    Overflow with calendar?
    11 Posts 2 Posters 2.4k Views 2 Watching
      avanloo01
      I have this calendar of my high school with all my assignments. I wanted to add this to my mirror, but I got an error.
      bytesParsed: 8281,
        code: 'HPE_HEADER_OVERFLOW',
        reason: 'Header overflow'
      Any help?
      Thanks!
        sdetweil @avanloo01
        @avanloo01 eh? show me the config?
          avanloo01
          Can I do this in like a private message or something, because I don’t know if I can just post the link on the internet.
            sdetweil @avanloo01
            @avanloo01 sure, just start a chat with me, click the bubble to the left, and then click chat
              avanloo01
              I sent you a message.
                we worked offline, and there was a security fix to reduce the header buffer size from 80,000 to 8,000 bytes.
                the server is sending a misformatted message with the calendar results
                the workarounds for this issue do not work
                https://github.com/nodejs/node/issues/24692
                  sdetweil @avanloo01
                  @avanloo01 here is a workaround…
                  do
                  export NODE_OPTIONS=--max-http-header-size=10000
                  then
                  npm start
                  if you use pm2 to launch MM, then add that line to the script that is launched by pm2
                  (typically MagicMirror/installers/mm.sh)
                    avanloo01
                    Thank you so much!
                      sdetweil @avanloo01
                      @avanloo01 did it work? I’m guessing so
                        avanloo01
                        Yes, it did.
