    Search module for livecam / stream
    28 Posts 4 Posters 5.1k Views 4 Watching
    • JerryPJ
      JerryP @KamiSchami
      @KamiSchami
      Yes you must first install the module.
      https://github.com/shbatm/MMM-RTSPStream
      pleas follow the wiki.
      and the line 950 is wrong.
      you must end whit
      } ] at line 950
      • KamiSchamiK
        KamiSchami
        … no, sorry 🙈 omxplayer is installed
        Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
        • KamiSchamiK
          KamiSchami
          … oooooh… cool, but no pic
          JerryPJ 1 Reply Last reply Reply Quote 0
          • KamiSchamiK
            KamiSchami
            Yes, yes ,yes HERO od my day !!! Thank you!
            • JerryPJ
              JerryP @KamiSchami
              • JerryPJ
                JerryP @KamiSchami
                @KamiSchami I think you have made a small config failler.
                But I sa a later post that i’t was up and running.
                Picture please.
                • KamiSchamiK
                  KamiSchami
                  works. Still have to adjust the size a bit. Unfortunately it currently fades my buttons. Any other tip for formatting the css for me?
                  JerryPJ 2 Replies Last reply Reply Quote 0
                  • JerryPJ
                    JerryP @KamiSchami
                    @KamiSchami
                    And if you put in the config
                    	URL"http://"bla bla bla
                            width: 590,
                    	height: 332
                    • JerryPJ
                      JerryP @KamiSchami
                      @KamiSchami
                      When you put this in the CSS the white outline (Box) is going to none
                      * custom.css
                      .MMM-RTSPStream .innerWrapper {
                          border-style: none;
                      • KamiSchamiK
                        KamiSchami
                        Ok great 🍻
                        • KamiSchamiK
                          KamiSchami
                          ok, the edge is gone, but i can’t get the cam behind my button 🙈
                          • JerryPJ
                            JerryP @KamiSchami
                            @KamiSchami
                            can you pleas ad your config file.
                            • KamiSchamiK
                              KamiSchami
                              All? It’s long 🤣
                              • JerryPJ
                                JerryP @KamiSchami
                                @KamiSchami only the part of the
                                module: ‘MMM-RTSPStream’
                                • KamiSchamiK
                                  KamiSchami
                                  • JerryPJ
                                    JerryP @KamiSchami
                                    @KamiSchami You can use this.
                                    		module: "MMM-RTSPStream",
                                    		disabled: false, //false, true
                                    		position: "middle",
                                    			autoStart: true,
                                    			rotateStreams: false,
                                    			rotateStreamTimeout: 20,
                                    			moduleWidth: 468,
                                    			moduleHeight: 320,
                                    			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
                                    			remotePlayer: 'none',
                                    			showSnapWhenPaused: false,
                                    			remoteSnaps: false,
                                    			  stream1: {
                                    			  url: 'https://cam01.binz-kabel.de/cam1.m3u8',
                                    			  protocol: "tcp",
                                    			  frameRate: 25,
                                    			  muted: true,
                                                              hwAccel: true,
                                                              width: 450,
                                                              height: 300,
                                    • JerryPJ
                                      JerryP @JerryP
                                      @KamiSchami this part I meen
                                      			  stream1: {
                                      			  protocol: "tcp",
                                      			  frameRate: 25,
                                      			  muted: true,
        hwAccel: true,
        width: 450,
        height: 300,
                                      • KamiSchamiK
                                        KamiSchami
                                        Thanks, it was late yesterday. The camera was gray and night mode and my buttons are also gray, I have to check if it is brighter.
                                        • KamiSchamiK
                                          KamiSchami
                                          hi, it’s still over the button when i enlarge the module 🙈
                                            drx1984 @KamiSchami
                                            @KamiSchami what am I doing wrong?
                                            for me MM starts but the whole screen remains black
                                            Can someone help me please?
                                            Is the MMM-RTSPStream module up to date? still works?
