    After update, nothing happens.
    64 Posts 3 Posters 31.5k Views 3 Watching
      sdetweil @Richard238
      @Richard238 ok, thx. problem is new electron won’t run on Jessie anymore…
      I don’t know if this will work.
      from. the old mm folder
      rm -rf node_modules/electron
      npm install electron@6.1.12
      then npm start
        Richard238
        @sdetweil said in After update, nothing happens.:
        Sam, you’re a genius!
        That’s fixed it.
        This will only happen again in the not too distant future I’m sure, so would I be better off installing a newer OS?
        And then how do I recreate my MM on said new OS?
        I’m going to logoff for now, thanks again for your help today.
        More tomorrow I’m sure.
        Kind regards,
        Richard.
          @Richard238
          copy your MagicMirror folder to save it somewhere
          u can zip it to to save space
          install buster on your sd card
          run the installer to get things setup
          restore you MM zip file
          erase the node_modules folder
          npm install (this should put on the newer electron)
          npm start
            Richard238
            Old MM FTPd to NAS.
            Installing new OS now, on a different SD card so I can go back if absolutely necessary.
            My plan is to build a new MM as the old one had a lot of clutter - old unused modules etc.
            Taking the opportunity for a fresh start. I’ll let you know how it goes…
              Richard238 @Richard238
              @Richard238 said in After update, nothing happens.:
              Old MM FTPd to NAS.
              14:24
              All done.
              MM back just as it was with custom CSS, but this time using only the modules installed that I actually need.
              MM accessible from any LAN attached device as I don’t have it setup as a mirror anywhere.
              The terminal window is showing a constatnt log of what’s happening. Is that correct - I don’t remember it from MM_OLD?
              And will the update notification module do anything now, or do I need to do anything?
                @Richard238 edit the config.js, there us a new logLevel setting, make sure debug is not included
                  @Richard238 updatenotification will continue to advise things that have changed…
                  are u at 2.14 w 8.5 electron?
                    Richard238
                    I copied my config.js into the new install, and deleted all the old commented-out module junk I was no longer using.
                    Added the 'loglevel: [… ’ line, doesn’t yet seem to have made any difference. Reboot required perhaps?
                    2.14? Package.Json = “version” : “2.14.0”
                    Electron is 8.5
                    pi@magicmirror:~/MagicMirror $ grep version node_modules/electron/package.json
                      "version": "8.5.5"
                      @Richard238 can u show me some of the messages?
                        @Richard238 notice its logLevel, second l is capital
                          Richard238 @sdetweil
                          rue" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                          [02.01.2021 14:46.31.149] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/##################################### Interval: 300000
                          [02.01.2021 14:46.31.360] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/##################################### Interval: 300000
                          [02.01.2021 14:46.31.366] [LOG]   Create new news fetcher for url: http://feeds.reuters.com/reuters/UKTopNews - Interval: 120000
                          [02.01.2021 14:46.31.437] [LOG]   Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 120000
                          [02.01.2021 14:46.31.447] [INFO]  Checking git for module: MMM-doomsDay
                          [02.01.2021 14:46.31.455] [INFO]  Checking git for module: MMM-MysqlQuery
                          [02.01.2021 14:46.32.473] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
                          [02.01.2021 14:46.33.722] [INFO]  Calendar-Fetcher: Broadcasting 4 events.
                          [02.01.2021 14:46.35.400] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                          [02.01.2021 14:48.32.644] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
                          ipWhitelist: [],
                          	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
                          	language: 'en',
                          	timeFormat: 24,
                          I guess changing it to logLevel: [] ?
                            @Richard238 all of the messages are normal.
                            maybe u started w pm2 before
                              @Richard238 just FYI we were able to reproduce your problem on Jessie. So os upgrade, or downgrade electron were the only options
                                Rebooted, no change. Not a worry, just curious.
                                How though do I get MM to auto start at boot?
                                  @Richard238 use pm2, u should have been prompted during my scripted install.
                                  but use the fixuppm2 instructions here, last entry on the page
                                    Does that mean a change to the documentation, or have the install/update script(s) check for OS level before proceeding? (Or both, of course.)
                                    There must be many, many MM installs out there running on old OSs.
                                      @Richard238 i will update my scripts to check and advise.
                                      but my scripts are optional. I doubt the base will check. technically only supports pi3 and 4, but I try to make it to run anywhere
                                        We found a bug and a fix. And it was all done in a day or so! :)
                                        Looks like a great result all round then where we’ve all learned something.
                                        Thank you for your help.
                                        Richard.
                                          @Richard238 my pleasure.
                                            A month on, and I’ve not had any update prompts, is that correct?
                                            Thank you.
                                            • 3 / 4
