    Display waste bins in color
    52 Posts 3 Posters 26.4k Views 3 Watching
      sdetweil @kusselin
      @kusselin no problem… i’ll be around
      • kusselinK
        kusselin
        Hi sam, here it is:
        pi@raspberrypi:~/MagicMirror $ grep version package.json
                "version": "2.13.0",
        • kusselinK
          kusselin
          anyone here who can help me that the font from the calender can be in colour display…
          Is this not a css problem, because ashishtank said that the code must be in config.js???
          About help…thanks
            sdetweil @kusselin
            @kusselin said in Display waste bins in color:
            well, not config.js, but in the calendar module, but u posted the production version and
            its in the next release(coming tomorrow) and in develop branch
            So, u can wait and update tomorrow
            or update today to the develop branch
            see the pinned topic at the top of the troubleshooting section on 365 calendars (second post) for the instructions to get to the develop branch
            • kusselinK
              kusselin
              @sdetweil said in Display waste bins in color:
              OK. then the code does not come into the config.js as it wrote ashistank but into the config of the calendar module correctly!
              OK. ie tomorrow on 01.01.21 there will be a new version … and could you please show me in the calendar module where exactly I have to copy the code?
              customEvents: [
              		"keyword": "Grüne Tonne plus",
              		"color": "green"
              		"keyword": "Biomüll",
              		"color": "brown"
              		"keyword": "Restmüll",
              		"color": "gray"
              		"keyword": "Glasbox",
              		"color": "blue"
              Many Thanks.
                sdetweil @kusselin
                @kusselin the code says this.config.customEvents
                so it is outside all the calendars
                   module: 'calendar':
                   position:
                      customEvents:
                      calendars : {...}
                u can put it in today, and it will be ignored, and then update tomorrow and it will be used
                kusselinK 1 Reply Last reply Reply Quote 0
                • kusselinK
                  kusselin @sdetweil
                  @sdetweil hi sam, a happy new year.
                  The update you mean is only for the calender module right?
                  Also i go in the module folder and then in calender and there i make a git pull…right?
                  Best regards
                    sdetweil @kusselin
                    @kusselin no. it has ALL the fixes to mm since oct.
                    I just used it as a placeholder for the instructions
                    • A
                      ashishtank Module Developer
                      @kusselin : once new version of MM is released today, you will get all the latest code and then it should work.
                      • kusselinK
                        kusselin
                        @ashishtank said in Display waste bins in color:
                        Ahh ok…since achuell is the latest version 2.13.0. i have this version…and today a new verdion is comming…ok i will wait…where can i find the info for new versuon?
                        S A 2 Replies Last reply Reply Quote 0
                          sdetweil @kusselin
                          @kusselin it will be displayed in the banner above when released (version will be 2.14)
                          • A
                            ashishtank Module Developer @kusselin
                            @kusselin details will be here https://forum.magicmirror.builders/category/17/magicmirror
                            • kusselinK
                              kusselin
                              Thank you
                                sdetweil @kusselin
                                @kusselin new release available
                                • kusselinK
                                  kusselin
                                  Ok i see…thanks snd now the update how is standing in the update manual here…right
                                    sdetweil @kusselin
                                    @kusselin eh? not sure what u said. run my upgrade script
                                    see
                                    • kusselinK
                                      kusselin
                                      o.k thanks
                                      • kusselinK
                                        kusselin
                                        here my update installation:
                                        pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                                        No LSB modules are available.
                                        doing test run = false
                                        saving custom.css
                                        upgrading from version 2.13.0 to 2.14.0
                                        fetching latest revisions
                                        From https://github.com/MichMich/MagicMirror
                                           3dbe8bfb..10dc315f  master     -> origin/master
                                         * [new tag]           V2.2.1     -> V2.2.1
                                         * [new tag]           v.2.1.3    -> v.2.1.3
                                         * [new tag]           v2.0.0     -> v2.0.0
                                         * [new tag]           v2.0.1     -> v2.0.1
                                         * [new tag]           v2.0.2     -> v2.0.2
                                         * [new tag]           v2.0.3     -> v2.0.3
                                         * [new tag]           v2.0.4     -> v2.0.4
                                         * [new tag]           v2.0.5     -> v2.0.5
                                         * [new tag]           v2.1.0     -> v2.1.0
                                         * [new tag]           v2.1.1     -> v2.1.1
                                         * [new tag]           v2.1.2     -> v2.1.2
                                         * [new tag]           v2.10.0    -> v2.10.0
                                         * [new tag]           v2.10.1    -> v2.10.1
                                         * [new tag]           v2.11.0    -> v2.11.0
                                         * [new tag]           v2.12.0    -> v2.12.0
                                         * [new tag]           v2.14.0    -> v2.14.0
                                         * [new tag]           v2.2.0     -> v2.2.0
                                         * [new tag]           v2.2.2     -> v2.2.2
                                         * [new tag]           v2.3.0     -> v2.3.0
                                         * [new tag]           v2.3.1     -> v2.3.1
                                         * [new tag]           v2.4.0     -> v2.4.0
                                         * [new tag]           v2.4.1     -> v2.4.1
                                         * [new tag]           v2.5.0     -> v2.5.0
                                         * [new tag]           v2.6.0     -> v2.6.0
                                         * [new tag]           v2.7.0     -> v2.7.0
                                         * [new tag]           v2.7.1     -> v2.7.1
                                         * [new tag]           v2.8.0     -> v2.8.0
                                         * [new tag]           v2.9.0     -> v2.9.0
                                        > core-js@3.7.0 postinstall /home/pi/MagicMirror/node_modules/core-js
                                        > node -e "try{require('./postinstall')}catch(e){}"
                                        Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
