    Can't install MMM-Navigate
    13 Posts 3 Posters 3.4k Views 3 Watching
    • K Offline
      keineAhnung123
      Im trying to install the MMM-Navigate module made by @AxLed.
      When running
      npm install
      following message return:
      pi@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ npm install
      > MagicMirror-Module-Navigate@1.4.0 install /home/pi/MagicMirror/modules/MMM-Navigate
      > electron-rebuild
      /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/fs-extra/lib/mkdirs/make-dir.js:85
            } catch {
      SyntaxError: Unexpected token {
          at new Script (vm.js:51:7)
          at createScript (vm.js:136:10)
          at Object.runInThisContext (vm.js:197:10)
          at Module._compile (internal/modules/cjs/loader.js:618:28)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
          at Module.load (internal/modules/cjs/loader.js:566:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
          at Function.Module._load (internal/modules/cjs/loader.js:498:3)
          at Module.require (internal/modules/cjs/loader.js:598:17)
          at require (internal/modules/cjs/helpers.js:11:18)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! MagicMirror-Module-Navigate@1.4.0 install: `electron-rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the MagicMirror-Module-Navigate@1.4.0 install script.
      npm ERR!     /home/pi/.npm/_logs/2021-01-03T17_47_54_887Z-debug.log
      When i start the MagicMirror following error in in console:
      [03.01.2021 18:56.24.542] [LOG]   Module helper loaded: MMM-Page-Selector
      [03.01.2021 18:56.24.602] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 59. This version of Node.js requires
      NODE_MODULE_VERSION 76. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
      [03.01.2021 18:56.24.622] [ERROR] App threw an error during load
      [03.01.2021 18:56.24.626] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
          at process.func [as dlopen] (electron/js2c/asar.js:140:31)
          at Object.Module._extensions..node (internal/modules/cjs/loader.js:1016:18)
          at Object.func [as .node] (electron/js2c/asar.js:140:31)
          at Module.load (internal/modules/cjs/loader.js:816:32)
          at Module._load (internal/modules/cjs/loader.js:728:14)
          at Function.Module._load (electron/js2c/asar.js:748:26)
          at Module.require (internal/modules/cjs/loader.js:853:19)
          at require (internal/modules/cjs/helpers.js:74:18)
          at bindings (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/bindings/bindings.js:112:48)
          at /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:7:31
      [03.01.2021 18:56.24.630] [ERROR] Whoops! There was an uncaught exception...
      [03.01.2021 18:56.24.638] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
      Can someone imagine whats the problem?
      Thanks in advance :)
        sdetweil @keineAhnung123
        @keineAhnung123 show results of
        node -v
        npm -v
        • K Offline
          keineAhnung123
          pi@raspberrypi:~ $ node -v
          v9.11.2
          pi@raspberrypi:~ $ npm -v
          6.14.10
          node seems to be outdated?
          I will try to update it
          • K Offline
            keineAhnung123 @keineAhnung123
            sudo apt remove nodejs
            sudo apt install nodejs
            still Version 9.11.2 :(
              @keineAhnung123 install nvm, and then use nvm to install node 10.23
              https://www.sitepoint.com/quick-tip-multiple-versions-node-nvm/
              • K Offline
                keineAhnung123
                Thank you, that worked.
                Is there a reason why 10.23 and not the newest 14.15.3 or 15.0?
                  @keineAhnung123 cause we haven’t tested w those levels yet
                    matze86 @sdetweil
                    I tried to start my Mirror in server mode and than i got this error:
                    [17.03.2021 20:17.36.506] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                    NODE_MODULE_VERSION 76. This version of Node.js requires
                    NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
                    [17.03.2021 20:17.36.508] [LOG]   Loading module helpers ...
                    [17.03.2021 20:17.36.509] [LOG]   No helper found for module: alert.
                    [17.03.2021 20:17.36.510] [LOG]   Initializing new module helper ...
                    [17.03.2021 20:17.36.510] [LOG]   Module helper loaded: updatenotification
                    [17.03.2021 20:17.36.511] [LOG]   No helper found for module: clock.
                    [17.03.2021 20:17.36.517] [ERROR] Whoops! There was an uncaught exception...
