    Can't install MMM-Navigate
    13 Posts 3 Posters 3.8k Views 3 Watching
      sdetweil @keineAhnung123
      @keineAhnung123 show results of
      node -v
      npm -v
      • K
        keineAhnung123
        pi@raspberrypi:~ $ node -v
        v9.11.2
        pi@raspberrypi:~ $ npm -v
        6.14.10
        node seems to be outdated?
        I will try to update it
        • K
          keineAhnung123 @keineAhnung123
          sudo apt remove nodejs
          sudo apt install nodejs
          still Version 9.11.2 :(
            @keineAhnung123 install nvm, and then use nvm to install node 10.23
            https://www.sitepoint.com/quick-tip-multiple-versions-node-nvm/
            • K
              keineAhnung123
              Thank you, that worked.
              Is there a reason why 10.23 and not the newest 14.15.3 or 15.0?
                @keineAhnung123 cause we haven’t tested w those levels yet
                  matze86 @sdetweil
                  I tried to start my Mirror in server mode and than i got this error:
                  [17.03.2021 20:17.36.506] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                  was compiled against a different Node.js version using
                  NODE_MODULE_VERSION 76. This version of Node.js requires
                  NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
                  the module (for instance, using `npm rebuild` or `npm install`).
                  [17.03.2021 20:17.36.508] [LOG]   Loading module helpers ...
                  [17.03.2021 20:17.36.509] [LOG]   No helper found for module: alert.
                  [17.03.2021 20:17.36.510] [LOG]   Initializing new module helper ...
                  [17.03.2021 20:17.36.510] [LOG]   Module helper loaded: updatenotification
                  [17.03.2021 20:17.36.511] [LOG]   No helper found for module: clock.
                  [17.03.2021 20:17.36.517] [ERROR] Whoops! There was an uncaught exception...
                  [17.03.2021 20:17.36.522] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                      at Object.Module._extensions..node (internal/modules/cjs/loader.js:1122:18)
                      at Module.load (internal/modules/cjs/loader.js:928:32)
                      at Function.Module._load (internal/modules/cjs/loader.js:769:14)
                      at Module.require (internal/modules/cjs/loader.js:952:19)
                      at require (internal/modules/cjs/helpers.js:88:18)
                      at bindings (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/bindings/bindings.js:112:48)
                      at /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:7:31
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:15:3)
                      at Module._compile (internal/modules/cjs/loader.js:1063:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
                  [17.03.2021 20:17.36.525] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [17.03.2021 20:17.36.526] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  in “non-server-mode” it works very well.
                  i reinstalled the module , npm, node.js, electron, but it still doesn’t work
                  Any idea?
                    sdetweil @matze86
                    @matze86 right. the library epoll is compiled for electron, but not just node. (server mode)
                    per the messages, I would try npm rebuild
                      matze86 @sdetweil
                      npm rebuild failed:
                      pi@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ npm rebuild
                      npm ERR! code 1
                      npm ERR! path /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll
                      npm ERR! command failed
                      npm ERR! command sh -c node-gyp rebuild
                      npm ERR! gyp info it worked if it ends with ok
                      npm ERR! gyp info using node-gyp@7.1.2
                      npm ERR! gyp info using node@14.16.0 | linux | arm
                      npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
                      npm ERR! gyp info spawn /usr/bin/python3
                      npm ERR! gyp info spawn args [
                      npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/gyp/gyp_main.py',
                      npm ERR! gyp info spawn args   'binding.gyp',
                      npm ERR! gyp info spawn args   '-f',
                      npm ERR! gyp info spawn args   'make',
                      npm ERR! gyp info spawn args   '-I',
                      npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/config.gypi',
                      npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/addon.gypi',
                      npm ERR! gyp info spawn args   '/home/pi/.cache/node-gyp/14.16.0/include/node/common.gypi',
                      npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                      npm ERR! gyp info spawn args   '-Dvisibility=default',
                      npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/pi/.cache/node-gyp/14.16.0',
                      npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp',
                      npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/pi/.cache/node-gyp/14.16.0/<(target_arch)/node.lib',
                      npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll',
                      npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                      npm ERR! gyp info spawn args   '--depth=.',
                      npm ERR! gyp info spawn args   '--no-parallel',
                      npm ERR! gyp info spawn args   '--generator-output',
                      npm ERR! gyp info spawn args   'build',
                      npm ERR! gyp info spawn args   '-Goutput_dir=.'
                      npm ERR! gyp info spawn args ]
                      npm ERR! gyp ERR! build error
                      npm ERR! gyp ERR! stack Error: You must run `node-gyp configure` first!
                      npm ERR! gyp ERR! stack     at ReadFileContext.<anonymous> (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/lib/build.js:43:20)
                      npm ERR! gyp ERR! stack     at ReadFileContext.callback (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/graceful-fs/graceful-fs.js:123:16)
                      npm ERR! gyp ERR! stack     at FSReqCallback.readFileAfterOpen [as oncomplete] (fs.js:273:13)
                      npm ERR! gyp ERR! System Linux 5.10.11-v7l+
                      npm ERR! gyp ERR! command "/usr/local/bin/node" "/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/.bin/node-gyp" "rebuild"
                      npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll
                      npm ERR! gyp ERR! node -v v14.16.0
                      npm ERR! gyp ERR! node-gyp -v v7.1.2
                      npm ERR! gyp ERR! not ok
                      npm ERR!     /home/pi/.npm/_logs/2021-03-17T21_03_25_216Z-debug.log
                      i tried with npm install (a second time), but this doesn’t change anything
                        sdetweil @matze86
                        @matze86 sorry. no idea from here.i had a similar problem in one of my modules.
                        I rewrote part of it to eliminate the troublesome library
                          matze86 @sdetweil
                          now i reinstalled raspberry os and still got the same error…
                          [19.03.2021 23:16.00.366] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                          NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                          [19.03.2021 23:16.00.367] [LOG]   Loading module helpers ...
                          [19.03.2021 23:16.00.368] [LOG]   No helper found for module: alert.
                          [19.03.2021 23:16.00.368] [LOG]   Initializing new module helper ...
                          [19.03.2021 23:16.00.369] [LOG]   Module helper loaded: updatenotification
                          [19.03.2021 23:16.00.370] [LOG]   No helper found for module: clock.
                          [19.03.2021 23:16.00.374] [ERROR] Whoops! There was an uncaught exception...
                          [19.03.2021 23:16.00.378] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                              at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                              at Module.require (internal/modules/cjs/loader.js:692:17)
                              at require (internal/modules/cjs/helpers.js:25:18)
                              at module.exports._ (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:7:31)
                          [19.03.2021 23:16.00.379] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [19.03.2021 23:16.00.380] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            sdetweil @matze86
                            @matze86 do this
                            from the MMM-Navigate folder
                            npm rebuild epoll --update-binary
                            worked for me
                            note that this compiled version won’t work if you use electron now…