                                        The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
                                        > https://opencollective.com/core-js
                                        > https://www.patreon.com/zloirock
                                        Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
                                        > electron@8.5.3 postinstall /home/pi/MagicMirror/node_modules/electron
                                        > node install.js
                                        > magicmirror@2.14.0 install /home/pi/MagicMirror
                                        " && cd vendor && npm install --loglevel=error
                                        > @fortawesome/fontawesome-free@5.15.1 postinstall /home/pi/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free
                                        > node attribution.js
                                        Font Awesome Free 5.15.1 by @fontawesome - https://fontawesome.com
                                        License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License)
                                        updated 3 packages and audited 24 packages in 18.623s
                                        1 package is looking for funding
                                          run `npm fund` for details
                                        found 0 vulnerabilities
                                        > magicmirror@2.14.0 postinstall /home/pi/MagicMirror
                                        > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                        > magicmirror@2.14.0 install-fonts /home/pi/MagicMirror
                                        > echo "Installing fonts ...
                                        " && cd fonts && npm install --loglevel=error
                                        audited 1 package in 3.134s
                                        added 55 packages from 85 contributors, removed 261 packages, updated 72 packages and audited 1149 packages in 324.101s
                                        42 packages are looking for funding
                                        found 1 low severity vulnerability
                                          run `npm audit fix` to fix them, or `npm audit` for details
                                        processing for module MMM-Carousel please wait
                                        npm WARN deprecated nodeunit@0.9.5: you are strongly encouraged to use other testing options
                                        npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                        npm WARN deprecated request@2.79.0: request has been deprecated, see https://github.com/request/request/issues/3142
                                        npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                                        npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                                        npm WARN deprecated hawk@3.1.3: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
                                        npm WARN deprecated har-validator@2.0.6: this library is no longer supported
                                        npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
                                        npm WARN deprecated cryptiles@2.0.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
                                        npm WARN deprecated boom@2.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
                                        npm WARN deprecated sntp@1.0.9: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
                                        npm WARN deprecated core-js@2.6.12: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                                        npm notice created a lockfile as package-lock.json. You should commit this file.
                                        added 522 packages from 374 contributors and audited 522 packages in 150.454s
                                        14 packages are looking for funding
                                        found 88 vulnerabilities (45 low, 12 moderate, 30 high, 1 critical)
                                        processing complete for module MMM-Carousel
                                        processing for module MMM-Remote-Control please wait
                                        added 31 packages from 26 contributors and audited 31 packages in 15.301s
                                        processing complete for module MMM-Remote-Control
                                        processing for module MMM-SoccerLiveScore please wait
                                        up to date in 1.338s
                                        processing complete for module MMM-SoccerLiveScore
                                        processing for module MMM-Formula1 please wait
                                        npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
                                        added 646 packages from 393 contributors and audited 646 packages in 176.234s
                                        58 packages are looking for funding
                                        found 2 low severity vulnerabilities
                                        processing complete for module MMM-Formula1
                                        processing for module MMM-ioBroker please wait
                                        npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                                        added 47 packages from 502 contributors and audited 47 packages in 20.087s
                                        3 packages are looking for funding
                                        processing complete for module MMM-ioBroker
                                        processing for module MMM-Fuel please wait
                                        added 458 packages from 286 contributors and audited 458 packages in 137.315s
                                        84 packages are looking for funding
                                        processing complete for module MMM-Fuel
                                        processing for module MMM-PublicTransportHafas please wait
                                        npm WARN deprecated hafas-client@2.10.4: Deprecated. Use hafas-client@latest.
                                        npm WARN deprecated vbb-translate-ids@3.1.0: Deprecated. Use vbb-translate-ids@latest.
                                        added 33 packages from 23 contributors and audited 33 packages in 18.988s
                                        processing complete for module MMM-PublicTransportHafas
                                        processing for module MMM-Tools please wait
                                        added 3 packages from 3 contributors and audited 3 packages in 4.837s
                                        processing complete for module MMM-Tools
                                        processing for module MMM-Traffic please wait
                                        added 2 packages from 7 contributors and audited 2 packages in 5.081s
                                        processing complete for module MMM-Traffic
                                        restoring custom.css
                                        what sy me this? What must i do for them?
                                        Must i make really npm audit fix in the console??
                                          sdetweil @kusselin
                                          @kusselin ok, wait some more… it will say its done
                                          • kusselinK
                                            kusselin
                                            o.k. and this is my version now:
                                                    "version": "2.14.0",
                                            • 2 / 3
