Overflow with calendar?
I have this calendar of my high school with all my assignments. I wanted to add this to my mirror, but I got an error.
bytesParsed: 8281, code: 'HPE_HEADER_OVERFLOW', reason: 'Header overflow'Any help?
Thanks! -
@avanloo01 eh? show me the config?
Can I do this in like a private message or something, because I don’t know if I can just post the link on the internet.
@avanloo01 sure, just start a chat with me, click the bubble to the left, and then click chat
I sent you a message.
we worked offline, and there was a security fix to reduce the header buffer size from 80,000 to 8,000 bytes.
the server is sending a misformatted message with the calendar resultsthe workarounds for this issue do not work
https://github.com/nodejs/node/issues/24692 -
@avanloo01 here is a workaround…
do
export NODE_OPTIONS=--max-http-header-size=10000then
npm startif you use pm2 to launch MM, then add that line to the script that is launched by pm2
(typically MagicMirror/installers/mm.sh) -
Thank you so much!
@avanloo01 did it work? I’m guessing so
Yes, it did.
@avanloo01 awesome… I will close the issue i opened…
