clone object
                    						thisEvent.today = thisEvent.startDate >= today && thisEvent.startDate < today + 24 * 60 * 60 * 1000;
                    						thisEvent.endDate = midnight;
                    						thisEvent.title += " (" + count + "/" + maxCount + ")";
                    						splitEvents.push(thisEvent);
                    						event.startDate = midnight;
                    						count += 1;
                    						midnight = moment(midnight, "x").add(1, "day").format("x"); // next day
                    					// Last day
                    					event.title += " (" + count + "/" + maxCount + ")";
                    					splitEvents.push(event);
                    					for (event of splitEvents) {
                    						if (event.endDate > now && event.endDate <= future) {
                    							events.push(event);
                    				} else {
                    					events.push(event);
                    		events.sort(function (a, b) {
                    			return a.startDate - b.startDate;
                    		return events.slice(0, this.config.maximumEntries);
                    	listContainsEvent: function (eventList, event) {
                    		for (var evt of eventList) {
                    			if (evt.title === event.title && parseInt(evt.startDate) === parseInt(event.startDate)) {
                    				return true;
                    		return false;
                    	 * Requests node helper to add calendar url.
                    	 * @param {string} url The calendar url to add
                    	 * @param {object} auth The authentication method and credentials
                    	 * @param {object} calendarConfig The config of the specific calendar
                    	addCalendar: function (url, auth, calendarConfig) {
                    		this.sendSocketNotification("ADD_CALENDAR", {
                    			url: url,
                    			excludedEvents: calendarConfig.excludedEvents || this.config.excludedEvents,
                    			maximumEntries: calendarConfig.maximumEntries || this.config.maximumEntries,
                    			maximumNumberOfDays: calendarConfig.maximumNumberOfDays || this.config.maximumNumberOfDays,
                    			fetchInterval: this.config.fetchInterval,
                    			symbolClass: calendarConfig.symbolClass,
                    			titleClass: calendarConfig.titleClass,
                    			timeClass: calendarConfig.timeClass,
                    			auth: auth,
                    			broadcastPastEvents: calendarConfig.broadcastPastEvents || this.config.broadcastPastEvents
                    	 * Retrieves the symbols for a specific event.
                    	 * @param {object} event Event to look for.
                    	 * @returns {string[]} The symbols
                    	symbolsForEvent: function (event) {
                    		let symbols = this.getCalendarPropertyAsArray(event.url, "symbol", this.config.defaultSymbol);
                    		if (event.recurringEvent === true && this.hasCalendarProperty(event.url, "recurringSymbol")) {
                    			symbols = this.mergeUnique(this.getCalendarPropertyAsArray(event.url, "recurringSymbol", this.config.defaultSymbol), symbols);
                    		if (event.fullDayEvent === true && this.hasCalendarProperty(event.url, "fullDaySymbol")) {
                    			symbols = this.mergeUnique(this.getCalendarPropertyAsArray(event.url, "fullDaySymbol", this.config.defaultSymbol), symbols);
                    		return symbols;
                    	mergeUnique: function (arr1, arr2) {
                    		return arr1.concat(
                    			arr2.filter(function (item) {
                    				return arr1.indexOf(item) === -1;
                    	 * Retrieves the symbolClass for a specific calendar url.
                    	 * @returns {string} The class to be used for the symbols of the calendar
                    	symbolClassForUrl: function (url) {
                    		return this.getCalendarProperty(url, "symbolClass", "");
                    	 * Retrieves the titleClass for a specific calendar url.
                    	 * @returns {string} The class to be used for the title of the calendar
                    	titleClassForUrl: function (url) {
                    		return this.getCalendarProperty(url, "titleClass", "");
                    	 * Retrieves the timeClass for a specific calendar url.
                    	 * @returns {string} The class to be used for the time of the calendar
                    	timeClassForUrl: function (url) {
                    		return this.getCalendarProperty(url, "timeClass", "");
                    	 * Retrieves the calendar name for a specific calendar url.
