    After update, nothing happens.
    64 Posts 3 Posters 33.9k Views 3 Watching
      Richard238 @sdetweil
      No, it’s a Pi 3B
        sdetweil @Richard238
        @Richard238 hm… rename your magic mirror folder to some other name
        then run my installer to get everything updated
        the in your existing folder do
        rm -rf node_moules
        npm install --only=prod
        then npm start and see what happens
        my installer will start.mm again, just do.pm2 stop all, and we will fix it later
        see here for the installer script
          Do I run your installer
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
          from the (renamed) MM folder, or from the /home/pi prompt?
            @Richard238 /home/pi… it will figure it out
              pi@pi_mirror:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
              #: “#!/bin/bash: No such file or directory
              pi@pi_mirror:~ $
                @Richard238 the quotes need to be up/down, not slanted
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                if u paste that line here without the code block wrapper, the quotes will be changed
                  pi@pi_mirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                  It appears MagicMirror has not been installed on this system
                  please run the installer, raspberry.sh first
                  pi@pi_mirror:~ $
                    @Richard238 not upgrade, install
                      Ooops! You can tell it’s New Years Day, maybe I need another drink. :D
                        Richard238
                        Splashscreen: Changed theme to MagicMirror successfully.
                        Do you want use pm2 for auto starting of your MagicMirror (y/N)?
                          @Richard238 no
                            ~/install.log should say we upgraded node to 10.23 ish and npm to 6.14 ish
                              Richard238
                              Do you want use pm2 for auto starting of your MagicMirror (y/N)?N
                              Do you want to disable the screen saver? (y/N)?
                              We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                              pi@pi_mirror:~ $
                              As a new user, you can only post once every 120 second(s) until you have earned 3 reputation - please wait before posting again …New User? I’ve been a member for years?
                              S A 2 Replies Last reply Reply Quote 0
                                @Richard238 no idea…
                                so, now
                                node --v
                                npm --v
                                go to the old folder, delete the node_modules folder
                                rm -rf node_modules
                                then npm start
                                  ashishtank Module Developer @Richard238
                                  @Richard238 you need at least 3 reputation to post more often. It will be visible in your profile.
                                    @sdetweil said in After update, nothing happens.:
                                    [92mNode.js installation Done! version=v10.23.0
                                    0mInstalled npm version: V6.14.8
                                      so, now
                                      node --v
                                      npm --v
                                      pi@pi_mirror:~ $ node --v
                                      node: bad option: --v
                                      pi@pi_mirror:~ $ npm --v
                                      6.14.8
                                      pi@pi_mirror:~ $ node -v
                                      v10.23.0
                                      pi@pi_mirror:~ $
                                        @Richard238 ok, up to level
                                          Richard238
                                          MagicMirror installation finished successfully!
                                          added 330 packages from 282 contributors and audited 1149 packages in 152.782s
                                          16 packages are looking for funding
                                            run `npm fund` for details
                                          found 1 low severity vulnerability
                                            run `npm audit fix` to fix them, or `npm audit` for details
                                          pi@pi_mirror:~/MagicMirror__RL1 $ npm start
                                          > magicmirror@2.14.0-develop start /home/pi/MagicMirror__RL1
                                          /home/pi/MagicMirror__RL1/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror__RL1/node_modules/electron/dist/electron)
                                            @Richard238 interesting. I have to go pick up grandson, be unable to research for a few hours. 3ish…
                                            • 2 / 4
