    After update, nothing happens.
    64 Posts 3 Posters 35.9k Views 3 Watching
      sdetweil @Richard238
      @Richard238 yes pm2 stop all
        Richard238
        pi@pi_mirror:~ $ pm2 stop all
        [PM2] Applying action stopProcessId on app [all](ids: 0)
        [PM2] [mm](0) ✓
        │ Name │ mode │ status  │ ↺ │ cpu │ memory │
        │ mm   │ fork │ stopped │ 0 │ 0%  │ 0 B    │
         Use `pm2 show <id|name>` to get more details about an app
        pi@pi_mirror:~ $ cd ~/MagicMirror__RL1
        pi@pi_mirror:~/MagicMirror__RL1 $ git pull origin develop
        remote: Enumerating objects: 8, done.
        remote: Counting objects: 100% (8/8), done.
        remote: Compressing objects: 100% (8/8), done.
        remote: Total 8 (delta 1), reused 0 (delta 0), pack-reused 0
        Unpacking objects: 100% (8/8), done.
        From https://github.com/MichMich/MagicMirror
         * branch            develop    -> FETCH_HEAD
           a4ab0cb..da00c16  develop    -> origin/develop
        Updating a4ab0cb..da00c16
        Fast-forward
         CHANGELOG.md | 1 +
         js/module.js | 2 +-
         2 files changed, 2 insertions(+), 1 deletion(-)
        pi@pi_mirror:~/MagicMirror__RL1 $ npm install --only=prod
        > magicmirror@2.14.0-develop install /home/pi/MagicMirror__RL1
        " && cd vendor && npm install --loglevel=error
        audited 24 packages in 1.991s
        1 package is looking for funding
          run `npm fund` for details
        found 0 vulnerabilities
        > magicmirror@2.14.0-develop postinstall /home/pi/MagicMirror__RL1
        > npm run install-fonts && echo "MagicMirror installation finished successfully!
        > magicmirror@2.14.0-develop install-fonts /home/pi/MagicMirror__RL1
        > echo "Installing fonts ...
        " && cd fonts && npm install --loglevel=error
        audited 1 package in 1.03s
        audited 1149 packages in 36.561s
        16 packages are looking for funding
        found 1 low severity vulnerability
          run `npm audit fix` to fix them, or `npm audit` for details
        pi@pi_mirror:~/MagicMirror__RL1 $ npm start
        > magicmirror@2.14.0-develop start /home/pi/MagicMirror__RL1
        /home/pi/MagicMirror__RL1/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror__RL1/node_modules/electron/dist/electron)
          @sdetweil the new install used the master branch, so on electron 6. the old folder is on develop, so electron 8.5
            @Richard238 ok. 1st time seeing this…
            just to make sure
            from the old folder
            grep version node_modules/electron/package.json
              Richard238
              @sdetweil said in After update, nothing happens.:
              pi@pi_mirror:~/MagicMirror__RL1 $ grep version node_modules/electron/package.json
              “type”: “version”,
              “version”: “8.5.3”
                @sdetweil one more diag command
                lsb_release -a
                  Richard238
                  pi@pi_mirror:~ $ lsb_release -a
                  No LSB modules are available.
                  Distributor ID: Raspbian
                  Description: Raspbian GNU/Linux 8.0 (jessie)
                  Release: 8.0
                  Codename: jessie
                  pi@pi_mirror:~ $
                    @Richard238 ok, thx. problem is new electron won’t run on Jessie anymore…
                    I don’t know if this will work.
                    from. the old mm folder
                    rm -rf node_modules/electron
                    npm install electron@6.1.12
                    then npm start
                      Richard238
                      Sam, you’re a genius!
                      That’s fixed it.
                      This will only happen again in the not too distant future I’m sure, so would I be better off installing a newer OS?
                      And then how do I recreate my MM on said new OS?
                      I’m going to logoff for now, thanks again for your help today.
                      More tomorrow I’m sure.
                      Kind regards,
                      Richard.
                        @Richard238
                        copy your MagicMirror folder to save it somewhere
                        u can zip it to to save space
                        install buster on your sd card
                        run the installer to get things setup
                        restore you MM zip file
                        erase the node_modules folder
                        npm install (this should put on the newer electron)
                        npm start
                          Richard238
                          Old MM FTPd to NAS.
                          Installing new OS now, on a different SD card so I can go back if absolutely necessary.
                          My plan is to build a new MM as the old one had a lot of clutter - old unused modules etc.
                          Taking the opportunity for a fresh start. I’ll let you know how it goes…
                          R 1 Reply Last reply
                            Richard238 @Richard238
                            @Richard238 said in After update, nothing happens.:
                            Old MM FTPd to NAS.
                            14:24
                            All done.
                            MM back just as it was with custom CSS, but this time using only the modules installed that I actually need.
                            MM accessible from any LAN attached device as I don’t have it setup as a mirror anywhere.
                            The terminal window is showing a constatnt log of what’s happening. Is that correct - I don’t remember it from MM_OLD?
                            And will the update notification module do anything now, or do I need to do anything?
                            S 2 Replies Last reply
                              @Richard238 edit the config.js, there us a new logLevel setting, make sure debug is not included
                                @Richard238 updatenotification will continue to advise things that have changed…
                                are u at 2.14 w 8.5 electron?
                                  Richard238
                                  I copied my config.js into the new install, and deleted all the old commented-out module junk I was no longer using.
                                  Added the 'loglevel: [… ’ line, doesn’t yet seem to have made any difference. Reboot required perhaps?
                                  2.14? Package.Json = “version” : “2.14.0”
                                  Electron is 8.5
                                  pi@magicmirror:~/MagicMirror $ grep version node_modules/electron/package.json
                                    "version": "8.5.5"
                                    @Richard238 can u show me some of the messages?
                                      @Richard238 notice its logLevel, second l is capital
                                        Richard238 @sdetweil
                                        rue" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                                        [02.01.2021 14:46.31.149] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/##################################### Interval: 300000
                                        [02.01.2021 14:46.31.360] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/##################################### Interval: 300000
                                        [02.01.2021 14:46.31.366] [LOG]   Create new news fetcher for url: http://feeds.reuters.com/reuters/UKTopNews - Interval: 120000
                                        [02.01.2021 14:46.31.437] [LOG]   Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 120000
                                        [02.01.2021 14:46.31.447] [INFO]  Checking git for module: MMM-doomsDay
                                        [02.01.2021 14:46.31.455] [INFO]  Checking git for module: MMM-MysqlQuery
                                        [02.01.2021 14:46.32.473] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
                                        [02.01.2021 14:46.33.722] [INFO]  Calendar-Fetcher: Broadcasting 4 events.
                                        [02.01.2021 14:46.35.400] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [02.01.2021 14:48.32.644] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
                                        ipWhitelist: [],
                                        	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
                                        	language: 'en',
                                        	timeFormat: 24,
                                        I guess changing it to logLevel: [] ?
                                          @Richard238 all of the messages are normal.
                                          maybe u started w pm2 before
                                            @Richard238 just FYI we were able to reproduce your problem on Jessie. So os upgrade, or downgrade electron were the only options
                                            • 3 / 4