                    	 * @returns {string} The name of the calendar
                    	calendarNameForUrl: function (url) {
                    		return this.getCalendarProperty(url, "name", "");
                    	 * Retrieves the color for a specific calendar url.
                    	 * @returns {string} The color
                    	colorForUrl: function (url) {
                    		return this.getCalendarProperty(url, "color", "#fff");
                    	 * Retrieves the count title for a specific calendar url.
                    	 * @returns {string} The title
                    	countTitleForUrl: function (url) {
                    		return this.getCalendarProperty(url, "repeatingCountTitle", this.config.defaultRepeatingCountTitle);
                    	 * Helper method to retrieve the property for a specific calendar url.
                    	 * @param {string} property The property to look for
                    	 * @param {string} defaultValue The value if the property is not found
                    	 * @returns {*} The property
                    	getCalendarProperty: function (url, property, defaultValue) {
                    			if (calendar.url === url && calendar.hasOwnProperty(property)) {
                    				return calendar[property];
                    		return defaultValue;
                    	getCalendarPropertyAsArray: function (url, property, defaultValue) {
                    		let p = this.getCalendarProperty(url, property, defaultValue);
                    		if (!(p instanceof Array)) p = [p];
                    		return p;
                    	hasCalendarProperty: function (url, property) {
                    		return !!this.getCalendarProperty(url, property, undefined);
                    	 * Shortens a string if it's longer than maxLength and add a ellipsis to the end
                    	 * @param {string} string Text string to shorten
                    	 * @param {number} maxLength The max length of the string
                    	 * @param {boolean} wrapEvents Wrap the text after the line has reached maxLength
                    	 * @param {number} maxTitleLines The max number of vertical lines before cutting event title
                    	 * @returns {string} The shortened string
                    	shorten: function (string, maxLength, wrapEvents, maxTitleLines) {
                    		if (typeof string !== "string") {
                    			return "";
                    		if (wrapEvents === true) {
                    			var temp = "";
                    			var currentLine = "";
                    			var words = string.split(" ");
                    			var line = 0;
                    			for (var i = 0; i < words.length; i++) {
                    				var word = words[i];
                    				if (currentLine.length + word.length < (typeof maxLength === "number" ? maxLength : 25) - 1) {
                    					// max - 1 to account for a space
                    					currentLine += word + " ";
                    				} else {
                    					line++;
                    					if (line > maxTitleLines - 1) {
                    						if (i < words.length) {
                    							currentLine += "&hellip;";
                    						break;
                    					if (currentLine.length > 0) {
                    						temp += currentLine + "<br>" + word + " ";
                    					} else {
                    						temp += word + "<br>";
                    					currentLine = "";
                    			return (temp + currentLine).trim();
                    		} else {
                    			if (maxLength && typeof maxLength === "number" && string.length > maxLength) {
                    				return string.trim().slice(0, maxLength) + "&hellip;";
                    			} else {
                    				return string.trim();
                    	 * Capitalize the first letter of a string
                    	 * @param {string} string The string to capitalize
                    	 * @returns {string} The capitalized string
                    	capFirst: function (string) {
                    		return string.charAt(0).toUpperCase() + string.slice(1);
                    	 * Transforms the title of an event for usage.
                    	 * Replaces parts of the text as defined in config.titleReplace.
                    	 * Shortens title based on config.maxTitleLength and config.wrapEvents
                    	 * @param {string} title The title to transform.
                    	 * @param {object} titleReplace Pairs of strings to be replaced in the title
                    	 * @param {number} maxTitleLength The max length of the string
                    	 * @returns {string} The transformed title.
                    	titleTransform: function (title, titleReplace, wrapEvents, maxTitleLength, maxTitleLines) {
                    		for (var needle in titleReplace) {
                    			var replacement = titleReplace[needle];
                    			var regParts = needle.match(/^\/(.+)\/([gim]*)$/);
                    			if (regParts) {
                    				// the parsed pattern is a regexp.
