Overflow with calendar?
11 Posts 2 Posters 1.8k Views 2 Watching
    avanloo01
    I have this calendar of my high school with all my assignments. I wanted to add this to my mirror, but I got an error.
    bytesParsed: 8281,
      code: 'HPE_HEADER_OVERFLOW',
      reason: 'Header overflow'
    Any help?
    Thanks!
    S 1 Reply Last reply Dec 19, 2020, 1:26 PM Reply Quote 0
      sdetweil @avanloo01
      @avanloo01 eh? show me the config?
        avanloo01
        Can I do this in like a private message or something, because I don’t know if I can just post the link on the internet.
        S 1 Reply Last reply Dec 19, 2020, 1:30 PM Reply Quote 0
          sdetweil @avanloo01
          @avanloo01 sure, just start a chat with me, click the bubble to the left, and then click chat
            avanloo01
            I sent you a message.
            S 1 Reply Last reply Dec 20, 2020, 1:02 PM Reply Quote 0
              we worked offline, and there was a security fix to reduce the header buffer size from 80,000 to 8,000 bytes.
              the server is sending a misformatted message with the calendar results
              the workarounds for this issue do not work
              https://github.com/nodejs/node/issues/24692
                sdetweil @avanloo01
                @avanloo01 here is a workaround…
                do
                export NODE_OPTIONS=--max-http-header-size=10000
                then
                npm start
                if you use pm2 to launch MM, then add that line to the script that is launched by pm2
                (typically MagicMirror/installers/mm.sh)
                  avanloo01
                  Thank you so much!
                  S 1 Reply Last reply Dec 21, 2020, 1:28 PM Reply Quote 0
                    sdetweil @avanloo01
                    @avanloo01 did it work? I’m guessing so
                      avanloo01
                      Yes, it did.
                      S 1 Reply Last reply Dec 23, 2020, 2:30 PM Reply Quote 0
