    Display waste bins in color
    52 Posts 3 Posters 25.6k Views 3 Watching
    • kusselinK Offline
      kusselin
      Hi, the calender module is the standard module wich is automatic install to magic mirror.
      My MM is actually up to date. So i can‘t update my MM and i have no info to update the calender module from remote app.
      So what can i do??
      Best regards
        sdetweil @kusselin
        @kusselin can u do
        grep version package.json
        • kusselinK Offline
          kusselin
          Sorry i m not at home… tomorrow…
            sdetweil @kusselin
            @kusselin no problem… i’ll be around
            • kusselinK Offline
              kusselin
              Hi sam, here it is:
              pi@raspberrypi:~/MagicMirror $ grep version package.json
                      "version": "2.13.0",
              • kusselinK Offline
                kusselin
                anyone here who can help me that the font from the calender can be in colour display…
                Is this not a css problem, because ashishtank said that the code must be in config.js???
                About help…thanks
                  sdetweil @kusselin
                  @kusselin said in Display waste bins in color:
                  well, not config.js, but in the calendar module, but u posted the production version and
                  its in the next release(coming tomorrow) and in develop branch
                  So, u can wait and update tomorrow
                  or update today to the develop branch
                  see the pinned topic at the top of the troubleshooting section on 365 calendars (second post) for the instructions to get to the develop branch
                  • kusselinK Offline
                    kusselin
                    @sdetweil said in Display waste bins in color:
                    OK. then the code does not come into the config.js as it wrote ashistank but into the config of the calendar module correctly!
                    OK. ie tomorrow on 01.01.21 there will be a new version … and could you please show me in the calendar module where exactly I have to copy the code?
                    customEvents: [
                    		"keyword": "Grüne Tonne plus",
                    		"color": "green"
                    		"keyword": "Biomüll",
                    		"color": "brown"
                    		"keyword": "Restmüll",
                    		"color": "gray"
                    		"keyword": "Glasbox",
                    		"color": "blue"
                    Many Thanks.
                      sdetweil @kusselin
                      @kusselin the code says this.config.customEvents
                      so it is outside all the calendars
                         module: 'calendar':
                         position:
                            customEvents:
                            calendars : {...}
                      u can put it in today, and it will be ignored, and then update tomorrow and it will be used
                      kusselinK 1 Reply Last reply Reply Quote 0
                      • kusselinK Offline
                        kusselin @sdetweil
                        @sdetweil hi sam, a happy new year.
                        The update you mean is only for the calender module right?
                        Also i go in the module folder and then in calender and there i make a git pull…right?
                        Best regards
                          sdetweil @kusselin
                          @kusselin no. it has ALL the fixes to mm since oct.
                          I just used it as a placeholder for the instructions
                            ashishtank Module Developer
                            @kusselin : once new version of MM is released today, you will get all the latest code and then it should work.
                            • kusselinK Offline
                              kusselin
                              @ashishtank said in Display waste bins in color:
                              Ahh ok…since achuell is the latest version 2.13.0. i have this version…and today a new verdion is comming…ok i will wait…where can i find the info for new versuon?
                              S A 2 Replies Last reply Reply Quote 0
                                sdetweil @kusselin
                                @kusselin it will be displayed in the banner above when released (version will be 2.14)
                                  ashishtank Module Developer @kusselin
                                  @kusselin details will be here https://forum.magicmirror.builders/category/17/magicmirror
                                  • kusselinK Offline
                                    kusselin
                                    Thank you
                                      sdetweil @kusselin
                                      @kusselin new release available
                                      • kusselinK Offline
                                        kusselin
                                        Ok i see…thanks snd now the update how is standing in the update manual here…right
                                          sdetweil @kusselin
                                          @kusselin eh? not sure what u said. run my upgrade script
                                          see
                                          • kusselinK Offline
                                            kusselin
                                            o.k thanks
                                            • 2 / 3