                    				needle = new RegExp(regParts[1], regParts[2]);
                    			title = title.replace(needle, replacement);
                    		title = this.shorten(title, maxTitleLength, wrapEvents, maxTitleLines);
                    		return title;
                    	 * Broadcasts the events to all other modules for reuse.
                    	 * The all events available in one array, sorted on startdate.
                    	broadcastEvents: function () {
                    		var eventList = [];
                    		for (var url in this.calendarData) {
                    			var calendar = this.calendarData[url];
                    				var event = cloneObject(calendar[e]);
                    				event.symbol = this.symbolsForEvent(event);
                    				event.calendarName = this.calendarNameForUrl(url);
                    				event.color = this.colorForUrl(url);
                    				delete event.url;
                    				eventList.push(event);
                    		eventList.sort(function (a, b) {
                    		this.sendNotification("CALENDAR_EVENTS", eventList);
                    • kusselinK Offline
                      kusselin @sdetweil
                      @sdetweil said in Display waste bins in color:
                      adress:"0.0.0.0",
                      ipWhitelist:[],
                      in config.js
                      then on pc
                      Yes, have it so!!
                        @kusselin Looks like you are using very old calendar module (so as Magic Mirror). Please update the Magic Mirror to latest version and then test (make sure to keep backup of you config.js and other custom.css files).
                        2020-12-28 10_52_18-DiffNow - Compare Files, URLs, and Clipboard Contents Online.png
                        • kusselinK Offline
                          kusselin
                          Hi, the calender module is the standard module wich is automatic install to magic mirror.
                          My MM is actually up to date. So i can‘t update my MM and i have no info to update the calender module from remote app.
                          So what can i do??
                          Best regards
                            sdetweil @kusselin
                            @kusselin can u do
                            grep version package.json
                            • kusselinK Offline
                              kusselin
                              Sorry i m not at home… tomorrow…
                                sdetweil @kusselin
                                @kusselin no problem… i’ll be around
                                • kusselinK Offline
                                  kusselin
                                  Hi sam, here it is:
                                  pi@raspberrypi:~/MagicMirror $ grep version package.json
                                          "version": "2.13.0",
                                  • kusselinK Offline
                                    kusselin
                                    anyone here who can help me that the font from the calender can be in colour display…
                                    Is this not a css problem, because ashishtank said that the code must be in config.js???
                                    About help…thanks
                                      sdetweil @kusselin
                                      well, not config.js, but in the calendar module, but u posted the production version and
                                      its in the next release(coming tomorrow) and in develop branch
                                      So, u can wait and update tomorrow
                                      or update today to the develop branch
                                      see the pinned topic at the top of the troubleshooting section on 365 calendars (second post) for the instructions to get to the develop branch
                                      • kusselinK Offline
                                        kusselin
                                        OK. then the code does not come into the config.js as it wrote ashistank but into the config of the calendar module correctly!
                                        OK. ie tomorrow on 01.01.21 there will be a new version … and could you please show me in the calendar module where exactly I have to copy the code?
                                        customEvents: [
                                        		"color": "green"
                                        		"color": "brown"
                                        		"color": "gray"
                                        		"color": "blue"
                                        Many Thanks.
                                          sdetweil @kusselin
                                          @kusselin the code says this.config.customEvents
                                          so it is outside all the calendars
                                             module: 'calendar':
                                             position:
                                                customEvents:
                                                calendars : {...}
                                          u can put it in today, and it will be ignored, and then update tomorrow and it will be used
                                          kusselinK 1 Reply Last reply Reply Quote 0
                                          • kusselinK Offline
                                            kusselin @sdetweil
                                            @sdetweil hi sam, a happy new year.
                                            The update you mean is only for the calender module right?
                                            Also i go in the module folder and then in calender and there i make a git pull…right?
                                            Best regards
                                            • 2 / 3
