    After update, nothing happens.
    64 Posts 3 Posters 33.9k Views 3 Watching
      Richard238
      @sdetweil said in After update, nothing happens.:
      npm install electron@6.1.12
      Sam, you’re a genius!
      That’s fixed it.
      This will only happen again in the not too distant future I’m sure, so would I be better off installing a newer OS?
      And then how do I recreate my MM on said new OS?
      I’m going to logoff for now, thanks again for your help today.
      More tomorrow I’m sure.
      Kind regards,
      Richard.
        sdetweil @Richard238
        @Richard238
        copy your MagicMirror folder to save it somewhere
        u can zip it to to save space
        install buster on your sd card
        run the installer to get things setup
        restore you MM zip file
        erase the node_modules folder
        npm install (this should put on the newer electron)
        npm start
          Richard238
          Old MM FTPd to NAS.
          Installing new OS now, on a different SD card so I can go back if absolutely necessary.
          My plan is to build a new MM as the old one had a lot of clutter - old unused modules etc.
          Taking the opportunity for a fresh start. I’ll let you know how it goes…
            Richard238 @Richard238
            @Richard238 said in After update, nothing happens.:
            Old MM FTPd to NAS.
            14:24
            All done.
            MM back just as it was with custom CSS, but this time using only the modules installed that I actually need.
            MM accessible from any LAN attached device as I don’t have it setup as a mirror anywhere.
            The terminal window is showing a constatnt log of what’s happening. Is that correct - I don’t remember it from MM_OLD?
            And will the update notification module do anything now, or do I need to do anything?
              @Richard238 edit the config.js, there us a new logLevel setting, make sure debug is not included
                @Richard238 updatenotification will continue to advise things that have changed…
                are u at 2.14 w 8.5 electron?
                  Richard238
                  I copied my config.js into the new install, and deleted all the old commented-out module junk I was no longer using.
                  Added the 'loglevel: [… ’ line, doesn’t yet seem to have made any difference. Reboot required perhaps?
                  2.14? Package.Json = “version” : “2.14.0”
                  Electron is 8.5
                  pi@magicmirror:~/MagicMirror $ grep version node_modules/electron/package.json
                    "version": "8.5.5"
                    @Richard238 can u show me some of the messages?
                      @Richard238 notice its logLevel, second l is capital
                        Richard238 @sdetweil
                        rue" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                        [02.01.2021 14:46.31.149] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/##################################### Interval: 300000
                        [02.01.2021 14:46.31.360] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/##################################### Interval: 300000
                        [02.01.2021 14:46.31.366] [LOG]   Create new news fetcher for url: http://feeds.reuters.com/reuters/UKTopNews - Interval: 120000
                        [02.01.2021 14:46.31.437] [LOG]   Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 120000
                        [02.01.2021 14:46.31.447] [INFO]  Checking git for module: MMM-doomsDay
                        [02.01.2021 14:46.31.455] [INFO]  Checking git for module: MMM-MysqlQuery
                        [02.01.2021 14:46.32.473] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
                        [02.01.2021 14:46.33.722] [INFO]  Calendar-Fetcher: Broadcasting 4 events.
                        [02.01.2021 14:46.35.400] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                        [02.01.2021 14:48.32.644] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
                        ipWhitelist: [],
                        	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
                        	language: 'en',
                        	timeFormat: 24,
                        I guess changing it to logLevel: [] ?
                          @Richard238 all of the messages are normal.
                          maybe u started w pm2 before
                            @Richard238 just FYI we were able to reproduce your problem on Jessie. So os upgrade, or downgrade electron were the only options
                              Rebooted, no change. Not a worry, just curious.
                              How though do I get MM to auto start at boot?
                                @Richard238 use pm2, u should have been prompted during my scripted install.
                                but use the fixuppm2 instructions here, last entry on the page
                                  Does that mean a change to the documentation, or have the install/update script(s) check for OS level before proceeding? (Or both, of course.)
                                  There must be many, many MM installs out there running on old OSs.
                                    @Richard238 i will update my scripts to check and advise.
                                    but my scripts are optional. I doubt the base will check. technically only supports pi3 and 4, but I try to make it to run anywhere
                                      We found a bug and a fix. And it was all done in a day or so! :)
                                      Looks like a great result all round then where we’ve all learned something.
                                      Thank you for your help.
                                      Richard.
                                        @Richard238 my pleasure.
                                          A month on, and I’ve not had any update prompts, is that correct?
                                          Thank you.
                                            @richard238 outside modules have certainly changed since then. base is once every 90 days
                                            • 3 / 4
