    Can't install MMM-Navigate
    13 Posts 3 Posters 3.7k Views 3 Watching
    • K Offline
      keineAhnung123 @keineAhnung123
      sudo apt remove nodejs
      sudo apt install nodejs
      still Version 9.11.2 :(
        sdetweil @keineAhnung123
        @keineAhnung123 install nvm, and then use nvm to install node 10.23
        https://www.sitepoint.com/quick-tip-multiple-versions-node-nvm/
        • K Offline
          keineAhnung123
          Thank you, that worked.
          Is there a reason why 10.23 and not the newest 14.15.3 or 15.0?
            @keineAhnung123 cause we haven’t tested w those levels yet
              matze86 @sdetweil
              I tried to start my Mirror in server mode and than i got this error:
              [17.03.2021 20:17.36.506] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
              was compiled against a different Node.js version using
              NODE_MODULE_VERSION 76. This version of Node.js requires
              NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
              the module (for instance, using `npm rebuild` or `npm install`).
              [17.03.2021 20:17.36.508] [LOG]   Loading module helpers ...
              [17.03.2021 20:17.36.509] [LOG]   No helper found for module: alert.
              [17.03.2021 20:17.36.510] [LOG]   Initializing new module helper ...
              [17.03.2021 20:17.36.510] [LOG]   Module helper loaded: updatenotification
              [17.03.2021 20:17.36.511] [LOG]   No helper found for module: clock.
              [17.03.2021 20:17.36.517] [ERROR] Whoops! There was an uncaught exception...
              [17.03.2021 20:17.36.522] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                  at Object.Module._extensions..node (internal/modules/cjs/loader.js:1122:18)
                  at Module.load (internal/modules/cjs/loader.js:928:32)
                  at Function.Module._load (internal/modules/cjs/loader.js:769:14)
                  at Module.require (internal/modules/cjs/loader.js:952:19)
                  at require (internal/modules/cjs/helpers.js:88:18)
                  at bindings (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/bindings/bindings.js:112:48)
                  at /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:7:31
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:15:3)
                  at Module._compile (internal/modules/cjs/loader.js:1063:30)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
              [17.03.2021 20:17.36.525] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [17.03.2021 20:17.36.526] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              in “non-server-mode” it works very well.
              i reinstalled the module , npm, node.js, electron, but it still doesn’t work
              Any idea?
                sdetweil @matze86
                @matze86 right. the library epoll is compiled for electron, but not just node. (server mode)
                per the messages, I would try npm rebuild
                  matze86 @sdetweil
                  npm rebuild failed:
                  pi@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ npm rebuild
                  npm ERR! code 1
                  npm ERR! path /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll
                  npm ERR! command failed
                  npm ERR! command sh -c node-gyp rebuild
                  npm ERR! gyp info it worked if it ends with ok
                  npm ERR! gyp info using node-gyp@7.1.2
                  npm ERR! gyp info using node@14.16.0 | linux | arm
                  npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
                  npm ERR! gyp info spawn /usr/bin/python3
                  npm ERR! gyp info spawn args [
                  npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/gyp/gyp_main.py',
                  npm ERR! gyp info spawn args   'binding.gyp',
                  npm ERR! gyp info spawn args   '-f',
                  npm ERR! gyp info spawn args   'make',
                  npm ERR! gyp info spawn args   '-I',
                  npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/config.gypi',
                  npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/addon.gypi',
                  npm ERR! gyp info spawn args   '/home/pi/.cache/node-gyp/14.16.0/include/node/common.gypi',
                  npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                  npm ERR! gyp info spawn args   '-Dvisibility=default',
                  npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/pi/.cache/node-gyp/14.16.0',
                  npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp',
                  npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/pi/.cache/node-gyp/14.16.0/<(target_arch)/node.lib',
                  npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll',
                  npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                  npm ERR! gyp info spawn args   '--depth=.',
                  npm ERR! gyp info spawn args   '--no-parallel',
                  npm ERR! gyp info spawn args   '--generator-output',
                  npm ERR! gyp info spawn args   'build',
                  npm ERR! gyp info spawn args   '-Goutput_dir=.'
                  npm ERR! gyp info spawn args ]
                  npm ERR! gyp ERR! build error
                  npm ERR! gyp ERR! stack Error: You must run `node-gyp configure` first!
                  npm ERR! gyp ERR! stack     at ReadFileContext.<anonymous> (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/lib/build.js:43:20)
                  npm ERR! gyp ERR! stack     at ReadFileContext.callback (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/graceful-fs/graceful-fs.js:123:16)
                  npm ERR! gyp ERR! stack     at FSReqCallback.readFileAfterOpen [as oncomplete] (fs.js:273:13)
                  npm ERR! gyp ERR! System Linux 5.10.11-v7l+
                  npm ERR! gyp ERR! command "/usr/local/bin/node" "/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/.bin/node-gyp" "rebuild"
                  npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll
                  npm ERR! gyp ERR! node -v v14.16.0
                  npm ERR! gyp ERR! node-gyp -v v7.1.2
                  npm ERR! gyp ERR! not ok
                  npm ERR!     /home/pi/.npm/_logs/2021-03-17T21_03_25_216Z-debug.log
                  i tried with npm install (a second time), but this doesn’t change anything
                    sdetweil @matze86
                    @matze86 sorry. no idea from here.i had a similar problem in one of my modules.
                    I rewrote part of it to eliminate the troublesome library
                      matze86 @sdetweil
                      now i reinstalled raspberry os and still got the same error…
                      [19.03.2021 23:16.00.366] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                      NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                      [19.03.2021 23:16.00.367] [LOG]   Loading module helpers ...
                      [19.03.2021 23:16.00.368] [LOG]   No helper found for module: alert.
                      [19.03.2021 23:16.00.368] [LOG]   Initializing new module helper ...
                      [19.03.2021 23:16.00.369] [LOG]   Module helper loaded: updatenotification
                      [19.03.2021 23:16.00.370] [LOG]   No helper found for module: clock.
                      [19.03.2021 23:16.00.374] [ERROR] Whoops! There was an uncaught exception...
                      [19.03.2021 23:16.00.378] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                          at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                          at Module.require (internal/modules/cjs/loader.js:692:17)
                          at require (internal/modules/cjs/helpers.js:25:18)
                          at module.exports._ (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:7:31)
                      [19.03.2021 23:16.00.379] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [19.03.2021 23:16.00.380] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        sdetweil @matze86
                        @matze86 do this
                        from the MMM-Navigate folder
                        npm rebuild epoll --update-binary
                        worked for me
                        note that this compiled version won’t work if you use electron now…