                    [17.03.2021 20:17.36.522] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                        at Object.Module._extensions..node (internal/modules/cjs/loader.js:1122:18)
                        at Module.load (internal/modules/cjs/loader.js:928:32)
                        at Function.Module._load (internal/modules/cjs/loader.js:769:14)
                        at Module.require (internal/modules/cjs/loader.js:952:19)
                        at require (internal/modules/cjs/helpers.js:88:18)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:15:3)
                        at Module._compile (internal/modules/cjs/loader.js:1063:30)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
                    [17.03.2021 20:17.36.525] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [17.03.2021 20:17.36.526] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    in “non-server-mode” it works very well.
                    i reinstalled the module , npm, node.js, electron, but it still doesn’t work
                    Any idea?
                      sdetweil @matze86
                      @matze86 right. the library epoll is compiled for electron, but not just node. (server mode)
                      per the messages, I would try npm rebuild
                        matze86 @sdetweil
                        npm rebuild failed:
                        pi@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ npm rebuild
                        npm ERR! code 1
                        npm ERR! path /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll
                        npm ERR! command failed
                        npm ERR! command sh -c node-gyp rebuild
                        npm ERR! gyp info it worked if it ends with ok
                        npm ERR! gyp info using node-gyp@7.1.2
                        npm ERR! gyp info using node@14.16.0 | linux | arm
                        npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
                        npm ERR! gyp info spawn /usr/bin/python3
                        npm ERR! gyp info spawn args [
                        npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/gyp/gyp_main.py',
                        npm ERR! gyp info spawn args   'binding.gyp',
                        npm ERR! gyp info spawn args   '-f',
                        npm ERR! gyp info spawn args   'make',
                        npm ERR! gyp info spawn args   '-I',
                        npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/config.gypi',
                        npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/addon.gypi',
                        npm ERR! gyp info spawn args   '/home/pi/.cache/node-gyp/14.16.0/include/node/common.gypi',
                        npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                        npm ERR! gyp info spawn args   '-Dvisibility=default',
                        npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/pi/.cache/node-gyp/14.16.0',
                        npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp',
                        npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/pi/.cache/node-gyp/14.16.0/<(target_arch)/node.lib',
                        npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll',
                        npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                        npm ERR! gyp info spawn args   '--depth=.',
                        npm ERR! gyp info spawn args   '--no-parallel',
                        npm ERR! gyp info spawn args   '--generator-output',
                        npm ERR! gyp info spawn args   'build',
                        npm ERR! gyp info spawn args   '-Goutput_dir=.'
                        npm ERR! gyp info spawn args ]
                        npm ERR! gyp ERR! build error
                        npm ERR! gyp ERR! stack Error: You must run `node-gyp configure` first!
                        npm ERR! gyp ERR! stack     at ReadFileContext.<anonymous> (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/lib/build.js:43:20)
                        npm ERR! gyp ERR! stack     at ReadFileContext.callback (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/graceful-fs/graceful-fs.js:123:16)
                        npm ERR! gyp ERR! stack     at FSReqCallback.readFileAfterOpen [as oncomplete] (fs.js:273:13)
                        npm ERR! gyp ERR! System Linux 5.10.11-v7l+
                        npm ERR! gyp ERR! command "/usr/local/bin/node" "/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/.bin/node-gyp" "rebuild"
                        npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll
                        npm ERR! gyp ERR! node -v v14.16.0
                        npm ERR! gyp ERR! node-gyp -v v7.1.2
                        npm ERR! gyp ERR! not ok
                        npm ERR!     /home/pi/.npm/_logs/2021-03-17T21_03_25_216Z-debug.log
                        i tried with npm install (a second time), but this doesn’t change anything
                          sdetweil @matze86
                          @matze86 sorry. no idea from here.i had a similar problem in one of my modules.
                          I rewrote part of it to eliminate the troublesome library
                            matze86 @sdetweil
                            now i reinstalled raspberry os and still got the same error…
                            [19.03.2021 23:16.00.366] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                            NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                            [19.03.2021 23:16.00.367] [LOG]   Loading module helpers ...
                            [19.03.2021 23:16.00.368] [LOG]   No helper found for module: alert.
                            [19.03.2021 23:16.00.368] [LOG]   Initializing new module helper ...
                            [19.03.2021 23:16.00.369] [LOG]   Module helper loaded: updatenotification
                            [19.03.2021 23:16.00.370] [LOG]   No helper found for module: clock.
                            [19.03.2021 23:16.00.374] [ERROR] Whoops! There was an uncaught exception...
                            [19.03.2021 23:16.00.378] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                                at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                                at Module.require (internal/modules/cjs/loader.js:692:17)
                                at require (internal/modules/cjs/helpers.js:25:18)
                                at module.exports._ (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:7:31)
                            [19.03.2021 23:16.00.379] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            [19.03.2021 23:16.00.380] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              sdetweil @matze86
                              @matze86 do this
                              from the MMM-Navigate folder
                              npm rebuild epoll --update-binary
                              worked for me
                              note that this compiled version won’t work if you use electron now…
